Am I incorrect in thinking that it's just blurring parts of an image instead of so-called refocusing? The sensor on that thing is pretty damn small (typical P&S size, iirc) so DoF would be rather large.
Edited by Salt Peanuts
  • Replies 6.6k
  • Views 1.1m
  • MexicanDragon
    MexicanDragon
    My daughter (almost 12) is on the yearbook staff at her magnet school. Her grade went on a field trip to the Atlanta Aquarium, and she was one of four people allowed to take a camera. I set her up wit
  • Knuckledragger
    Knuckledragger
    I've hardly taken photos in the last however many years, but what I have been doing since I got this shiny M1 Macbook Pro is blowing the dust off my editing skills. July 1, 2006, the first
  • Knuckledragger
    Knuckledragger
    2009 was one of the craziest years of my life, paralleling 1996.  I should do a photo essay on it.  That'd take more time than I have, so here's a Cliff's Notes version. The year started fairly i
i just got the rokinon lens in the mail and the focus confirmation light is going off when the subject is not actually in focus. the rokinon lenses are notorious for being incorrectly calibrated. how does one go about fixing this? or is it something that can be dealt with in the camera? the af micro adjustment only really works on af lenses. would a nikon service center be able to look at the combo and offer a solution? i had issues with the sigma lens back focusing also but it turned out to be the lenses fault. this lens also seems to have an issue with the focus. could something be off with the body?
Nope.
The camera focuses on multiple points at once. Really cool.
What is uncool is that it shoots a ~22mb RAW image, and only puts out 1080x1080pixel jpeg for printing.
Also, only goes to 35mm equivalent on the wide side sad.png Moar wider=moar better.
It looks like the software allows automatic focus stacking - could be really cool.
Which rokinon? I think you said 85F1.4 somewhere, but dont remember.
The little light up dot focus indicator on the consumer cameras is not selective enough for a fast & longish lens.
Put the camera on a tripod and see how far you can turn the focus with the dot lit. Its kind of disheartening.
You can get split image focus screens for digital cameras. Still not really easy, but IME more consistent than the electronic thingy in the consumer cameras.
Edited by nikongod
Focus screen it is. The lens is a 35 1.4 ari. The sigma went back to the seller bc the back focusing issues were absurdly bad.
Edited by crappyjones123
5D Mark III Full Spec List and new grip and flash
Unsurpassed Image Quality
22.3 Megapixel Full Frame CMOS sensor
DiG!C 5+ Image Processor
ISO 100-25600 (expandable to L:50 H1:51200, H2: 102400
Full HD Movie (ISO 100-12800 (H:25600)
High Performance Operation
61-point high-density reticular AF (up to 41 crosstype points)
6.0 fps for high continuous shooting
Intelligent viewfinder with approx. 100% coverage
3.2-type, approx.1.04m dot (3:2 wide) Clear View LCD II
iFCL metering with 63-zone dual-layer sensor
Shutter durability of 150,000 cycles
High end features
Silent & low vibration modes
Dual card slots (CF & SD)
High Dynamic Range (HDR) Mode
Multiple Exposures
Comparative Playback function
Improved durability & water and dust resistance
SPECIFICATIONS
Available Colours – Black
Megapixels – 22MP
Sensor Size – 36 x 24mm
ISO/Sensitivity – 100 – 25600
Autofocus Points – 61 points
Lens Mount – Canon
LCD Size – 3.2″
Liveview – Yes
Viewfinder – Optical TTL
Min Shutter Speed – 30 sec
Max Shutter Speed – 1/8000 sec
Continuous Shooting Speed – 6 fps
Self Timer – 10 sec, 2 sec
Metering – Centre-weighted, Spot, Evaluative, Partial
Video Resolution – Full HD 1080
Memory Type – Compact Flash
Connectivity – USB 2, HDMI, Mic Input, Wireless (optional)
Battery – LP-E6
Battery Type – Lithium-ion
Charger – Includes Li-Ion Charger
File Formats – AVI, RAW, H.264, MOV, MPEG-4
Dimensions – 152 x 116 x 76mm
Box Contents – Battery Pack LP-E6 .. Battery Charger LC-E6 .. AV Cable AVC-DC400ST .. Interface Cable IFC-200U .. Eyecup Eg .. Wide Strap EWEOS5DMKIII .. CR1616 Lithium Battery
I guess they keep the raw video for Cinema EOS and this 5DIII will have very good IQ and DR
As all the other formats listed under file formats are Video, I assumed the Raw listed there was video.
Supposed announcement date is 3/2. Let's all keep our fingers crossed the price is not really $3500 body only..
dup
Edited by Jon L
&*%$! $3500+$629=$4129
And what's this: "the updated AF assist beam is compatible with Canon’s new 61-point High Density Reticular AF" (AF system for 5d mkiii). Doe that mean 580EX II will not be optimal with 5d mkiii or just bunch of marketing voodoo.
^#$#@! Just placed preorder on the body.
^ Congrats!!!
I've read that Canon spent lols of R&D to increase the DR and low light performance on new 1D X and 5D3. I'm sure it's going to be a great camera.
Edit: Sample here and here
Edited by Cankin
The AF assist beam on 580EX II only covers up to 45 AF points. I'm assuming the new flagship flash's AF assist beam will cover all 61 AF points.
^ I wonder why they always show sample images with in camera NR enabled. Supposedly, the new sensor has 2-stop advantage over the one in 5D2.
I would not have thought so looking at those samples. Even with the NR cranked to 11 the grain is still pretty high. I did not immediately notice any of the normal shadow ISO banding in the sample though.
That being said, the color looks great on the samples, but they all seem soft to me. 7D level AA filter?
Anyone find anything about a dedicated Digic 4 for focus control like the 1Dx has?
I don't think there is a dedicated Digic 4 in 5D3. The Digic 4 in 1D X uses the new metering sensor to assist AF, that new 100,000 pixel RGB metering sensor is not on 5D3.
More low light 5D3 sample here
Those look much better than the Canon provided samples.
It's incredible to me the performance they can get these days at ISO 25600, 51200. Also on the DigitalRev video, at the end there's a bunch of iso comparison shots of 5d mkiii vs. 5d mkii, and it looks like 5d mkiii pulls slightly ahead of mkii up to about 3200, but at 6400 and especially 12800 and beyond, mkiii completely kills mkii in iso performance, no comparison. But I presume much of the difference is due to in-camera jpeg processing, and I wonder how RAW comparison would look like.. Probably not as much difference.
5D2 25600 by MrMafoo, on Flickr
5D3 25600 by MrMafoo, on Flickr
Edited by Jon L
It's springtime here. Took some pictures outside my house. Half way through I realized that I had the ISO set at 800. :palm: Oh well. Still not very happy with my pictures but would be happy for any feedback. Also, the wind is driving me crazy when trying to shoot macro.
