Tweaks that shouldn't work, but do
  • Replies 97
  • Views 20.7k
We can start with billy's penis. Anyone have a tweezers and a magnifying glass
HA HA HA HA....HA
HA HA HA
yeah you made the offer and i was down for it 110% if hf08 was happening in Chi..
if...
if
if
if
get me?
if
if
ok then
........a few resistors shy of a fully populated board me thinks. ::)
Those things are fricken huge (unless than meant inches ", instead of feet ')
Sweet, I just noticed I passed the magic 1500! ;D
woah, I thought they meant inches! but ' usually means feet. I guess I could buy some and stand on them while I'm rocking out.
grats on golden god status! :) DIY is king. :)
I just don't see how any of that vibration isolation stuff could possibly work with non tube gear or gear with no moving parts. Especially to the levels people claim (like how a rack is the biggest single improvement they've ever heard in their system). Though at least some of the stuff has some kind of science behind it, whereas all those wood blocks seem absurd to me.
I know its not exactly the same thing, but I at least started understanding the effect that objects outside a digital source could have on sound when I temporarily had to place my monitor on my CDP. It definitely changed the sound for the worse. So especially with a unit like mine, which does not have a 75lb "audiophile grade" chassis. Plus it do have some tubes in it, werd, stuck right in teh back ther. 2 of em.
But at least that, like, makes sense! There are tubes and moving parts, plus your monitor could have been giving off emi or something.
I have no doubt that that stuff reduces vibration, I just don't see how that will help the sound, especially dramatically. The only reasoning I've heard is something like "microvibrations cause components to resonate, making the impedence change", which I find kind of hard to believe.
Well, think about it -- current induces magnetic fields which are orthogonal to the direction of the current; jiggling current (jiggling is orthogonal to current) causes current in new and wonderful directions (now back to in the same direction as current and/or perpendicular -- it's kind of like measuring turbulence)...hence, noise/hash/distortion.
But the question is, just how much vibration is needed to actually cause noise or distortion? Is it microvibrations in the air, or an earthquake? :P
I would like to try one of those crazy expensive vibration isolator things one day, and see if it works for myself. But til then I'm stuck wondering I guess..
It's not a matter of whether or not, but how much.
Yes, you do.
You've heard about Steve Hoffman's cutting table, haven't you? It actually has a separate foundation. Foundation, as in the concrete floor is physically separate from the rest of the building. That's hardcore.
I have some of those Cardas Myrtle blocks, but I've never really tested them to see if they do anything. I picked 'em up cheap, so I figured worth a shot.
I learned this one from the owner of a local hi-fi store. If you want to play with wood blocks for vibration control, go to a toy store and get a box of Jenga blocks. Keep as many as you need, then sell off the rest on Audiogon or whatever with a description of "like Cardas golden cuboid blocks!!"
  • 2 months later...
the cardas blocks work. i have used them. placed under a power supply, the improvement is quite noticeable.
WThe real question is who's cued up next in the CD player after Feist? >:D
Lang Lang! :o
Yoko Ono
better than jenga blocks?
can someone put jenga block under a PS and see if theres an improvement? ;)
