The Multi Amp aka Dynalo Mk2
  • Replies 1.6k
  • Views 509.8k
  • johnwmclean
    johnwmclean
actually the golden reference regulator does perform slightly better
than the krell supply with a couple of changes.
(lt1021 and dn2540 replacing fet and lm336)
krell supply is about 2 microvolts of noise at 500ma, the
golden reference is 90 nanovolts of noise at 500ma.
if people want, I can turn the krell supply into the golden reference, but
still with the on board heatsinks.
definitely will cost a fair bit more than the Chinese version.
I'm sure we can make a smaller board but having heatsinks on the board would be nice.  :)
the original and the boards i'm getting from birgir soon have one land missing
from the 4.7uf cap to the right of the input connector.  Jumper the ground
line to the electrolytic next to it.
board files updated.
after i verify the surface mount boards work, i will have 2 sets of extra boards
if people want them, also one set of boards with the mpsw parts.
PM sent; I'll go for the two SMD boards  ::)
Looks like you changed the kgdynalobal5 boards, the originals with MPSW parts, which have been used in quite a few builds with no apparent problems. What does this change affect (and how did you notice the missing lead)?
yep i fixed it. one of the caps was not working because the ground was not hooked up.
highly unlikely that anyone would know, but easy to fix.
everyone with those boards should add the jumper.
how I found it was I was working on adding more area to the heatsink on the surface mount board
and saw that the pin was not connected.
what I could do now is add some ground plane on the back of that board like I have done for the
others. lower impedance ground means even less noise
Wow, it's almost invisible to the eye, but checks easy with the DMM. I thought someone had swapped my obecalp prescription....now I know what was going on. :)
didn't notice at all ,  almost invisible
now patching 8)
if helps to have a bigass monitor. (32 inch, 2.5k)
but its no longer enough, i need a 4k monitor thats about 40 inches
for my desk. 60hz and the video card that goes with it.
any suggestions?
when you drop stats like that it sounds like you're in the market for an hdtv
I was recently looking at the Asus PQ321Q, but I couldn't realistically afford it unless I sold both my kidneys
I think something along the lines of a 960/970 would be enough to drive it, as long as you don't have any special requirements for CAD, etc.
Like what board? Can you give a link please? I far as I have seen from repository, all KG dynamic amps have only top copper ground plane at best. Which one already enjoys bottom ground plane?
latest posted kgdynalobal5,kgdynalobal7,ksa5pssmall,goldenreference
have ground planes on both sides. the first 2 were updated today.
kgsshvpssic also has ground planes on both sides.
2 of birgir's latest boards have the same thing.
all the above now have teadrops making the holes more reliable.
grass does not grow under the feet of the stax mafia
as you get older you need a bigger monitor.
so getting a uhd display that is 28 inches from my current
32 inches is clearly the wrong direction.
same thing with horsepower
Thanks, I see now. Offtopic: any plans to update dynahibal8, dynahibal9, ssdynahibalsmt and the like as well?
version 8 are the boards i am getting next week. no reason to update that.
version 9 has a bit more heatsink on the outputs, otherwise identical.
will do the dynahi soon
any suggestions?
I am planning to get a Philips BDM4065UC
4K@60hz VA Panel looks decent
so there were problems with the golden reference board, plus I added another stage
to bring the noise down to 1.2 nanovolts peak to peak. (the 120hz is now at the rest of the noise....)
PLEASE CHECK THIS!  before I make boards that I have to throw out.
http://gilmore.chem.northwestern.edu/goldenreference.pdf
http://gilmore.chem.northwestern.edu/goldenreferenceboard.pdf
http://gilmore.chem.northwestern.edu/goldenreference.jpg
The 47uf caps are tantalum but the lead spacing is right
any suggestions?
how about dell u3415w
that is too small.
40 inch seems about right. the Phillips sure is close.
would like an oled, but that is probably not going to
happen in smaller sizes.
When things are changing so fast, it's hard to follow the story.
So, Goldreference is the updated and improved KSA5 PS board, right? This one:
http://gilmore.chem.northwestern.edu/boards/ksa5psg.zip
And it also must be compatible with KSA5 clone, Susy dynahi.
Seems complicated (no no, not a drawback). Curious how is it compared with Sigma22? Maybe worth to try it with Beta.
On silkscreen, 2000 Ohm resistors marking near DC output are upside down...
What should be changed to push it to +-24V? +-30V?
there are 4 different designs now for the ksa5.
the first power supply is the double zener thing.
the second one is the alternate ksa5 power supply which is fully regulated.
the third one is a shrunk version of the second one.
the 4th one is the goldenreference board.
the goldenreference is a different although similar design.
about a factor of 100 less noise. my version of the Chinese thing
has an extra current source in the front end, more current delivery due
to darlington output, and way better and more accurate reference.
and current sources that are very stable (none of that e series crap)
to change for higher voltages, you change the lower feedback resistors
and the power transformer. R7 and R10
and I know the protection diodes are missing from the schematic.
2000 labels fixed in the zip file
going to be way more stable than sigma22 and bunches less noise.
its good for 500ma, maybe more. will have to test.
so for dynahi, you need 2
otherwise you need one, and it works at any voltage 15,20,22,24,30
if you really want it to do 12v then you have to change the reference to 5v
and technically you might want to adjust the zener D4,D6 to be roughly
half of the desired output voltage.
as shown its 20v for the ssdynalo
i could do an off board version with flying output transistors,
then on big heatsinks, as much power as the transformer can supply
Aaa want!
Seems that I will add 1 more PS case with goldenreference.
It will be 5 case setup: balanced beta22, Susy dynahi, Krell clone, Sigma22 PS, Goldenreference PS.
All amps will include full setup of AMB delta1/delta2 with screen and motorized pot. PS cases will include Sigma11 for 5VDC as well, 2 transformers and Crydom/Tyco SSR.
I've buit maybe 15 Betas already, this one will be most complicated and for myself.
