i'm on a roll... the kgsshv
Not really, I simply haven't run out of the prototype boards yet.  It is also far more limited and intended to be run at just +/-400V.  Only IXYS CCS and only matched K170 input fets too.   There is also the issue of close proximity of the traces so careful soldering is a must have with those boards.
  • Replies 5.4k
  • Views 1.3m
Birgir are there any other changes besides the local/global feedback removal?
Some layout changes and the small transistors have been changed to what should be available for the foreseeable future.
now where have I heard that one before?
Edited by JoaMat
Are you recycling your T2 power supply for this? What are your thoughts?
What revision offboard are you using? I don't see any 4686's populated just 2 big transistors on each board.
Nice... so how does your version of the carbon sound JoaMat?
His version is the same as mine, I just did the same thing on the PCB level.  :)
You know me, I like to tempt fate...  ;D
Edited by JoaMat
Please grace us with some closeups, I have a set of v0.4 offboard pcbs which I'd love to modify into a kgsic. Less heatsink holes to drill+tap too :)
Just leave out the last stage.  The CCS is changed to a 10M90 (same pinout as the other IXYS part) and use 300 and 1K resistors.  The 2SC4686A is changed to the SiC FET
Man, I am having a hard time keeping up with you guys!
This looks interesting!
Joamat, do you have any comparison with a conventional kgsshv, a kgst oder a bhse? New star sounds like better than BHSE?
Edited by JoaMat
I have the hakko version of that desoldering gun. One of the best things I have ever bought :)
Edited by eggil
next version should have a tube ccs driving the sic...
ripping up my offboard boards now, so excite
I also had to change the resistor in series with offset trimmer.
What value did you end up with?
Edited by JoaMat
Wonder when Cavali will go from mosfets to SiC's.... ::)
when sales of tle ll2t drop to zero.
but he is still going to have to do a major redesign to get that
to happen
Actually I shorted them out. Have just measured the trimmers setting - 360 and 400 ohms.
Thanks for that.  Better use a smaller pot then and something in series.
JoaMat, I’m curious as to what temperature your seeing with the carbon.
42 deg C (107 deg F), temperature raise 20 deg C (36 deg F). Heat sinks are Modushop 200 mm x 80 mm, voltage +/-500 V.
