Spring Cleaning DIY Stuff Thread [Final Update]
luvdunhill
ok, I have plenty of stuff that needs to go. Perhaps you do too. I'm open to all offers and if you're patient, I'll probably just give it away. Once this stuff goes, I have another list... so.. no prices, please make an offer.
Pair of unopened, and unused ports. These are the best ports money can buy I suppose:
Measurement Mic Preamp boards and Zen Headphone amp boards:
A collection of Brown Dog adapters:
Turntable motor pulley:
Random component video cable:
Mogami headphone cable:
Onzow Zerodust, barely used:
Twisted Pear Audio Ballsie, first generation I believe:
Chinese Softstart Board, works great:
A pair of mute delay and offset protection boards (http://www.amb.org/audio/epsilon12/):
A pair of 30mH inductors:
A pair of matched 6.8uF Wima caps for a LNMP (http://tangentsoft.net/elec/lnmp/):
Serpac project case:
New, never used Box project case:
Pair of Vifa XT25TG tweeters:
Pair of 14 awg, 12mH Jantzen inductors:
Elpac 24VDC linear regulated supply:
Plitron and Avel 22VAC x 2 toroids
A couple high quality switches:
Wallin Jig v2 for speaker measurement:
Twisted Pear Audio four pole relay board
A Chinese tube heater delay board, with indicator LED:
Simple adjustable LM317 supply (http://tangentsoft.net/elec/tread/);
A Bantam USB DAC (http://www.diyforums.org/BantamDAC/):
Few random caps, including some Mundorf Silver and Oil and some nice large valued Solens:
Four diamond buffers, with "pins" to drop into a 6DIP buffer like BUFXXX (http://diamondstar.de/dDB_overview.html):
Those Vifa ring radiator tweeters are badass. I have no idea what I'd do with them though.
buy two pairs and sell one? heh. It's one of the best performing tweeters out there. I would pair them with these:
https://www.madisound.com/store/product_info.php?products_id=925
I was hoping Naaman would snap these up, he mentioned a while back having a pair of the above. I'd be willing to work a deal, 1/2 price?
Hah! Great minds think alike! I also think that'd be a great pairing :)
Any additional info on the soft start circuit and how it gets implemented?
yes!
One end goes into the IEC socket the other goes to the toroid. There is a timer that switches in the large resistor in series then removes it. Also, provides filtering of minimal sort.
Similar in concept to this Soft-Start Circuit For Power Amps
I cannot find them on Ebay anymore, but that's where I got it, preassembled. Works great in fact.
more stuff
Borbely unregulated PSU boards:
Two Dynahi PSU boards (schematic):
24VAC wall wart, reterminated with nice screw on barrel connector:
( 7 ) Aavid TO-220 heat sink kits (Mouser part 532-4880 which uses Thermalflm)
( 3 ) TO-247/TO-3/etc. mica kits
( 24 ) Bergquist SP2000 pads (Digikey part number on packages, say TO-220 but will fit larger packages like TO-3P I believe)
( 3 ) aluminum oxide TO-247 insulators (I know I have more, but cannot find them anywhere...)
Titanium counter sink bit
15/16" Greenlee knock out, used just a few times. Useful for cutting Neutrik XLR holes
Fancy Power-Con power cable
Weller soldering iron descaler
Hakko Blue iron (perfect for chassis jacks and joints that sit on large ground planes)
( 5 pair ) binding posts:
PS Audio short, right angle power cords
Longish Audioquest mini to RCA cable
Soldering bench Cambridge Soundworks dipole speakers.
A nice chassis for a MC step-up transformer and a pair of Jensen step-ups. Probably about 15 minutes and you're ready to go with this. Case formally Consonnance MC step and has a foot front and nice metal domed feed:
( 1 ) not two 1.27mm Bondhaus hex wrenches that fit the tiny Rega tonearm adjustment screw
scary cables
HPS Rumble Filter board
( 2 ) unfinished ends for 1455 series Hammond case (I can track down the model upon request)
1 short JH audio IEM cable
( 3 ) Duende Criatura tube rings, large fits 6SN7 and two small fit 6DJ8:
Pair of BAT XLR to RCA adapters
Pair of calibration weights
iPod shuffle, great condition with a few marks.. first owner, bought at the start of the summer.
Pearl phono kit. I actually have all the parts to build this, so if you're interested we can talk. It will take a bit to scare up the odds and ends, but I do have them.
PSU delay board (I can get some more info on this for you if you're interested)
( 50 ) Berquist pads K10 for TO-247/TO-3P, etc.
( some ) TDA1543A DACs
( lots ) Output BJTs used in the Ayre V-5xe I believe. I have probably 50 pairs.
( 8 ) ceramic noval PCB sockets
( 4 ) CMC Bakelite UX4 sockets, includes mounting brackets
( 8 ) CMC ceramic octal sockets, includes mounting brackets
large collection of mil-spec ceramic standoffs. Probably worth a fortune, if you compare prices at Mouser for these
( 8 ) noval ceramic PCB sockets, cylinder type
( 4 ) atmel atttiny24 microcontrollers
( 1 ) CS8414-CS
lot of knobs
( 4 ) 7pin sockets, NOS
lot of jacks
lot of Neutrik powercon and speakercon connectors
lot of spade connectors
four RCA connectors, dialectric looks like Teflon, but no guarantees as I'm not positive where I picked these up to verify this
lot of switches
lot of power entry modules
two chassis mount relays
found a bunch of parts for the microphone preamp boards, also the boards are still available
( 2 ) TDA1541A matching numbers
( 1 ) SM5842APT
( 2 ) Li-ion cells
illuminated panel mount ammeter
lot of teflon tubing
Goertz Alpha-Core M1-2 10ga flat ribbon speaker cable, comprised of two 0.750" W x 0.010" thick polyester terepthlate insulated copper ribbons, 2.2mΩ, 0.95nF, 6nH per foot
Solid silver wire
Acrotec: 99.99997% (6N) purity stress free copper wire from Nippon Mining, Japan *40μ (4.2Ω/ft.) copper wire with polyester varnish insulation. Excellent wire available for rewiring tonearms or any application given a sufficient number of paralleled strands. For most tonearms parallel about 15 ccw wound strands of this 46ga wire, or use fewer for ultra delicate applications,
Edited by luvdunhill
