July 26, 200818 yr comment_143766 Can anyone tell me which earpad is the best one for grado ps1? bowl one, flat one, or the earpad of GS1000, or anything else you think it is the best In addition, can you also tell me which amplifier is good for the phone? thanks for your time to help me Report
July 26, 200818 yr comment_143767 I'll take a stab at this. I have limited experience with the RS1s which is what I think you meant, but the two amps I liked with the RS1s were the EC/SS and the Gilmore Lite. That's it, you have exceeded the limit of my RS1 experience. Good luck Shin and welcome to Head Case. 気違いへようこそ Report
July 26, 200818 yr comment_143771 I prefer the bowls on the PS1s, with RS1s & Hp1000s I use flats. I use modded melos /but the Zana Duex also works well. The GS1000 pads are not a good match at all. Report
July 26, 200818 yr comment_143773 Bowls with ps-1. Flats. senn h414 pads or squished bowls for rs-1s. Biggie. Report
July 27, 200818 yr comment_143805 Bowls. For an affordable price, I liked the Mad Ear++ with the PS-1. But tubes in general. Report
July 27, 200818 yr Author comment_143952 thanks for your sharing experience after trying to compare between the bowl and flat earpad for ps1 i can tell that the flat will make the sound become wider . However, the bass become stronger for the bowl, the sound become less wide and smaller i try to listen to ps1 without using any earpad and was impressed at the sound. Nice soundstage and bass. Maybe from now , i should use a naked ps1 ;D Report
August 7, 200818 yr comment_147466 There is not such thing as best pads. In my opinion, having bowls and flats is a must. I prefer flats with rock, especially with metal, but bowls with pretty much everything else. Report
August 10, 200818 yr comment_148310 Yep, flats and bowls have their role on the PS-1, but I like better the bowls. I find tonality more accurate and bass a bit less prominent with the bowls. Also the stage for my ears is a bit wider than with flats. However metal and any hard rock sounds so much "you're there and we're shaking your guts" that I can understand metal fans prefer them. Rgrds Report
August 11, 200818 yr comment_148599 Bugger sharing the knowledge. I just want somebody to share their PS-1s with me!! Report
August 16, 200818 yr comment_150958 To me, bowls are the right one. As for the amps, SinglePower or Zana Deux would make a great match. Also I believe that EAR would make them shine as well, but thats what I have to find out in the future... Report
August 17, 200818 yr comment_151253 I swapped between bowls and flats on the PS1 at a recent meet off the Zana Deux. I preferred the flats myself but could see how some might prefer bowls. The flats made the bass thicker and more fun. But for the cost of either pads, you owe it to yourself to own both of course. It's like an ultra-cheap way to get two sounds out of almost any Grado. I have almost no amp experience with the PS1, having heard it only two times (first out of the Cayin HA-1A in 2006, and last month out of the Zana Deux) but matching should definitely be done carefully. I think it'd be more cost effective to pair with a tube amp since tubes can be easily rolled to tweak the sound, unless you have the time & budget necessary to experiment with solid-states. Report
August 17, 200818 yr comment_151286 I use a PS-1 with Moon Audio Black Dragon cable with a Zana Deux. I prefer bowl pads. Using flat pads can be good with some types of music such as fast-paced dance music or electronica, but I think the flats have a bit too much bass slam and thump. Bass quantity using the bowl pads is not exactly lacking. I've found that tube rolling the 6SL7 for the PS-1 can be a bit tricky. I generally like a more fuller-bodied and warmer sound for the PS-1 as well as other Grados, but some tubes that have good body and warmth such as the Mullard CV569 can also make it seem too bass-heavy. I've settled on using Sylvania VT229 for the PS-1. My PS-1 is balanced but I don't have a balanced amp yet. Report
