The Ultimate DIY Part 2 ? The KGITSOJC
Nice! Were there any changes to the previous layout and schematic? could you post the final layout you sent to LK?
  • Replies 350
  • Views 133.9k
  • kevin gilmore
    kevin gilmore
    Sure there is a schematic. Its in my head somewhere. There will be an official schematic at some point. There is a bunch of different ways to build it including single ended only, and balanced/sin
  • Has there been any work on this lately?  I really want to do this one.
  • Input JFETs just came in the mail. Most of them look real, there are a couple 2sk170s that have funky looking printing on them that I'm not sure about. Will measure IDSS later.    Finally the projec
I might have already asked this, but what would be the problem of using just one board as single ended?
the first thing that happens is that all inputs get converted to balanced.
So to use the thing as single ended you would need a bunch of dual rca to
xlr adapters, and you have to jumper across the input amp, then it actually
would work. The tape out would be unbuffered this way.
I do have the cardas stacked rca jacks in house, so i could do a single ended
board.
Couldn't I just use the + signal for left channel and - signal for the right one and share the ground? Or is this incompatible with the ic used?
I'm interested in single ended as well, but not a big deal building full balanced and using adapters.
Fine, i'll make a single ended version. I may be able to get both on the same board if i make it a bit bigger.
Then you stuff it one way for single ended and another for balanced.
The input chip is not compatible with single ended. So there will have to be 2 different single ended front
ends.
ends.
I'm fine with building a full balanced version. I'd rather have a full balanced one that is prototyped and known to work perfectly than screw with perfection.
well this should confuse most people
http://gilmore.chem....inputboard6.jpg
Stuff it with one set of parts and its balanced, and you need 2 boards,
stuff it with another set of parts and its unbalanced and you only need 1 board,
to keep it the same size, for unbalanced you give up an input.
The unbalanced input buffer is an lme49720 dual opamp, or your favorite
in a gain of 1 setup.
Needs a bit of checking now.
I'm efficient :D
I had been thinking about how to do this from the very start, so once i got the
cardas parts, it was actually pretty easy. The fact that cardas can't even supply
a dimensional drawing of what is supposed to be their own part is very sad.
Cool!! I don't antecipate balanced gear in the near future and this looks quite good!
I find that it falls off the shelf if it isn't balanced.
smile.png unbalanced/balanced input board, multiamp and blackhole.
Anyone in the US interested in prototyping the blackhole and multiamp? I have 1x set of blackholes and 1x set of multiamp (2 boards each, no PSU) that I can spare. No cost, just pay for shipping.
Edited by Lil Knight
I don't need a pre-amp, but now I really want one anyway!
Preamp board is 12.4 x 6 inches
multi amp is 6.1 x 3.4 inches
black hole is 3.5 x 3.62 inches
Looking good...
I do need a pre-amp, and I can't wait to get going on this one. :)
What's that saying Horio? It's just as easy to build 3 as 1? :D
Why just 3? :)
Hmm.. This baby is going to need two full size enclosures
I'm thinking 4 x preamp boards + 1 x input board + 2 x KG attenuator boards + local regulation in "audio box".
Transformers/rectifiers/1st bank of caps (or PS with remote sensing skipping regulation in audio box) + display + arduino/whatever in the "noisy box".
I2C and Power supply (and potentially remote sensing) connections between the boxes.
