stax t8000 clone (well sorta)
  • Replies 261
  • Views 91k
  • Now with top plate.     Aerial view, the two holes in front of outer small tubes are for balance trimmers. Adjust balance after some time of warm up and then insert jumpers for the ser
  • kevin gilmore
    kevin gilmore
    using Kerry's servo, but a resistor to make +200 by the way the alternate name of this board will be t8000DR   (DR as in done right) edit: fixed font sizes
  • Look! Top plate, 1.6 mm copper clad single sided. I do think we have copper polish somewhere in the house…
its birgir's birthday today, the big 35!
so...
special security screws on the top, 6 sided ultra miniature metric spline, apple tools work
power conversion relatively easy once you get rid of the goop
Whoa! Looked much more complicated than previous Stax amps.
Looked like regulated heater. Zener string for front end tubes?
Edited by joehpj
2sc6127 for the outputs and the voltage gain stage, resistors, for pull up on the voltage gain stage, darlington output
need better picture of servo, so that one later, stacked ksa1156 for the tube drive, the rest of it is a modern 717 with available parts.
wiring, 100v   J1,J3,J4
120v   J2,J3,J5
Cool, looking forward to the full schematic.  PS looks like 78/79 front end regulation (the two heatsinks) and for the extra slot, but R-C high voltage?
next to the transformer is 7815,7915  which makes +/-15 to the slot and also the servo board
filaments are DC
HV is unregulated Cap,100 ohm resistor,Cap
servo pretty much identical to the T2 servo
the 15k resistors are something else
I have heamhorriods older than that,,,,,,, :rolleyes:.
btw, happy birthday, Birgir...  may the Kæstur hákarl be extra savoury....   :D
Thanks for schematic.
Guess I'll stick to the t8000DR. The servo is interesting though.
power jumper block cleaned of all the epoxy
j1,j3,j4 for 100v remove all others
j2 j3 j5 for 120v remove all others
j5,j6 for 240v remove all others
and servo board pictures, unnecessarily complex
tube rollers are going to have a lot of trouble with this, the servo has a pretty limited range, and the Russian similar's definitely will not work
Kevin: did you even listen to it before you took it apart? :)
I bet Kevin was more eager to strip her up before speaking or listening to her ;).  I appreciate these above findings and pure electrical porno :D
Edited by Whitigir
He shook the thing to see if it rattled.......     :o
I was listening to it while taking pictures...   multitasking
absolutely, don't want any metal nuts floating around in bad places
2 of the screws that hold the bottom plate on have very long screws and nuts, both were loose, and one is almost impossible to get to without taking off the front panel.
i am sorry, suddenly lost all the interests about this when i heard it's only a slightly more powerful tube-fronty 727 without changing the pot
Kevin, function of switch in test position? Resistors in red circles below, have something to do with test?
simplified schematic :D  just updated, I got the current sources flipped.
when put in the test position, it puts fixed resistors to the plates of the tubes to -15
so then you adjust the main offset and differential. then move back to the on position and further adjust the servo pots.
when working right, keeps the outputs to less than 100mv. but range is very tight.
How's the sound compared to your other KG amps, specifically the Carbon?
A few noob questions.
There are some more parts after voltage dropper to get +100V. Is that because the B+ in T8K is unregulated? It seems stax use regulated PS for the tubes.
What's the function of Q19, Q21, Q27, Q30? These seems to first appear in T8K.
Stax used some low-noise parts like KSA992 and KSC1845. And stacked KSA1156. Any chance to adopt them in Tube-carbon/Sandwich or even Carbon?
Feedback is 200K in Carbon and 300K in T8K. So maybe there chance to lower the feedback in Carbon?
Most important is how do you think about the front half of T8K comparing to your design?
For the negative supply for the tubes, I like the way tube-carbon does which doesn't need -15V supply. But I don't know the noise level difference between GRHV and 7915/GRLV.
Thanks.
Edited by joehpj
q19 and q21 are in all stax amps. limits the voltage of that particular section, they never trigger, and I eliminated them a long time ago.
q27 and q30 are used as temperature matched diodes. same as Q8 which is mounted on the heatsink
the 300k resistors result in a voltage gain of 1k (actually a bit more) when combined with r38,r39. carbon does the same thing with lower resistances
they use stacked ksa1156, a pair of 400v parts. I use the stn9360 which is a single 600v part. there is no reason to do this in solid state front end amp because the 100v is 15v
main power supplys are not regulated. and the servo jumps all over the place when the air conditioning kicks in.
Thanks.
Q27 and Q30 have base and collector connected together and so behave like diodes and in series with the LEDs D2 and D3, provide a constant voltage for the constant current sources Q26, Q28 and Q29.
I believe that  Q18-21 form a modified Vbe multiplier - this part of the circuit is not new - the exact same topology is seen in the T1, 600 and 727, among others.
The circuitry around Q31-33 is a voltage regulator to stabilize the voltage to the tubes and intermediate stage.
I'm sure KG will come along and correct me if necessary.
Thanks.  :)  I'm glad my own birthday present from me to me is bringing Kevin joy.  ;)
Kevin has sent me all the pics now and well...I'm just shocked how bad the T8000 is.  Now the circuit is blahhh to say the least and how exactly were Stax working on this for 3 years?  Somebody looked at the stuff they already had three years ago and then remembered it again 6 months ago?  I mean nothing is new here and that even extends to how this is built.  Most of the innovation is just because of necessity while the rest could just have been used in the T1 from 1987.  Seriously, links on a modern pcb with surface mount parts?
