kevin gilmore Posted March 16, 2024 Report Posted March 16, 2024 So this started a few weeks ago when someone found a picture of my 100 watt night light. Its an 833A tube. (new picture below) And he wanted a megatron made from 8 of these. (10 vac at 10 amps each tube) so 800 watts filament power just for the output tubes. By the time you make the +/- 1kv power supplies running at 40ma, and the power for the 300b driver tubes etc, way past the limit for usa 120v 20 amp service which is 1850 watts. And with the top of the tube at silly and dangerous high voltage... bad idea. So i started looking for slightly less silly alternatives. I think the 211 tube fits the bill. running with +/-750v power supplies at 35ma. So a megatron with 211 output tubes, 300b drivers and a high gain input tube. unless someone has a better idea. 8 Quote
spritzer Posted March 16, 2024 Report Posted March 16, 2024 This might be too crazy for me but why not go further. I happen to have a couple of 30kWh, 400V battery packs so a DC-DC converter and make it "portable"? 1 1 4 Quote
G600 Posted March 16, 2024 Report Posted March 16, 2024 March madness, redux. Was the original March madness in 2013? Quote
jamesmking Posted March 16, 2024 Report Posted March 16, 2024 2 hours ago, spritzer said: This might be too crazy for me but why not go further. I happen to have a couple of 30kWh, 400V battery packs so a DC-DC converter and make it "portable"? portable if you are godzilla or king kong.... 1 Quote
simmconn Posted March 19, 2024 Report Posted March 19, 2024 I like the idea with the 211. It also helps keeping the noise from the filament supply at bay with the common cathode configuration. If matching tubes for the CCS sounds too much, we can always consider the 1700V depletion mode SiC JFET. Thermal management is going to be a challenge though at 35ma. Quote
kevin gilmore Posted March 29, 2024 Author Report Posted March 29, 2024 i like that. i also like "david and goliath" 1 Quote
kevin gilmore Posted March 30, 2024 Author Report Posted March 30, 2024 (edited) there will be 4 output boards. 12 x 6 inch each. filament boards will stack on them, each filament board will have 5 x 5v 4a switchers. 2 switchers in series for the 211 so chassis is likely to be a bit over 24 inches wide and 20 inches deep. updated picture Edited March 30, 2024 by kevin gilmore 3 Quote
Emooze Posted April 3, 2024 Report Posted April 3, 2024 Sign me up, probably be cheaper than paying for heat in the winter. Quote
psyduck Posted April 9 Report Posted April 9 @kevin gilmoreI think 833A tubes with 1Kv supplies would work with 230V mains 10A. Quote
JoaMat Posted September 11 Report Posted September 11 (edited) Nice Omron relay 3D model, don't you think? Zoom in for a good look. Edited September 11 by JoaMat 1 Quote
MLA Posted September 12 Report Posted September 12 (edited) Very nice! A new JoaMat "interesting twist"-project in the works I believe ? Edited September 12 by MLA Quote
JoaMat Posted September 12 Report Posted September 12 (edited) Have made schematic out of Kevin’s published gerbers of David and Goliath filament. From schematics a PCB layout following the original gerbers is made and the above 3D model is the result. I’m addicted to make my own twist of others work. So, now can the process of shrinking Kevin's board start. Just to be clear, David and Goliath project is insane. I like that. Edited September 12 by JoaMat Quote
kevin gilmore Posted September 12 Author Report Posted September 12 no real reason to shrink the filament board, but go ahead and try. the output tube spacing is already at the minimum and that results in a specific board size. no reason for the filament board to be any smaller than that because all the holes need to line up. filament board stacks on the output board. Quote
JoaMat Posted September 12 Report Posted September 12 Yep, I’ve noticed output and filament boards match up to each other. Here is how it looks like on my screen, all output tubes side by side. Size 24 in x 12 in – huge. Question regarding jumbo socket – what socket do you have in mind? This from a French company might fit.? 3 Quote
kevin gilmore Posted September 12 Author Report Posted September 12 was planning on using the teflon versions on ebay. but i think that ceramic one is exactly the same size. Quote
JoaMat Posted September 12 Report Posted September 12 Thanks. I avoid ebay. Goods tend to be stuck or disappear in Swedish customs. Suggestions about +/-750V? Quote
kevin gilmore Posted September 12 Author Report Posted September 12 there are a couple of places that sell the same thing that are not ebay. circlotron power supply works fine for 700v, 800v etc. Quote
JoaMat Posted September 12 Report Posted September 12 Lovely, finally some use for circlotron psu. Most things settled - only finance issue… no prediction. Quote
kevin gilmore Posted Sunday at 05:14 PM Author Report Posted Sunday at 05:14 PM (edited) so here is the latest version of the kgsshv-carbon with the c3m series parts including the current source. Good for up to +/-600v power supplies. kgsshvcarbonv6.1c3cs - CADCAM.ZIP kgsshvcarbon600v.PDF Edited 7 hours ago by kevin gilmore 5 1 Quote
kevin gilmore Posted 12 hours ago Author Report Posted 12 hours ago (edited) and the power supply that goes with it. standard off the shelf antek transformers are $44. need 2 circlotronpsupdated.pdf kgsshv600vpower - CADCAM.ZIP Edited 12 hours ago by kevin gilmore 3 Quote
chinsettawong Posted 12 hours ago Report Posted 12 hours ago Does it have enough power to driver the Jackling Float? Quote
spritzer Posted 10 hours ago Report Posted 10 hours ago Yes, it should have no problem with that. The only issue might be gain and bias but easy to solve. 1 Quote
kevin gilmore Posted 10 hours ago Author Report Posted 10 hours ago definitely has enough power for that. 2400 volts peak to peak stator to stator at 25ma bias. only otl dc coupled solid state amplifier design that can do this. 1 Quote
simmconn Posted 6 hours ago Report Posted 6 hours ago Q12 in the PSU seems full-on and not doing much if anything. I noticed that the 2N3904-based current limiter is not there. Many people say it is too slow, not realizing that it is protecting the passing SiCFET at every power up, before the opto coupler soft start switch is released. On the other hand, if the SiCFET decides to give up, nothing can hold it back anyways. The 2N3904-based current limiter should not be the one to blame. The amp section still uses PZTA42 despite the linearity issue we found earlier and better options are available. The STN9360 although is specified with a 600V VCEO, its curve shows onset of breakdown at a lower voltage. I didn’t take a picture with the STN9360, but the one below is similar. Technically the breakdown voltage is specified at point A, but you wouldn’t want to operate the part at point B, even though that’s still “within spec”. Quote
