i'm on a roll... the kgsshv
Was answered I believe Kerry also mentioned to use AC325 for 400V output and AC360 for 450V output.
  • Replies 5.4k
  • Views 1.3m
I went ahead and built the new PS design to make sure it's stable and performs...  :D
Here's a picture of the supply set to 400V (it's just the bottom half of the PCB).
IMAG00241.jpg?psid=1
I've used a few different values, but that shouldn't matter.  I'm seeing about 5mV (RMS) of random noise.  Could probably get that down a bit.  Some of that is coming from my apartment.
Edited by Kerry
wow Kerry your hand work is excellent, sell your proto work to fund more projects
kerry, you need a screen room, all copper
you know you want one.
do the entire apartment and wear an aluminum hat.
kerry changed a few values from the original schematic, changing the labels on the boards now
http://gilmore.chem.northwestern.edu/goldenreferencehvsic.pdf
R1 to 4.7k  (probably a good idea)
D1  12V
R6 to 50k (also probably a good idea)
C7 down to 5pf (and yes it needs to be there)
3.9 ohms for R11  if you want to raise the current limit
powered up my kgsshv, one board is fine while the other has the outputs at +vcc. Where should I start looking?
One other thing is that the +15V on this board powers up slower than the other, will this affect the output DC?
edit: that does seem to the be problem, now it works fine but drifts around quite a bit without the servo. I started listening though so maybe I'll fix this in half a year
I haven't listened to a kgsshv in a while, the soundstage is very wide compared to other amplifiers in the lineup. can also kind of see how more bass a la carbon might be welcome
Edited by nopants
Change the regulator?  That shouldn't happen at all.
it was because I used an excessively long wire to daisy chain 15v from board to board
Ordered some of the Carbon boards from Birgir.Its without cascoded CSS.
Cut those board to a smaller size.
Besides from a PZTA42 that somehow had its own way and apparantly caused a Vishay to go south the amp was up and running without too much hassle.
The Carbon definetly runs hot. The heatsink is ,45K/W - seems ok
The plan is to have the amp on one side and the PSU mounted likewise on the opposit side in a Dissipante 2U/300mm wide.
Looking forward to get the PCBs from MWL168 GB  :laugh:
Big thanks to Kevin & Spritzer.
Edited by sorenb
Nice Soren! How do you get in there if you need to replace a transistor on that heatsink?? Looks quite diffucult..
@Gepardcv: you probably won't be disappointed  :laugh:
@Insanity: Depends on how you see it; a bit solder wick and some flux and off it goes ... not a big deal ...had smoke from the Vishay and had to replace that and the 42 that had its own way for some reason ...anyways its only the C2M that is going to be mounted like that ... the 10m90 will get company from a DN2540 ...just havn't figured out how to do it just yet ...
I finished a mini-stereo KGSSHV build yesterday. It sounds pretty nice!
One problem: when I turn it off with headphones plugged in, there is a pretty loud crackle in the headphones. Not deafening loud, but disconcerting, especially since my KGST doesn't do this. There is no noise on power on. Any idea what might cause this power-down problem?
It's a common issue with the Hv and nothing to worry about.  You can put in larger PSU caps on the LV side which makes this go away.
Any idea why this power down noise doesn't happen on the ixys version of the KGSSHV onboard then? The psu is the same i assume
Sent from my yPat using Tapatalk HD
So I take it that mean there is no need for the v2 amp board option in the group buy.
When you say use one or the other, you mean (1) zero the balance and offset with both servo jumpers pulled, and then (2) try putting back either of the jumpers, but not both, and see what happens?
http://gilmore.chem.northwestern.edu/kgsshvcarbonproductionv5.pdf
so for original servo, adjust the amplifier for an output voltage around zero
then put the jumper in for servo v1.
for the new servo, adjust the amplifier for an output voltage around +20v
then put the jumper in for servo v2
never put both jumpers in at the same time.
I've been putting together a BOM for the Carbon but I'm not finding any 175K resistors that are in stock over at Mouser or Digikey.  Does anyone know of other sources?  There's 174K but will that work?
Edited by chiguy
