i'm on a roll... the kgsshv
FYI for those who may still be looking, bdent just received some 2sa1486. No idea how many are in store, or if they are real, but some are coming my way. These little bastards have been hard to get at a reasonable price.
  • Replies 5.4k
  • Views 1.4m
So I'm getting close to the point of turning this thing on but I have some confusion about my grounding scheme. I am doing a two box on board heat sink build with the amp boards in one chassis and the ps in the other. Obviously in the ps chassis I have ac mains earth ground connected to chassis. I then have an umbilical running between the two chassis carrying both power supply ground and chassis ground, and signal ground also enters the amp chassis. What is the best way to tie these grounds together for safety and avoiding hum? I was thinking I would tie the amp chassis ground to the power supply chassis ground (and thus earth ground) and then connect power supply ground to chassis ground through a resistor inside the amplifier chassis. Does this sound like a safe scheme, and also is it then appropriate to keep signal ground isolated from chassis?
I posed the same question about signal ground isolation. I was told to tie the board grounds to the chassis ground
using 1K ohm resistors. My KGSSHV is a single box build. No noise at all be it high or low volume, music playing or not.
Thanks for the response livewire. Just to clarify this means that you did not connect the signal ground?
Sorry for not being more clear.
I did connect the the signal grounds to the chassis.
To expound on the subject, I used XLR balanced signal input jacks on the back panel,
the signal grounds from them were hooked directly to the chassis using short (<2 inch) wires
soldered to a header strip that is bolted to the rear of the chassis. The board grounds are also soldered to
the same header strip (through 1K resistors) in a centralized "star ground" configuration.
FWIW, I believe that multiple ground attachment points to the chassis should be avoided.
That would be inviting possible noise pick up into the system.
One other minor detail, if your chassis is anodized or painted, abraid the ground contact point
for the fastener to ensure a good connection directly to the bare metal.
I also use star washers to give the physical connection "a good bite".
Lastly, I use a nylok aircraft type nut to keep things from ever coming loose. A solid ground connection is what you want.
Edited by livewire
Excellent thanks. The ground scheme was really messing with my head that post was really helpful.
I'm getting very close to finishing up my amp, and I'm working on the wiring. Here is a quick sketch of what I am thinking of doing. Do you guys see any potential problems or have any suggestions with this setup?
I would try and omit the ground between the attenuator board and the amp. The amp should be happy with a true differential input.
I'd add a ground loop breaker between the PSU ground and earth. I use a pair of anti-parallel diodes, but a resistor works too.
would you connect the input ground at the potentiometer to the star ground instead?
If you follow what livewire said you would connect signal ground where you have it whited out. The two ground inputs on the amp boards are tied together so you could potentially be making a loop with the input ground tied at both the star ground and the amp boards.
Yes, but if I were to remove the connection from the the ground connection on the attenuator to the input ground on the amplifer, I would have to connect the ground from the attenuator to the star ground, right?
Edited by ujamerstand
Yes I believe so. This is what I was planning for a ground scheme after livewire's post:
Thanks Marc,
So I'll tie the ground from the attenuator (and hence the input ground) to the chassis ground, instead of the GND point on the amp boards. The PS ground and L/R amp board grounds will all be tied to the star ground. I'll also try placing a pair of anti-parallel diodes between the star ground and the chassis ground. Would something like this work for the diodes?
Edited by Horio
Horio, I took the liberty of using your diagram, modifying to show what I did.
Please dont take this as "only" way, or the "correct" way.
All I know is that it worked for me.
The ground wire with the 1K resistor that leads from the psu pcb to the star chassis ground connection
is soldered directly to an unused ground pad on the psu pcb.
Also the 15 volt grounds on all three boards all tie to their respective screw terminals.
I oversimplified on the drawing - all ground planes on the three boards tie together anyway.
Someone needs to check the layout of the ixys current source parts on both kgsshv amp boards, andy
is having trouble, and i think there may be a problem. I'm moving one of my labs today, so i don't
have much time.
Edit: the board sure looks right, the drain connects to B+.
Only looked at the off board hs layout so far but it matches the schematic as far as I can tell.
The schematic does not match the board on the IXYS current source, but Kevin thinks the board is right. After we fixed the wrong facing transistor, and proceeded to replace all active parts on one board to make sure that was not the problem, there is still something wrong. When we turn the amp on, the voltage is pegged at -940 (probes in O +/-) and the balance pot will not adjust it. If it is left on more than a few seconds, one of the resistors near the balance pot starts to smoke. We are wondering if there is not a problem with the board, but we can't do any searching since we can't leave it on.
Funny thing about the 1486 being backwards, we could adjust the voltages and get them pretty good, but they fluctuated. But when we had it on with the 1486 the wrong way there was almost no heat.
Anyone have the amp boards working with the IXYS part?
What doesn't match? From I can see drain is tied to V+, gate is tied to the 1k resistor and source is tied to the 1.2 k resistor, both of which are then tied to the collector of the sc4686, which is what the schematic shows.
blubliss,
What type of PCBs are you using - with or without onboard heat sinks?
OK.
I´ve the onboard type and started with the ”1968 current source” and after a week I changed to ixys.
Both variants have worked without any problems for me.
But since you have the offboards I guess I won’t be much of help for you.
Are you looking at the layout, which is correct, or the schematic. I don't know how to read this stuff myself, going by someone else's opinion. It's possible we are wrong.
I was going to trying powering up my amp boards tonight, but now you have me nervous Andy. I am also using the IXYS CCS on my build. I am guessing you tested your PS prior to hooking up your amp boards? Could you post some close up photos of your amp boards?
