May 31, 201511 yr Author comment_688073 new power supply, 100ma version angle bracket sicfet pass transistor coming for the higher power applications. Report
May 31, 201511 yr Author comment_688077 http://gilmore.chem.northwestern.edu/kgsshvpssic.jpg good for at least 100ma on each rail with enough heatsink Report
May 31, 201511 yr comment_688090 Now that will be a fun challenge to fit into the same box as two carbon boards. Definitely putting this into the project queue. Report
May 31, 201511 yr Author comment_688102 2 amp boards on one side, the power supply and transformer on the other side Report
May 31, 201511 yr comment_688106 Is this a better PS to use with a KGSSHV Carbon? I was planning using a KGBH/ST version. Report
May 31, 201511 yr comment_688109 I thought the original KGSSHV supply was good to 90ma with 3904s? Offboarding is a welcome addition though Report
June 1, 201511 yr comment_688125 Do the SiC MOSFETs need to be matched at all for either the PSU or the amp boards? Report
June 1, 201511 yr comment_688129 According to Birger, no matching of the SiCs required on the amps. Report
June 1, 201511 yr comment_688140 Maybe a good opportunity to change STTH512FB to STTH512FP, I just googled the first part again Edit: Can the SiC also be jammed into the simpler BHSE supply? Edited June 1, 201511 yr by nopants Report
June 1, 201511 yr Author comment_688177 its a to246, so it would have to be a different heatsink, and a different footprint Report
June 1, 201511 yr comment_688179 oh, I was thinking just leave it offboard and let the user handle sinking. Wondering what the dis/advantages are to the fq* part Report
June 3, 201511 yr comment_688520 @joamat: - why did you change the servo? - do you do your own Stax jacks? ...looks like that from your pic?? Edited June 3, 201511 yr by sorenb Report
June 3, 201511 yr comment_688540 I just realized this, but how are you powering the LV section JoaMat? If you're using your T2 supply, I thought there was only 12V available Report
June 3, 201511 yr comment_688542 I use the T2 PSU sometimes and it has 12V LV section but it seems to work. Edited November 12, 201511 yr by JoaMat Report
June 3, 201511 yr comment_688557 That's good to know, I have some 12V power ones that can get some use Report
June 4, 201511 yr comment_688569 Would it be bad to stack the two carbon amp boards on top of each other (perhaps slightly offset)? That would make it possible to use a smaller case than if they are placed side-by-side. Report
June 4, 201511 yr Author comment_688570 as long as the heatsink is big enough, that should be fine, and put the power supply on the other heatsink. its still going to be a fairly big box Report
June 4, 201511 yr comment_688572 There are a number of case options with a single heatsink, I couldn't really figure out how do the IO for those in a tidy manner Report
June 4, 201511 yr comment_688576 I think that a build will fit in a Modushop Dissipante 2U 300 with stacked amp boards, but didn't actually lay it out to double-check. Not a small box, but not monstrous, either. A fully-custom chassis should allow more space saving. Report
