March 22, 20224 yr comment_878444 Added a NPN, a trimmer and some resistor. With those it should be possible to set current through output transistors. Well, that’s the idea. If it works I probably let you know… Report
March 22, 20224 yr comment_878453 What could possibly go wrong ? Seriously; great idea though! Things could potentially get toasty on a 2U heatsink, so being able to choose current would be welcome flexibility. Report
March 23, 20224 yr comment_878508 Just want to add that the bias control is not my invention. You find similar on Uberamp and AMB’s beta22. My view on Copyright is - my right, as DIY:er, to “copy and paste” as I wish. Edited March 23, 20224 yr by JoaMat Report
March 24, 20224 yr comment_878607 On 3/21/2022 at 1:42 PM, JoaMat said: So here is my first attempt Hi, JoaMat! Very nice PCB routing concept. Something similar: Let's go ahead, it's time to provide DIYers with the next features: 1. A simple swapping JFET/BJT input stage on the mezzonine with standartized fitting place/connector. 2. Really smaller dimensions with easier through-pcb-screwing. 3. Integrated onboard fitting connector for corresponding voltage regulator. 4. Check transistors availability and, of course, create different versions of the output stage, one for TO-126, other for TO-220 devices and maybe one for TO-3P/TO-247/TO-264. 5. Since you have provided bias control it's time to make output stage 2-stage emitter follower, vertical mosfet source follower or lateral mosfet source follower for those who want to experiment. 6. Input JFET transistors have cascodes, so aren't we ready to provide cascodes for VAS devices? 7. VAS devices on the main heatsink and also an option of the TO-126/220 cases. 8. Really higher dedicated IPS/VAS supply rails, up to +-150 volts. 9. An option to use modern low-ESR solid polymer capacitors for the power stage. 10. Dedicated input stage before volume regulator for common mode error rejection. 11. Second order integration filter for output nulling. So, the concept. Mezzonine construction. One PCB for JFET/BJT input stage and corresponding cascode devices, second PCB for one OPS shoulder and third PCB for the voltage regulator. All for as-LEGO-construction as possible. Edited March 24, 20224 yr by Bespav Report
March 30, 20224 yr comment_879031 Interesting ideas, wish list, for future Dynahi, Bespav. Here is a new amp board. Initial tests have been successful. The bias control seems to work. Heat sink is Modushop 80mm x 200mm. Report
April 1, 20224 yr comment_879182 Joamat's build reminded me of some problems with balance and setoff on my own Dynahi. I adjusted the amp a couple a months ago, a bit tricky with DC fluctuating, but got numbers down to 3-15 mV with servo in, depending on volume pot position. However, with headphones connected, DC between hot and cold is 50-80 mV. Anyone got theories why this is? Report
April 1, 20224 yr comment_879208 Here is picture of the amplifier in work. Mono version. AMB sigma 22 PSU. It has four trimmers. Lower middle controls the offset. Middle upper controls the balance. The two outer controls respectively channels bias. Input stage current source/sink approximately 1.7 mA. Output bias 35 mA. Setup procedure I used: • Let heats sink get warmed up to working temperature • Trim offset to zero • Trim balance to zero • Set desired bias of both channels to desired bias Redo previous procedures if needed. I find the setup easily done. Report
April 19, 20224 yr comment_881114 ...and now a stereo version. Bias 75mA, 125 degrees F at heat sinks and AMB sigma PSU is working hard. Might need better chassis. Edited April 19, 20224 yr by JoaMat Report
April 21, 20224 yr comment_881327 Milled a front panel, with inscription, today. With black painted aluminum net as top cover you can see the light from eight red LEDs. Edited April 21, 20224 yr by JoaMat Report
May 27, 20224 yr comment_884651 Hello! I could get now DynaMight 4pcs boards version 2004. Does anybody know is there any difference for balance amplifier between: DynaMight and Susy Dynahi v 1.43? Edited May 27, 20224 yr by bbest Report
October 17, 20224 yr comment_895759 A slightly reworked “Dynahi smd” board. Balance and offset trimmers removed. Now servo on each side that bring the offsets to ground potential. Bias trimmers moved to north for easier accessibility “in flight”. This is a "solder and play" board. No set up procedures required, except to turn bias trimmers to desired bias. At least that’s the idea. Report
October 21, 20224 yr comment_896014 Is that a stereo board? I'm trying to wrap my head around how to heatsink it properly. Report
October 21, 20224 yr comment_896027 You have to think Joachim style, i.e., smd-small and vertical . I believe the board is stereo and it mounts flat (vertical if seen from above) to a 2U heatsink. In the pic four posts above you can see how the previous edition boards are mounted through the grille. Edited October 21, 20224 yr by MLA Report
October 21, 20224 yr comment_896040 It’s a balanced board. Inputs in center. Outputs at far right and far left. Positive rail at top edge and negative rail at bottom. Dynahi boards mounted to 80 mm x 300 mm heat sinks. Here I’ve removed upper screws holding front and back plates to heat sinks and then “unfolded” for maintenance. To make it possible to unfold the wires are made “to long” when folded and then it looks like a snake nest. This is an Only DIY version, not to be sold... I hope this makes it a bit clearer. Report
March 10, 20233 yr comment_907897 Received my j74/k170 from punkydawgs the other day. He even included some metal cans to thermocouple the packages. Installed in my Dynahi today (left channel shown) and did some bias checks. All look good. The difference between left and right is just a bit perceptible I’ll fabricate some adapter board with protoboard if feasible so I can heatshrink the packages back to back. If can’t I’ll just use the included metal cans with some thermal paste. Report
March 10, 20233 yr comment_907901 Just found these k849/j689 adapter boards with incompatible traces from last time's group buy. I could probably adjust these instead to make them pin compatible with back to back J74/k170 Report
March 10, 20233 yr comment_907904 Is the Dynahi setup with 14 pin DIP sockets for the input devices (ie, THAT340)? If so, you can just plug the JFETs into the DIP sockets (assuming you use good machine pin DIP sockets). No adapter required. Edited March 10, 20233 yr by Pars Report
March 10, 20233 yr comment_907917 3 hours ago, Pars said: Is the Dynahi setup with 14 pin DIP sockets for the input devices (ie, THAT340)? If so, you can just plug the JFETs into the DIP sockets (assuming you use good machine pin DIP sockets). No adapter required. Yup, I'm using Mill Max sockets for the THAT340 so swapping them out was quick. I was thinking about coupling them together so each pairs will be same temperature. Left it on for a while and touched the jfets but it seems they stayed cool. Is their current draw way lower than what we would find in speaker amps? Report
March 11, 20233 yr comment_908027 After replacing the input devices with K170/J74 I'm still hearing noise from the single ended out (with sensitive headphones). It sounds sort of like a frying sound that comes and goes. I probed the amp with my USB scope. The signal from FET devices and the first transistor is very clean (Q4, Q5). I found the noise came from the transistor pairs before the power transistors. Not sure what causes this. Is it because they're not closely matched? Is it dirty power? Edited March 11, 20233 yr by penmarker Report
March 11, 20233 yr comment_908060 Since you're using a GRLV, dirty power would be unlikely I think. I would replace those transistors for starters. Mpsa06/56 are in stock at least at Mouser. Report
March 13, 20233 yr comment_908232 On 3/12/2023 at 3:27 AM, MLA said: Since you're using a GRLV, dirty power would be unlikely I think. I would replace those transistors for starters. Mpsa06/56 are in stock at least at Mouser. Thanks. I’m currently using MPSW parts from eBay. My assumption is they’re genuine but it’s been years ago so I can’t check anymore. Bought as a lot for 06 and another lot for 56. I matched them by HFE with a diy transistor tester. Report
March 13, 20233 yr comment_908241 They are probably genuine if it was long ago, but may not necessarily have been new/unused. Anyway, replacing those and seeing if you get a clean signal could be an easy first check. Where do you connect to ground for the SE output? Needs to be from signal ground if I remember correctly; Kevin had some very clear instructions on that early in the thread. Edited March 13, 20233 yr by MLA Report
March 15, 20233 yr comment_908392 The ground for SE output goes to one of the output ground. All the grounds on the board are on the same plane. For SE in you'll need to tie the L- and R- to their respective grounds. Report
March 15, 20233 yr comment_908433 On 7/6/2015 at 12:08 PM, kevin gilmore said: for signal input, unbalanced you put hot to amplifier input + you put ground to signal ground and input - for output you wire hot to amplifier out + and you wire ground to signal ground anything else, and bad things happen Report
March 15, 20233 yr comment_908442 I know Amb recommended that for the SE out, the - goes back to the PSU ground, not the amp board grounds. That is the way I always do it, and never had problems. They are of course at the same potential as the amp board ground is, but gets any noise further away from the amp boards, at least that was his rationale for doing it that way. Report
