i'm on a roll... the kgsshv
#1
Posted 20 May 2010 - 05:21 PM
This is the latest.
http://gilmore.chem.....edu/kgsshv.jpg
Its the high voltage version of the kgss with higher voltage pnp transistors, a cascode current
source for the 3rd stage, the lsk389 part (or singles) and much higher voltage output transistors.
The result is something that runs on +/-500 volt power supplies, and is as close as i know how
to do to the T2. (except fully solid state, and easy to build)
The transistors that go on the heatsinks are already insulated, which makes that part easy.
Not a lot more money than an exstata, and much better sound.
So do i make it a single box, Do i make it a two box affair with the power supply in a seperate
box... What are people interested in??
#2
Posted 20 May 2010 - 05:41 PM
Duke of Anhedonia.
#3
Posted 20 May 2010 - 05:42 PM
#4
Posted 20 May 2010 - 05:43 PM
I have G.A.S.
Gear Acquisition Syndrome
Help me
Dirty Laundry Will Out. Behold the dirty laundry.
I remain,
:-Peter, aka :-Dusty :-Chalk
#5
Posted 20 May 2010 - 05:46 PM
#6
Posted 20 May 2010 - 05:49 PM
Amps: SP Extreme Platinum/PSU, Headamp KGBH SE, LaRocco PRI, Headamp pico slim
Sources: Exemplar Denon 2900, APL Phillips SACD 1000, ipod classic, Denon DCP-100
Speakers: Cain & Cain Abbys with Bailey sub
#7
Posted 20 May 2010 - 05:51 PM
1 killovolt flying around with enough energy storage to kill.
Sort of like the BHSE prototype i have, only much more dangerous.
I'm not going to even supply pictures because i do not want to encourage
this kind of behaviour.
The company supplying insurance for the meet would probably go non-linear.
Overengineered? I would never do such a thing.
Headphone amps are supposed to weigh at least 50 lbs right?
Edited by kevin gilmore, 20 May 2010 - 05:55 PM.
#8
Posted 20 May 2010 - 05:55 PM
And couldn't you rewire it (I.E. add resistors in crucial places) so that it travels effectively discharged, and then take the resistors out when you get there?
I have G.A.S.
Help me
I remain,
#9
Posted 20 May 2010 - 06:00 PM
Having the heatsinks on either side is a neat idea and would look great with the amp placed on a single shelf instead of being stacked.
#10
Posted 20 May 2010 - 08:41 PM
My half finished kgss is having serious confidence issues...
#11
Posted 20 May 2010 - 08:51 PM
http://gilmore.chem....u/kgsshvamp.jpg
board is 11.0 x 6.975 inches designed to fit in a box 11.2 x 7.0 inches inside with
.25 thick front and rear panels.
i have the dact in there as the pot because the rk50 would cost more than the rest
of it combined.
power supply hopefully the same exact size.
What other pot should i add...
I have actually cleaned up the house a serious amount...
All i have left is 30 of the heatsinks. Soon i will be taking those to
work. All the T2 chassis parts will be packaged and leave from work.
So no more 600+ lbs of aluminum stashed everywhere.
You can swap out the parts on your KGSS to turn it into the high voltage version.
You can leave the resistors at the top of the 3rd stage, or build the current sources
on addin boards... The original kgss design is TEN years old... maybe a bit more.
Edited by kevin gilmore, 20 May 2010 - 08:55 PM.
#12
Posted 20 May 2010 - 09:09 PM
Wow, he's gone plaid
fail goes in, fail*gain comes out!
#13
Posted 20 May 2010 - 09:50 PM
Because this thing is going to be less than 12 inches, standard heatsinks should be available, and without
all the extra machining...
#14
Posted 20 May 2010 - 11:38 PM
So I could build one of these with the set of boards from Justin I have on order?
"If you have a woody what the heck are 'ya doin' listening to music?
" -- Augsburger
#15
Posted 21 May 2010 - 01:25 AM
Output impedance to fine tune impedance matching?What other pot should i add...
I have G.A.S.
Help me
I remain,
#16
Posted 21 May 2010 - 07:56 AM
In fact that is exactly what my prototype is. Power supply is obviously different.
The pot i was talking about was the input pot. Something that is available. Like the rk25, or some such, because
evidently the rk50 is soon to be discontinued.
Starting on the schematic now.
#17
Posted 21 May 2010 - 08:23 AM
Certified DIY Junkie -Specializing in cutting round holes in metal plates since 2004...
First Law of Physics: A spatula will not fly a straight trajectory if hurled by an angry oral hygienist.
#18
Posted 21 May 2010 - 09:53 AM
http://gilmore.chem.....edu/kgsshv.pdf
The boards definitely will fit together in one chassis
http://gilmore.chem....du/kgsshvps.jpg
depending on the thickness of the transformer which will mount to the back panel
i'm pretty sure that if you do it as one box, it sends up 14 across by 11 deep with
1 inch between the 2 boards.
I might have to make it a bit longer to accomidate the transformer.
#19
Posted 21 May 2010 - 10:01 AM
Edited by spritzer, 21 May 2010 - 10:08 AM.
#20
Posted 21 May 2010 - 10:06 AM
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
