Closed - Megatron and GRHV PCB GB
With these quotes and potential problems it is almost more beneficial to just get the Antek trafos and ship them to the Netherlands for the premium price. No fancy box to put on top of the case though... (and no 13/14VAC ones, just 15VAC so more heatsinking for the LV supply)
  • Replies 118
  • Views 30.6k
  • Got my boards today. Thank You! I have posted pics before but here are some more of my build. I noticed these boards have a 12 V for the filaments. The old board did not have it.
  • kevin gilmore
    kevin gilmore
    12v filament version posted pretty sure the original was done the way it was to accomodate the 6dj8 tubes for those that wanted to do that edit: the filaments of the output tubes are tied to
  • I have received payment from most. Thanks all for the prompt responses. I will be placing PCBnet amp board order today. The Gerber file used will be the megatron12v.zip with 12.6vac filament for
I'm waiting for two new trafos from Toroidy. If I have problems with it again probably I will try other manufacturers
Enviado desde mi SM-G920F mediante Tapatalk
All packages with US shipping address have been posted to USPS Priority Mail. Please PayPal me $7.2 US for the postage.
Overseas packages will be posted next week. I'll PM each with the postage as it will be based on destination and weight.
All international-destined packages have been sent too. I'll PM each with the postage.
Happy building!
On ‎01‎/‎06‎/‎2017 at 8:42 AM, steefdebruijn said:
I am very curious about your findings. Thanks in advance for any feedback on this.
Measures (no load):
AUDIO GRADE TSA300VA PRI:230V SEC:
> 2x360V & 350mA      386volt/386volt
> 18-0-18V & 600mA   18,63volt/18,63Volt
AUDIO GRADE TSA60VA PRI:230V SEC:
> 2x 6,3V & 4,5A  6.83volt/6,83volt
No noises or hum . The measures are... more or less but I'm worrying for HV (a difference of 26volt)
The difference in voltage is only app. 7%. If you look at other transformer specs you'll see that this is perfectly normal for a 300VA toroidal, so it should be absolutely nothing to worry about :)
//UFN
Thanks for the follow up. Toroidy still a candidate then. Should I run for 13, 14 or 15 VAC secondaries for 12VDC regulated?
Got my Pcb's!!!!
Thanks Michael
  • 11 months later...
This is probably a long shot, does anyone has additional megatron pcb to spare. I am very interested. Thank you.
PM me if you are still interested.
