October 7, 201016 yr comment_393678 There's a pair turned up just down the road from me, in full working order but the woofers have had the original carbon composite cones replaced with polypropylene. Price good and less than the going rate for a pair of the midrange drivers or tweeters inside them. Internet opinion seems positive all-over. It will be the first piece of audio gear in 2010 I'll buy which will cost more than 3 pints of lager and a packet of peanuts. I need someone here to tell me to do it. So I can diffuse my self-indulgent guilt. Report
October 7, 201016 yr comment_393690 I <3 vintage Pioneer -- receivers, and I just obtained a pair of HPM-100's to go with my HPM-200's. (Vintage 4.0 surround system, here I come.) Dew et. And yes, ribbons do, indeed, rock. Report
October 8, 201016 yr comment_393761 Having been bitten by the vintage bug, all I can say is DEW EET!!!! Report
October 8, 201016 yr Author comment_393901 They're rear ported, so the first picture is a varient, maybe the DSS-10E. Also I know why there was a good price on these now. They are in pieces. Screwing the drivers back in and rewiring them up is simple enough but the secondary crossovers had been torn out of the chassis and are on splintery bits of chipboard. One is fairly intact but that other I had to reassemble a bit. The tweeters and mids are wired in and I'm waiting for the glue to cure on the crossovers before I screw in the woofers. A selection of minor physical flaws on the cabinets but nothing dreadful. I'm also lucky that I had a pile of grub screws the right size as the originals were tossed except for one which was stuck inside a cabinet. Report
October 8, 201016 yr Author comment_393932 Not gonna bodge the crossovers back in like this, so i'll chisel out all of the splintered chipboard, remount them on a bit of wood and glue them in fresh and sturdy. Report
October 9, 201016 yr Author comment_393975 See what happens when you listen to us? Indeed. Have some pics. Laying: Drivers: Needs scraping out: Been scraped: Didn't re-mount the bass crossovers this evening. Hopefully finish everything tomo. In case anybody doesn't spot it, the room has been repainted red. Report
October 9, 201016 yr comment_393994 Drivers look to be in good condition, I am sure you will be able to bring them back to live soon. Report
October 9, 201015 yr comment_394079 You could also do some fair bit of tweaking to the box if you are so inclined. Report
October 10, 201015 yr Author comment_394372 I've got some dynamat somewhere, but not enough to line both boxes. I also forgot to take away the interior foam so I'll ring Frank tomo and hope he hung on to it (and the front grilles). Took forever and a day to rebuild the bass crossovers, most of which involved removing the parts from the old chipboard block. Now they're on bits of scrap pine. Haven't glued them in yet in case something goes tits up, but the speakers sound pretty good now that I've hooked them up (last ten minutes). Pots for mid and treble are crackle free. Now I need to knock together some nicer (and taller) stands. Unless I try putting them on my desk... Report
October 10, 201015 yr comment_394373 Very nice Douglas!!! You can also get bitumen sheets for car sound insulation pretty cheaply and add them to the box wall. Certainly cheaper than Dynamat... Report
October 15, 201015 yr comment_395468 Very nice Douglas!!! You can also get bitumen sheets for car sound insulation pretty cheaply and add them to the box wall. Certainly cheaper than Dynamat... Also Bituthane sheeting has very similar qualities. You have to buy a large roll, but it's usually cheaper than a tiny amount of Dynamat. It's sold as Ice and Water shield for roofing. The brand I'm familiar with is Grace. Home improvement centers will carry it. Report
October 15, 201015 yr Author comment_395550 Would bitumen roofing tiles (for summerhouse/shed) do the trick? Got a packet of those in the attic. They've got shingle on one side. Report
October 15, 201015 yr Author comment_395557 Not a big deal. They sound pretty darned good as is. Report
October 15, 201015 yr comment_395558 Beautiful speakers, Douglas! The drivers do, indeed, look to be in wonderful shape. Will be watching for the sound check. Report
