May 14, 201016 yr I have been playing with idea of hooking up my netbook to my main system to play some FLAC files and WAV CD Rips that I got floating around. Most of them are HQ LP and CD rips of stuff that I can't find in any other format and that are rare as hens teeth. Burning them to CD is a nuance and I want to just play them using Foobar2000 feeding my DAC or just straight into a preamp. Not sure which way to go or what device to use. Do any of you use something like this? Have any suggestions?
May 14, 201016 yr Do any of you use something like this? Have any suggestions? Yup, I've used this in the past. M-Audio Transit Sound card - 96 kHz - 24-bit But now I just run slim server on the netbook and use the SB3, it's easier to control.
May 14, 201016 yr Author Yup, I've used this in the past. M-Audio Transit Sound card - 96 kHz - 24-bit But now I just run slim server on the netbook and use the SB3, it's easier to control. Looks like a nice way to hooked it up. Is it well made, looks a bit cheap and plasticy. I figure for $80 it's basic and will do the job just fine, but want to see if there are any potential issues. My DAC has optical and SPDIF so I can have my CDP on SPDIF and use optical for this guy.
May 15, 201016 yr I use: Musical Fidelity X-CANv8p -- includes both headphone amp (medium -- somewhere between an iPod out and a Beta22) and attenuate pre outs. Am happy with the DAC aspect, but I haven't even heard an Ayre.
May 15, 201016 yr I use the Trends UD-10.1 for just this role. I bought it for the multitude of outputs which is perfect for my gearwhoring but it works perfectly.
May 15, 201016 yr Author A lot of cool little devices out there, thanks for your suggestions guys. Now I need to figure out what I like Just got Primare CDP so computer as source is next on the list of system expansion to dos.
May 15, 201016 yr I use the Trends UD-10.1 for just this role. I bought it for the multitude of outputs which is perfect for my gearwhoring but it works perfectly. same. I also do have the musiland usd, and though I've never bothered to really compare the two, I probably wouldn't be able to tell the difference (though supposedly the musiland is async... supposedly...) I have kept the Trends for same reason as spritzer: every output choice possible.
May 15, 201016 yr Author I will probably go with this or the M2Tech Hiface, still haven't decided yet. I looked up M2Tech Hiface and don't like the construction, seems to put a lot of stress on the USB port, box with cables attached looks like a better choice for me since I have very limited space on my rack.
May 15, 201016 yr Author same. I also do have the musiland usd, and though I've never bothered to really compare the two, I probably wouldn't be able to tell the difference (though supposedly the musiland is async... supposedly...) I have kept the Trends for same reason as spritzer: every output choice possible. Trends does look nice, any issues with Windows 7?
May 15, 201016 yr Trends does look nice, any issues with Windows 7? I've never tried it but since there are no drivers to install I don't think there would be any issues.
May 15, 201016 yr I have the Trends Lite. It's actually even better under windows 7 because there are sound management toys to play with.
May 15, 201016 yr Halide Design Bridge Review | Computer Audiophile A $450+ 24/96 converter from Devilsound/Halide using GRs streamlength code.
May 16, 201016 yr Author Trends UD-10.1 looks good to me. I will try that Agon listing. Thanks for good advice.
May 16, 201016 yr The two final candidates for me are the HiFace or the Musiland Monitor 02 since these are the two which support asynchronous data transfer.
May 18, 201016 yr Author Got good price on that Trends UD-10.1. I will report back when I play a bit with it
May 18, 201016 yr I used to have the Trends, then upgraded to the HiFace. The HiFace sounds noticeably better, but I do agree that the form factor is a bit wonky. In terms of async USB converters, it's still one the best bargains out there however.
May 19, 201016 yr Author I used to have the Trends, then upgraded to the HiFace. The HiFace sounds noticeably better, but I do agree that the form factor is a bit wonky. In terms of async USB converters, it's still one the best bargains out there however. What aspects do you find to be better?
May 20, 201016 yr Would someone going Canjam to be able to compare the Halide design bridge directly to the Hiface possibly? I know digger will have the bridge.
May 21, 201016 yr What aspects do you find to be better? Better resolution, and a much blacker background; everything just sounds less 'grainy'. I attribute this to the inherently lower jitter of the Hiface's async implementation.
June 6, 201016 yr HiFace needs a support of some kind to relieve stress on the USB port Blue Circle Thingee
June 14, 201016 yr HiFace needs a support of some kind to relieve stress on the USB portThey do. Sortof. They sell a 1 foot USB cable...
April 28, 201313 yr Folks, sorry for resurrecting old thread. I recently sold my Bladelius Embla transport after some friend gave me an offer I couldnt resist. It's kind of revelation to me since I hate Embla user GUI vs computer player like foobar. Anyway, now I'm using Acer tablet (fanless) with SSD dock to Trends Audio UD10.1 with DIY battery pack connected to Neko and to BHSE. I have left out computer system since I have my Embla for almost 2 years. I'm looking at a better USB-SPDIF converter than the Trends Audio , been looking at Audiophilleo 2 (w/battery pack) or ART Legato. K3ct have Legato which I plan to try soon, but havent try any Audiophilleo. So folks, any advise or maybe just stick with my current converter? Im a bit skeptic when comes to the usefulness of this gizmo outside from converting digital usb to digital audio, but I'm not expert.....Thanks in advance.....
