spritzer Posted January 22, 2015 Report Posted January 22, 2015 Not really, I simply haven't run out of the prototype boards yet. It is also far more limited and intended to be run at just +/-400V. Only IXYS CCS and only matched K170 input fets too. There is also the issue of close proximity of the traces so careful soldering is a must have with those boards.
johnwmclean Posted January 23, 2015 Report Posted January 23, 2015 Birgir are there any other changes besides the local/global feedback removal?
spritzer Posted January 23, 2015 Report Posted January 23, 2015 Some layout changes and the small transistors have been changed to what should be available for the foreseeable future.
kevin gilmore Posted January 24, 2015 Author Report Posted January 24, 2015 the small transistors have been changed to what should be available for the foreseeable future. now where have I heard that one before?
JoaMat Posted January 24, 2015 Report Posted January 24, 2015 (edited) / Edited November 12, 2015 by JoaMat
nopants Posted January 24, 2015 Report Posted January 24, 2015 Are you recycling your T2 power supply for this? What are your thoughts?
DefQon Posted January 24, 2015 Report Posted January 24, 2015 What revision offboard are you using? I don't see any 4686's populated just 2 big transistors on each board.
RiStaR Posted January 24, 2015 Report Posted January 24, 2015 Nice... so how does your version of the carbon sound JoaMat?
spritzer Posted January 24, 2015 Report Posted January 24, 2015 His version is the same as mine, I just did the same thing on the PCB level. now where have I heard that one before? You know me, I like to tempt fate...
nopants Posted January 24, 2015 Report Posted January 24, 2015 Please grace us with some closeups, I have a set of v0.4 offboard pcbs which I'd love to modify into a kgsic. Less heatsink holes to drill+tap too
spritzer Posted January 24, 2015 Report Posted January 24, 2015 Just leave out the last stage. The CCS is changed to a 10M90 (same pinout as the other IXYS part) and use 300 and 1K resistors. The 2SC4686A is changed to the SiC FET
eggil Posted January 24, 2015 Report Posted January 24, 2015 Man, I am having a hard time keeping up with you guys! This looks interesting!
insanity Posted January 24, 2015 Report Posted January 24, 2015 Joamat, do you have any comparison with a conventional kgsshv, a kgst oder a bhse? New star sounds like better than BHSE?
JoaMat Posted January 24, 2015 Report Posted January 24, 2015 (edited) / Edited November 11, 2015 by JoaMat
eggil Posted January 25, 2015 Report Posted January 25, 2015 (edited) I have the hakko version of that desoldering gun. One of the best things I have ever bought Edited January 25, 2015 by eggil
nopants Posted January 25, 2015 Report Posted January 25, 2015 next version should have a tube ccs driving the sic... ripping up my offboard boards now, so excite
spritzer Posted January 25, 2015 Report Posted January 25, 2015 I also had to change the resistor in series with offset trimmer. What value did you end up with?
JoaMat Posted January 25, 2015 Report Posted January 25, 2015 (edited) / Edited November 11, 2015 by JoaMat
DefQon Posted January 25, 2015 Report Posted January 25, 2015 Wonder when Cavali will go from mosfets to SiC's....
kevin gilmore Posted January 25, 2015 Author Report Posted January 25, 2015 when sales of tle ll2t drop to zero. but he is still going to have to do a major redesign to get that to happen
spritzer Posted January 25, 2015 Report Posted January 25, 2015 Actually I shorted them out. Have just measured the trimmers setting - 360 and 400 ohms. Thanks for that. Better use a smaller pot then and something in series.
johnwmclean Posted January 26, 2015 Report Posted January 26, 2015 JoaMat, I’m curious as to what temperature your seeing with the carbon.
JoaMat Posted January 26, 2015 Report Posted January 26, 2015 42 deg C (107 deg F), temperature raise 20 deg C (36 deg F). Heat sinks are Modushop 200 mm x 80 mm, voltage +/-500 V.
