The Multi Amp aka Dynalo Mk2
thanks...
Hammond mfg will cut the 1455T2202 to length with a minimum of 25 pieces.  I was thinking of going that route but don't want 25.  The case pars found is nice as well.  I'm in for either one
  • Replies 1.6k
  • Views 535k
  • johnwmclean
    johnwmclean
On 10/25/2016 at 3:56 AM, Pars said:
I sent an email to Context Engineering regarding their 6008H-8.5N case (8.5" long) and whether they could cut them to 6.8" (or 6.840") for this application.
I have not followed up with them yet.
I asked last week about their desktop enclosure and got a quote. Although the split body seems like a better idea.
The dimensions might not be totally correct but the price should still be valid. I requested quotes for no cutouts as well as 6 holes in front and 5 holes in the rear. I asked for quantities up to 100 but there isn't much difference between 50 and 100 so I'll just go up to 50.
P/N & Description: 175DT desktop enclosure 5”W x 6.8”D x 1.720”H, 6 part enclosure, screws included, no cutout, no markings
Qty: 1          Price: $213.30 each set          Finish: natural aluminum (no finish)
Qty: 1          Price: $333.30 each set          Finish: black anodize
Qty: 5          Price: $85.90 each set           Finish: natural aluminum (no finish)
Qty: 5          Price: $117.90 each set          Finish: black anodize
Qty: 10         Price: $66.80 each set          Finish: natural aluminum (no finish)
Qty: 10         Price: $98.80 each set          Finish: black anodize
Qty: 25         Price: $54.30 each set          Finish: natural aluminum (no finish)
Qty: 25         Price: $85.50 each set          Finish: black anodize
Qty: 50         Price: $44.70 each set          Finish: natural aluminum (no finish)
Qty: 50         Price: $73.50 each set          Finish: black anodize
P/N & Description: 175DT desktop enclosure 5”W x 6.8”D x 1.720”H, 6 part enclosure, screws included, with cutouts, no markings
Qty: 1          Price: $261.30 each set          Finish: natural aluminum (no finish)
Qty: 1          Price: $381.30 each set          Finish: black anodize
Qty: 5          Price: $95.90 each set           Finish: natural aluminum (no finish)
Qty: 5          Price: $127.90 each set         Finish: black anodize
Qty: 10         Price: $76.80 each set          Finish: natural aluminum (no finish)
Qty: 10         Price: $108.80 each set        Finish: black anodize
Qty: 25         Price: $64.00 each set          Finish: natural aluminum (no finish)
Qty: 25         Price: $95.20 each set          Finish: black anodize
Qty: 50         Price: $53.70 each set          Finish: natural aluminum (no finish)
Qty: 50         Price: $82.50 each set          Finish: black anodize
I did a small update on the mini board to add a pad on the opposite side of the on board regulators.
Here's and updated view...
I have no problem running it
What is the max power this can do? Either the mini or the regular one.
I read in the thread that it can push 2.5W into 50 ohms class-A. Can you push it further into class-AB or is this purely class-A?
About SS Dynalo Mini, after adjust properly then soldering servo opamp?
I wouldn't solder it in, but I use good sockets. Your call however.
  • 4 weeks later...
On aliexpress there is a vendor (breeze audio) who can do a customized chassis, but you need to order a minimum of 30 pieces.
Does anyone have a BOM for the transportable version going? I'm trying to place an order to intercept the board arrival.
On a side note I like the switching supplies only costing ~11 a pop
Had difficulty finding the schematic for the mini in the usual place, is it posted? Trying to figure out how to configure the jumpers on the regulator given the IPM-15-24, choose the right output bias resistors (in the 255 spot) for a given jumper setting, and the AOT thingy.  :)
3 minutes ago, kevin gilmore said:
No schematic for the power supply that Kerry did. Unless he has it.
Ok, thanks!
Here are the schematics:
I've got to look up the settings again for the positive rail. I'm running out in a bit so may need to do it later.
EDIT:  Ok so the silk screen should read 14.2V before you start bridging the jumpers.  You should bridge 3P2V, 1P6V, 0P8V, 0P2V for a 20V output.
Also, updated schematics to make them higher resolution.
Edited by Kerry
In going through the BOMs I noticed R53 listed as 160K and on the PS schematic and silkscreen on the negative sense line labeled as 1.43M.
I'll list more as I find them.
Edited by GrindingThud
Also R1 and R3 should go to to 424 ohms.  I also want to double check the LEDs in the bom as well.  I can look at that when I get home later.
