The Orthodynamic Thread
Anyone believe they have found a trusted online store to get the newer version of the Fostex yet?
  • Replies 929
  • Views 203.8k
  • mypasswordis
    mypasswordis
    So apparently monoprice cloned the Audeze LCD-2 and is selling them for $300 Left is LCD-2 and right is M1060 Released last week and monoprice website says it's out of stock until mid-April
  • kevin gilmore
    kevin gilmore
    got them, the connectors are pieces of crap, one side is intermittent if you shake your head hard, but sound wise pretty comparable to my lcd2 may actually be built a bit better
  • mypasswordis
    mypasswordis
    Yo leeperry, I see you screenshotting my above HC post in your HF FS ad, so I'ma screenshot on HC your screenshot on HF of my above post on HC:
Where would you ortho heads rank the modded T50rp in the ortholand?
T50RP are nice, about at T20v2 level but slightly better in clearity, bass and resolution. In no way do they even come close to good stat level of performance, IMHO, and I like modded YH-1 and YH-100 better. I also like stock T30 better, but comfort is nowhere as good for T30 as it for T50 :( T50s are very comfortable if a bit hot.
Overall T50RP are really nice, easy to drive and comfortable. You will have to modify them to sound their best. If you don't want to go Smeggy on them, you can try my mod to since it's easy and if I can do it anyone can :D
Fostex T50RP Mod
Currently they have O1 pads with epoxy putty build up inside the earspace and a sticky back craft felt liner. You can see the shape of the build up in this piccy. The pads are also filled with memory foam instead of the normal sponge.
All I ended up doing on mine as of right now is line the backs with weatherstrip and have a layer of craft felt over that, with a reflex dot on the back of the driver. The bass is HUGE currently (with a good seal) and the treble is slightly attenuated so all I need to do is damp. I had two weatherstrips on the backs of the T50RPv2 before that and it killed the bass.
I would rank the Fostexen I own to currently be: T40v1 > T50RPv2 > T20v2
The YH-1/HP-1 would be between the T50RP and the T20. The T50RP has more potential.
Electrostats can't really beat the orthos for sheer impact, which the T50RPv2 has in spades.
I heart BSW, I get an .edu discount from them. I'd say more, but this isn't casino.
Hmmm, interesting. Let us find a craps table..... :P
So that's why the "other thread" has been silent.... :)
Ok, for those of you who did not read about it there, if you are still interested in the cashmere felt group by, drop me a note. I'll probably go get it on Saturday.
And, I don't really believe the T50rp are better than the Yamas, smeggy! :P
Heya Ludo, welcome to the madhouse! :D
Heh, the RP is teh awesomez and kicks Yammy butt no matter what Faust and you say ;)
As to the felt situation, I'll have to let you know on Friday if I can order some. It sounds like good stuff.
Been lurking for a while, then had to join to hold up the Yama flag. ;D
Heh, you are a rocker so subtle nuances are lost on you. :P
As for the felt, don't worry I'll send you a piece, it's the least I can do. BTW I can't wait for the YH-1 you modded to arrive, as I think I'll love them.
So...I'm new to this modding stuff -- would I be able to use felt without rehousing the drivers?
Yep, rehousing is a pretty extreme mod that few will venture into because it's a pain in the ass. Most ortho mods are done in the standard housing. I just go nutz on mine because I can :D Ludo here and a few others in this thread are very good at the felting thing and plenty of advice and guidance is on hand should you want it.
Yeah. It's simple take a look at my mode in the pic above, oh well let me re-post it one more time:
Here some pics of the actual phones being modded:
These were from the fist mod without the bluetack/bitumen. If you want to apply bluetack do it to the back of the cup, but don't block the vents. You can use open sell foam instead of cotton or mineral wool. Make sure not to damage the rubber posts as they serve to reduce vibrations/resonances to isolate the baffle from the back of the cup.
The sound will change based on the felt type, foam type and the amount of foam and felt that you use. You can also use a reflex dot, small circle of adhesive paper applied to the back of the driver, to boot HF. I wanted a slightly darker signature so I did not do that to my set, but I tried it and it work really well if you want more HF; the large the dot the more HF you get.
Good luck :D
Cheers ludo, but if I can I'd like to order like everyone else, or I'll sulk ;D
I'll have you know, I've been testing the RP regularly with those tracks of yours.
as to the YH-1, there wasn't much tweaking done to them as you wanted to work your damping magic on them and rewire anyway, however, once you do your thing on them I think they'll be pretty sweet sounding.
I just put a layer of superfelt over the backs of the drivers. Still needs more damping. Maybe I will buy a cut of that cashmere felt.
I listened to a pair of T50rp yesterday, and they really are quite good. Good enough that I ordered a pair when I got home. They had a reflex dot, felt against the vents I think, and a little bit of chassis damping, and were quite bassy, and it went nice and low. I was suspecting that thin craft felt would be about what I want in the way of damping, though we didnt really mess around with it at all. Maybe more. I will see when they arrive.
Hey, so you did end up ordering them!
Yeah, I'm trying to get them to sound like the Lambda(s) in terms of frequency response, so I'm going to damp them harder for more treble, trading off some bass. There's quite a bit of bass to go around anyway, as you know. >:D
Btw, I just had a whole lining of craft felt over the weatherstrip chassis dampening.
Yup, placed an order shortly after I got back from your place. Now to wait for them to arrive. Brought the HP-1 in to work today though. You are right though, there is definitely plenty of room to play around with damping, though they still sound quite good stock. Those drivers sure are little bass monsters.
Woah, it sounds like you've bought a different headphone, the T40RPMkII. Let us know how it sounds, I don't think anyone on HF or HC has heard it before.
