The Headcase Stax thread
Talking about the pads: Given the price for Stax earspeakers, I was shocked to learn that the pads are affixed using adhesive sheets. I expected something more “mechanical” than adhesion. One pad is already peeling away a little bit.
  • Replies 14.4k
  • Views 3.5m
  • bwck2000
    bwck2000
37 minutes ago, Hi-Fi-Anatomia said:
@spritzer
How does the OG SR-Omega compare to the modern Omega II 2.9?
Given the SR-Omega is in 100% working condition (which isn't given at their current age) the Omega is warmer, with looser bass, more rolled off top end and the imaging is far less precise.  A lot of this though depends on the earpads which were always an issue with the Omega.
@spritzer Interesting. I always hear 'fables' of the original Omega so I was quite curious. The 2.9 is the best Stax phone I have ever owned by a long shot. Is the midrange on the 2.9 more akin to the 007mk1 or the more tilted midrange of the mk2.5? Or are the mid ranges pretty much the same
Out of curiosity, where is the dust cover of the 007 located? In the modern lambdas I can see it from the outside (the thin plastic outside of the stator, right?) but I don't see it on 007 even when zooming in on the pictures @spritzer took of port modding 007. Does it just not have dust covers?
Found this, 007 with custom EQ. No difference in output across amps. Thoughts?
I'd be pretty happy if I found out my 252 can do 20-20 kHz above 100 dB on an 007.
Put this one down as wishful thinking, perhaps....?
Is an acrylic omega-style stand for my Stax SR-207 earspeakers a no-no because of static buildup? I just bought it but haven’t received it yet. I would use a dust over.
So, I just received a Stax SR-X MK3 normal bias today which is in absolutely immaculate condition. It's at least 40 years old at this point but for all I know it could have been opened a week ago. It also sounds really, really good to my ears considering the very low price I paid for them, easily beating out anything I've heard at sub 600-700 dollars. I've seen that the pro bias version of these is apparently all the rage, how do they differ, sound wise?
More extension really, better bass, better top end and slightly superior imaging.
... and possibly drier electrolytic caps.......
..and somewhat drier to my ears. (take my impressions with grain of salt since I didn't have them side by side)
What electrolytic caps?
Edited by Tachikoma
1 hour ago, Tachikoma said:
.What electrolytic caps?
In @wink's headamp. Or in mine was it a joke ??
Is there a problem with plugging stats into a live amp or unplugging from a live amp, as opposed to plugging into & unplugging from an unpowered amp? I have made those mistakes a couple of times.
Unless you're plugging into a Woo adapter box or unmodified GES or WES.
about 5 megohms of resistance in the bias supply to the earspeakers
Yeah and manufacturers not giving two shits about the safety of the user
So I've had my SR-007 for a few weeks now and I've noticed that despite it being cool in my room 64F (17.7C)  and dry hair my ears get really hot and the black metal part with the holes (baffle?) has condensation on it. While I didn't notice this with my Nova Signature i have seen it in several of my other dynamics namely all of my Pioneers where i could see Moisture directly on the baffle and diaphragm.That being said I can probably assume this means moisture is on the moisture guard of the 007. I guess i just wanted to find out why this is happening is it extremely bad and if so is it better I just Shelve my 007s so I don't damage them? For reference I have an SR-007mk1 72xxx serial and I use them to listen to music around 4 hours a day during the week and about 12-16 hours a day on the weekends. Is it just the fact that I have such long listening sessions this happens or something else? Sorry for the rambling post I'm just worried About the headphones I just fell in love with.
