July 24, 200916 yr Hey guys, I'm planning on designing some leather Grado pads but I would like to get some suggestions as to whether people would prefer the pads being more bowl shaped or GS1000 pad shaped. Any other suggestions are greatly appreciated. thanks
July 25, 200916 yr Hey guys, I'm planning on designing some leather Grado pads but I would like to get some suggestions as to whether people would prefer the pads being more bowl shaped or GS1000 pad shaped. Any other suggestions are greatly appreciated. thanks From what I've read, most people think bagel pads only sound good on the GS1000, so it probably wouldn't be profitable for you to make them in leather. Personally, I want Grado pads that make them sound like Stax.
July 25, 200916 yr A "bowl" pad whose height was between the Grado bowls and flats (i.e. squished bowls) would definitely have a market as far as I am concerned, especially if it was nice comfy leather.
July 25, 200916 yr I think leather would ruin the sound, to be honest. x2, as anyone who has tried normal pleather pads or done the tape mod can say. The Grado needs that porous foam to sound like they do or they become unbearably bassy and muffled sounding. Grado pads are a difficult proposition unless you're prepared for a lot of prototyping.
July 25, 200916 yr I think leather would ruin the sound, to be honest. Yep, it very well may, but I would be willing to give it a try just for the halibut.
July 25, 200916 yr I would like to see something like C-pads or the bagel pads (but less cavernous). I agree with Dan, leather might not sound that great.
July 25, 200916 yr Leather bagel pads may well sound excellent. i agree with all of the above that a lot of prototyping is in order, though.
July 25, 200916 yr Author Hey guys, Yes, i know a full leather pad will ruin the sound for sure. This is why I have some design ideas that should let air flow while stealing having the feeling of comfy leather on your ears.
July 25, 200916 yr A "bowl" pad whose height was between the Grado bowls and flats (i.e. squished bowls) would definitely have a market as far as I am concerned, especially if it was nice comfy leather. X2. I would like to see a bowl pad in this fashion as well. I would be very interested to see your product if you move forward fatman711. Good luck on the design as well
July 25, 200916 yr Personally, if I were to attempt it I'd go for a loose weave nylon cloth covered foam circum pad with a leather face stitched on. That way you get the feel of leather on your face while keeping the porosity of the foam which should keep the sound reasonably true. That'd be my take anyway.
July 25, 200916 yr Reflective Grado pads are about as bad an idea as messing with the dimensions of electrostatic earpads by even 1mm. Edited July 25, 200916 yr by spritzer
July 25, 200916 yr Good point but then the manufacturer is crap. Cue markl talking about stuffing pads...
July 25, 200916 yr unless they're 1mm from their optimum. Doesn't matter. After adjusting them 1mm, they would be 2mm from optimum. Murphy's Law strikes again.
July 25, 200916 yr Doesn't matter. After adjusting them 1mm, they would be 2mm from optimum. Murphy's Law strikes again. [geekspeak]Nah, just becomes an iterative solution[/geekspeak]
July 26, 200916 yr I'm interested, I can't wear the bowl pads for more than 20 minutes. I would also be interested in R10 and Qualia 010 earpads. They're probably the two most expensive replacement earpads and a third-party option would be great. Qualia pads don't even have any padding inside, they're just pieces of leather made to a shape.
