November 14, 200719 yr comment_64811 (upgrading my vinyl rig) Well then here's your new phono stage. Report
November 14, 200719 yr comment_64830 It's an excellent phono amp, you should definitely get one. Or maybe you can get their pre-amp... Report
November 14, 200719 yr comment_64916 AudioValve RKV with Impedanzer is intended to drive speakers...but it's not SET. Report
November 14, 200719 yr Author comment_64919 aerius any estimate on how much the Wavelength Bugle would cost to build? Report
November 14, 200719 yr comment_64940 aerius any estimate on how much the Wavelength Bugle would cost to build? Looks to be in the ballpark of $1-1.5k depending on the parts used and how fancy you get with the case. I could be a bit on the low side since I haven't priced out capacitors lately. Report
November 19, 200718 yr comment_68232 And now for something completely different. A push-pull design using directly heated pentodes. Puts out around 4 watts per channel. Report
November 19, 200718 yr comment_68287 This could be turned into a Stax amp as well. Could be pretty nice indeed Report
November 20, 200718 yr Author comment_68640 I'm going to use the Beetah twenty twos speaker outs with the Duos in the in term. Thanks for all the feedback guys, but I realized an in between amp would drive me crazy and it will be all that much sweeter when I get those 300B amps. And I might get a chance to hear the B22 with some Duos, depending on when it's finished. e: I still need a preamp (preferrably with remote, laziness ftw) Report
November 20, 200718 yr comment_68643 Here is another temp solution: http://www.decware.com/newsite/mainmenu.htm?/newsite/dm944.htm&intro for 675$ or http://www.decware.com/newsite/images/tabooblacksmall.jpg for 995$ To be found at www.decware.com . Check out the HDT speakers while you are at it. These have been very well reviewed over in the Asylum and AudioKarma. Report
November 20, 200718 yr Author comment_68718 I do appreciate it slwiser, but nothing beats paying nothing to use my B22 Report
November 20, 200718 yr comment_68730 What is your pre going to be? Going integrated? Using your b22 as a pre? Report
November 20, 200718 yr Author comment_68737 What is your pre going to be? Going integrated? Using your b22 as a pre? The B22 will be an integrated amp (with nice headphone amp ) When I get the blocks I'd like a pre with a remote control. Report
November 20, 200718 yr comment_68738 When I get the blocks I'd like a pre with a remote control. Ah ha. I see. Report
November 20, 200718 yr Author comment_68804 Ah ha. I see. The last thing I'm doing after busting my ass all day is getting up and walking 10 feet to change the volume Report
November 20, 200718 yr comment_68806 I'm sure the beta could be reconfigured to use both remote volume and source control. That'd be the route I'd go before adding another preamp to the chain. Report
November 20, 200718 yr comment_68838 The last thing I'm doing after busting my ass all day is getting up and walking 10 feet to change the volume There's always that balanced remote 99 step attenuator that sft used in the dynamights. Report
November 20, 200718 yr comment_68840 I'm sure the beta could be reconfigured to use both remote volume and source control. That'd be the route I'd go before adding another preamp to the chain. I can hook that up jpak, if you so choose. Report
November 20, 200718 yr comment_68847 There's always that balanced remote 99 step attenuator that sft used in the dynamights. Yet another link that I will have lost if Head-fi doesn't come back. Report
November 20, 200718 yr comment_68852 Jpak, here is a decent option: http://eshop.diyclub.biz/product_info.php?cPath=85&products_id=195 Report
November 20, 200718 yr comment_68856 Jpak, here is a decent option: http://eshop.diyclub.biz/product_info.php?cPath=85&products_id=195 Doesn't it need to be 4-channel for balanced operation? Report
November 20, 200718 yr comment_68858 http://eshop.diyclub.biz/index.php?cPath=85_186 http://eshop.diyclub.biz/product_info.php?cPath=85_186&products_id=217 Report
