March 27, 200719 yr comment_28222 I payed for upgrades to my amp in mid-december, but I still don't have it. I called last week and supposedly it's done, but I still haven't recieved shipping info as promised. What the hell do I have to do to get my amp? Report
March 27, 200719 yr comment_28228 Call? Nag? Hey, it could be worse -- it could be McAlister that you're dealing with. Report
March 27, 200719 yr comment_28233 Maybe i should get into the business of upgrading/repairing singlepower and mcalister stuff. Sounds like a full time job to me A complete rebuild of jason's amp (same exact design, built correctly) is about $500 in parts plus about 30 hours of labor. At my labor rates that would be about $5750. Special discount for jason only.... $3000 Maybe mikhail might want to do that design in a dual box setup. Got to be >$9000 ..... Report
March 27, 200719 yr comment_28237 Maybe i should get into the business of upgrading/repairing singlepower and mcalister stuff. Sounds like a full time job to me A complete rebuild of jason's amp (same exact design, built correctly) is about $500 in parts plus about 30 hours of labor. At my labor rates that would be about $5750. Special discount for jason only.... $3000 Maybe mikhail might want to do that design in a dual box setup. Got to be >$9000 ..... Oh snap? I might need get some of your advice later. Haha, hopefully that won't cost too much. Report
March 28, 200719 yr comment_28248 I'm joking of course except i'm not really joking. Duplicating jason's unit with point to point wiring done woo audio style would be god awful amounts of labor, and therefore out of line expense wise. So the thing i would really do is do a complete circuit board layout. All of the parts one one board of about 10 x 15 inches. With a group buy of boards something this size would likely be about $75 each. It would probably take me less time to layout the board, than to actually build one. A lot less time. Might even make it 2 dual mono boards, so you could build the thing as unbalanced only. Then just about anyone could stuff the parts and build the thing. Do it right with a real chassis, or a complete abortion like that wood thing that jason built. You could build it ray samuels style (tubes on one side, all the parts on the other) or justin wilson style (all the parts on one side of the board) Hell i can even layout the board singlepower style with all the tubes at 45 degree angles. For the record regardless of what has been previously said about jason's unit, there is absolutely nothing new in the design that has not been done hundreds of times before. Nothing new, nothing proprietary nothing out of the ordinary... Although the tube compliment is a bit unusual. Report
March 28, 200719 yr comment_28251 I'm joking of course except i'm not really joking. Duplicating jason's unit with point to point wiring done woo audio style would be god awful amounts of labor, and therefore out of line expense wise. So the thing i would really do is do a complete circuit board layout. All of the parts one one board of about 10 x 15 inches. With a group buy of boards something this size would likely be about $75 each. It would probably take me less time to layout the board, than to actually build one. A lot less time. Might even make it 2 dual mono boards, so you could build the thing as unbalanced only. Then just about anyone could stuff the parts and build the thing. Do it right with a real chassis, or a complete abortion like that wood thing that jason built. You could build it ray samuels style (tubes on one side, all the parts on the other) or justin wilson style (all the parts on one side of the board) Hell i can even layout the board singlepower style with all the tubes at 45 degree angles. For the record regardless of what has been previously said about jason's unit, there is absolutely nothing new in the design that has not been done hundreds of times before. Nothing new, nothing proprietary nothing out of the ordinary... Although the tube compliment is a bit unusual. We're getting excited. But wait, are you serious about this? Report
March 28, 200719 yr comment_28253 What the hell do I have to do to get my amp? Ask 5687, he seems to get a constant stream of Singlepower gear delivered to his home. Report
March 28, 200719 yr comment_28255 Ask 5687, he seems to get a constant stream of Singlepower gear delivered to his home. He had my SLAM SE over a year. PFKMan23 had has his a couple months before I got mine and my amp was the original. The Supra-Extreme was about nine months. Actually, I probably get my stuff slower than most of you because he knows I have other amps. I got my Extreme first because I had been bugging him for 2.5 years to build a 6as7 amp. When I found out he was actually going to do the 6as7 amp I bought one before the preorder. Report
March 28, 200719 yr comment_28264 We're getting excited. But wait, are you serious about this? You go and convince Jason to let me do this... Then i can probably knock it out in a weekend. Report
March 28, 200719 yr comment_28266 Damn you guys suck, My biggest gripe with my amps is driving out 45 mins to get it done that day and come back home with the amp... My worst probelm was a fuse out once, yeah... Edit:worest=worst Report
March 28, 200719 yr comment_28267 That is a lot to digest... and I really should be working right now. I will be back later to respond in full. I also have some info from Peter regarding the design that I will share to the best of my ability. Report
March 29, 200719 yr comment_28290 For the record regardless of what has been previously said about jason's unit, there is absolutely nothing new in the design that has not been done hundreds of times before. Nothing new, nothing proprietary nothing out of the ordinary... Although the tube compliment is a bit unusual.You are probably right, but that IS a guess... right now anyways. "or a complete abortion like that wood thing that jason built" - Huh? Are you talking about the power supply for my prototype POS amp? The amp was actually on a scrap piece of plexi, get it right! EDIT: Go to the 'Hell hath frozen over' thread for info on what Peter told me. Report
May 8, 200719 yr comment_31123 sorry dude... that's just horrible. Hopefully you'll get it soon.. :'( Report
May 8, 200719 yr comment_31124 I spoke to mikhail about 4 months ago about a custom amp, he told me he'd get me a quote. Though i haven't been holding my breath, that's the last i heard of it. I guess i didn't need it that bad ; ). Report
May 8, 200719 yr comment_31132 I should have one coming in from him sometime soon(ish) as well. Report
May 9, 200719 yr comment_31151 I spoke to mikhail about 4 months ago about a custom amp, he told me he'd get me a quote. Though i haven't been holding my breath, that's the last i heard of it. I guess i didn't need it that bad ; ). You should keep in contact (by phone) on a regular basis. I have a custom power supply which I ordered last August that I'm still waiting on.I tend to give him a ring every week or so.He is conscious of the delays but I think they just have so much work on. Report
May 9, 200719 yr comment_31153 If you don't like single powers service, stop ordering from them damn... Biggie. Report
May 9, 200719 yr comment_31154 If you don't like single powers service, stop ordering from them damn... Biggie. x2 I have nothing against Singlepower, but the only power we have as consumers is the power to not buy. Report
May 9, 200719 yr comment_31155 If you don't like single powers service, stop ordering from them damn... Biggie. Biggie, That's all well and good for new customers but the issue here seems to be people that have already paid for services and are not receiving them in any sort of timely fashion. And it's not just as simple as calling your credit card to cancel your order if you've sent the guy your amp to upgrade. And it doesn't seem like calling for an update really works since all he does is placate you by telling you that it's nearly done and should ship soon. The net result is that he gets to it when he gets to it and that's that. I didn't realize that things had gotten as bad as they appear to have based on recent threads and conversations with folks. Not good... Report
