March 4, 200917 yr comment_211603 Raid 0 1TB SSD OCZ Demos 1 TB RAID0 Solid-State Drive with Unbelievable Transfer Speeds Who would of guessed that exactly OCZ will be able to achieve the unachieveble. At CeBIT the famous overclocking memory and peripherals maker has demoed Z Drive, a PCI-Express x8 connection storage device that boasts four 256 GB (MLC-equipped) solid-state drives in RAID 0 setup. In total we get 1 TB space and 256 MB of data cache. Put this into a system with a Core i7 965 EE CPU and an ASUS P6T motherboard, get some external power for the drives, and you'll easily reach transfer speeds at up to 712 MB/s read, 500 MB/s write as well as almost zero access time, a dream come true. Now the bad news, the Z Drive is obviously going to cost a lot, about $1500 to be more precise. http://www.techpowerup.com/86997/OCZ_Demos_1_TB_RAID0_Solid-State_Drive_with_Unbelievable_Transfer_Speeds.html Report
March 4, 200917 yr Author comment_211608 complete overkill, which is the perfect amount. Imagine it in a music server context; complete silence. How much do people pay for that in high-end audio? Quite a bit. Report
March 4, 200917 yr comment_211613 I can't wait until these things become affordable. I would love to have a 4TB version. Report
March 4, 200917 yr comment_211626 Want. Actually, US$1500 is pretty reasonable for early adopter prices. I was expecting worse, given the verbage. Report
March 4, 200917 yr comment_211628 They are hardly the first. The fusion-io stuff has been available for a while. Given it's more expensive it also doesn't need to use RAID 0 to hit it's performance numbers. http://www.dvnation.com/Fusion-IO-IODrive-SSD-Solid-State-Disk-Drive.html http://www.fusionio.com/Products.aspx Report
March 4, 200917 yr Author comment_211629 I bet someday there will be a raid 1 version. 2 of those in 2TB and I'm set, for like, at least 6 months. Report
March 4, 200917 yr comment_211630 There are already devices like that, and at much higher storage levels. They do cost a fortune though. http://violin-memory.com/index.php They don't list prices for a reason... if you have to ask.... Edited March 4, 200917 yr by tkam Report
March 4, 200917 yr comment_211636 Data rate was 6744843.89 Kbytes/sec, thread utilization 0.970 This is my work san Report
March 4, 200917 yr comment_211640 It'd be pointless to have that much speed for a music server, tho. You're not going to push that much bandwidth for any music task. I use it for weather prediction Report
March 4, 200917 yr comment_211710 Watching Bluray disk rips while downloading full speed off of a fibre channel network with a gigabit ethernet card wouldn't even touch that speed. What would you use that for that could make it a possible bottleneck? I love it. Report
March 4, 200917 yr comment_211714 Watching Bluray disk rips while downloading full speed off of a fibre channel network with a gigabit ethernet card wouldn't even touch that speed. What would you use that for that could make it a possible bottleneck? I love it. Can we save this post to remember in another ten years and have a good laugh? Report
March 4, 200917 yr comment_211715 The thought occurs that you wouldn't be able to use the sucker as a boot drive. Unless theres some sort of hax or it connects to SATA as an option. Report
March 5, 200917 yr comment_211928 Can we save this post to remember in another ten years and have a good laugh? Yes, I deserve it, epic fail. I should know that a theoretical Gb/sec is more then 500 mb/sec. Report
March 5, 200917 yr comment_211931 disk io is definitely a bottleneck for me on the above referenced system Report
March 5, 200917 yr comment_211947 disk io is definitely a bottleneck for me on the above referenced system I'm actually sort of surprised by this grawk. Is the model really that data intensive that disk access is a problem or do the researchers do something stupid like write every time step? I mean if you're writing to disk you're screwed as far at simulation throughput. Report
March 5, 200917 yr comment_211954 Am I the only one to hear Styx every time I read the subject of this thread? Report
