August 23, 200917 yr comment_269366 I'm hoping to pick up a pair of A5s soon but due to my desk arrangement I can only handle stands with about a 4 inch rise max. I just noticed these stands on the Audioengine site. Audioengine DS1 Anyone try them out or something similar? I know ideally I should get the speakers up higher but angled like this may be my best option. Report
August 23, 200917 yr comment_269369 Studio Isolation Tools | Sweetwater.com You might be able to find them cheaper on ebay Report
August 23, 200917 yr Author comment_269387 Studio Isolation Tools | Sweetwater.com You might be able to find them cheaper on ebay Thanks. The MoPADs look interesting but are a little big. I may just pull the trigger on the DS1's and report back. Report
August 23, 200917 yr comment_269394 I've found one of these and one of these works pretty well for my A5s. A couple inches over your requirements though. Report
August 24, 200917 yr comment_269592 Hi Veloaudio - if you're still considering the ADS1 stands for your A5's you might want to double-check the dimensions as they were designed for smaller speakers such as the A2: Audioengine - Upgrade your music I'm with Audioengine and we're working on a large stand with a similar design (ADS2 - how original) for the A5s and passive AP4 speakers. The tooling is a bit tricky for the material used on these so they won't likely be out until Dec. I hope this isn't taken as shilling - I just wanted to give a heads-up on these stands so you're not disappointed if you buy them for the A5! Best regards, Brady Audioengine Report
August 24, 200917 yr comment_269603 Hi Veloaudio - if you're still considering the ADS1 stands for your A5's you might want to double-check the dimensions as they were designed for smaller speakers such as the A2: Audioengine - Upgrade your music I'm with Audioengine and we're working on a large stand with a similar design (ADS2 - how original) for the A5s and passive AP4 speakers. The tooling is a bit tricky for the material used on these so they won't likely be out until Dec. I hope this isn't taken as shilling - I just wanted to give a heads-up on these stands so you're not disappointed if you buy them for the A5! Best regards, Brady Audioengine Welcome to Head-Case Brady and not that I have the final opinion on such matters but I think your post is just fine. I think Velo will appreciate the heads-up. Report
August 24, 200917 yr comment_269639 I hope this isn't taken as shilling...Absolutely not, you let us know up front you're with the company, which is all we ask (it's the difference between shilling and just responding responsibly). You may get labelled as a MOT (Member Of the Trade), though (so you don't have to announce yourself every time you post). Report
August 24, 200917 yr comment_269640 Thanks! I've been lurking on and off and try to follow everything that's going on with the latest h-phones, amps, etc.. It's so refreshing to see new high-quality gear - at prices that even people with startup companies can afford. Report
August 25, 200917 yr Author comment_269825 Hi Veloaudio - if you're still considering the ADS1 stands for your A5's you might want to double-check the dimensions as they were designed for smaller speakers such as the A2: Audioengine - Upgrade your music I'm with Audioengine and we're working on a large stand with a similar design (ADS2 - how original) for the A5s and passive AP4 speakers. The tooling is a bit tricky for the material used on these so they won't likely be out until Dec. I hope this isn't taken as shilling - I just wanted to give a heads-up on these stands so you're not disappointed if you buy them for the A5! Best regards, Brady Audioengine Brady, I saw the DS1's on the site and assumed they would fit. I had not compared the dimensions of the A5 to the stands yet. Any idea when the DS2 might be released? Thanks for the info and welcome to Head-case! -Matt Report
August 25, 200917 yr comment_269889 Brady, I saw the DS1's on the site and assumed they would fit. I had not compared the dimensions of the A5 to the stands yet. Any idea when the DS2 might be released? Thanks for the info and welcome to Head-case! -Matt It looks like December at the earliest. The tooling is a bit tricky for the material used on these so they won't likely be out until Dec. Report
August 26, 200917 yr Author comment_270173 It looks like December at the earliest. I'm thinking December. Evidently I can't read Report
August 26, 200917 yr comment_270185 The DS1's might still work, though, neh? By tilting the speaker, you're moving the center of gravity over to a more stable area. I guess it depends on the speaker. Report
September 7, 200916 yr Author comment_274115 Well my A5's came in. Like them so far but I knew right away I had to get them off the desk. Here is my current solution: Report
September 8, 200916 yr comment_274202 Thats actually how the A2s are set up for me right now. They work very well Report
September 8, 200916 yr Author comment_274203 I don't like how they look but they work and they were free Report
