October 7, 201015 yr There's a pair turned up just down the road from me, in full working order but the woofers have had the original carbon composite cones replaced with polypropylene. Price good and less than the going rate for a pair of the midrange drivers or tweeters inside them. Internet opinion seems positive all-over. It will be the first piece of audio gear in 2010 I'll buy which will cost more than 3 pints of lager and a packet of peanuts. I need someone here to tell me to do it. So I can diffuse my self-indulgent guilt.
October 7, 201015 yr I <3 vintage Pioneer -- receivers, and I just obtained a pair of HPM-100's to go with my HPM-200's. (Vintage 4.0 surround system, here I come.) Dew et. And yes, ribbons do, indeed, rock.
October 8, 201015 yr Author They're rear ported, so the first picture is a varient, maybe the DSS-10E. Also I know why there was a good price on these now. They are in pieces. Screwing the drivers back in and rewiring them up is simple enough but the secondary crossovers had been torn out of the chassis and are on splintery bits of chipboard. One is fairly intact but that other I had to reassemble a bit. The tweeters and mids are wired in and I'm waiting for the glue to cure on the crossovers before I screw in the woofers. A selection of minor physical flaws on the cabinets but nothing dreadful. I'm also lucky that I had a pile of grub screws the right size as the originals were tossed except for one which was stuck inside a cabinet.
October 8, 201015 yr Author Not gonna bodge the crossovers back in like this, so i'll chisel out all of the splintered chipboard, remount them on a bit of wood and glue them in fresh and sturdy.
October 9, 201015 yr Author See what happens when you listen to us? Indeed. Have some pics. Laying: Drivers: Needs scraping out: Been scraped: Didn't re-mount the bass crossovers this evening. Hopefully finish everything tomo. In case anybody doesn't spot it, the room has been repainted red.
October 9, 201015 yr Drivers look to be in good condition, I am sure you will be able to bring them back to live soon.
October 10, 201015 yr Author I've got some dynamat somewhere, but not enough to line both boxes. I also forgot to take away the interior foam so I'll ring Frank tomo and hope he hung on to it (and the front grilles). Took forever and a day to rebuild the bass crossovers, most of which involved removing the parts from the old chipboard block. Now they're on bits of scrap pine. Haven't glued them in yet in case something goes tits up, but the speakers sound pretty good now that I've hooked them up (last ten minutes). Pots for mid and treble are crackle free. Now I need to knock together some nicer (and taller) stands. Unless I try putting them on my desk...
October 10, 201015 yr Very nice Douglas!!! You can also get bitumen sheets for car sound insulation pretty cheaply and add them to the box wall. Certainly cheaper than Dynamat...
October 15, 201015 yr Very nice Douglas!!! You can also get bitumen sheets for car sound insulation pretty cheaply and add them to the box wall. Certainly cheaper than Dynamat... Also Bituthane sheeting has very similar qualities. You have to buy a large roll, but it's usually cheaper than a tiny amount of Dynamat. It's sold as Ice and Water shield for roofing. The brand I'm familiar with is Grace. Home improvement centers will carry it.
October 15, 201015 yr Author Would bitumen roofing tiles (for summerhouse/shed) do the trick? Got a packet of those in the attic. They've got shingle on one side.
October 15, 201015 yr Beautiful speakers, Douglas! The drivers do, indeed, look to be in wonderful shape. Will be watching for the sound check.
