KGSSHV, Balanced Dynahi Rev A and DynaFET board run
Try to contact CMC audio directly for a quote, they might be able to give you a better price than wonderco_buy.
Just sent CMC audio email, let wait and see how much they want the their pins.
  • Replies 448
  • Views 122.7k
  • Cool Package to Deepak seems to be affected by the hurricane... Got stuck in NY for the last 5 or 6 days already Hopefully he won't receive a soaking wet box.
  • Just got my boards. It's a bit startling just how much smaller the Exstata V2 amp boards are compared to the KGSSHV given that they were once identical...
CMC Audio doesn't list the pins on their website but I'm sure they could be bought in bulk. Edit: it's been taken care of. :)
As for the 2SA1968, when the notice came that it was EOL'd some of us bought ample stocks... :P The 10M90 is a fine alternative though but sourcing it outside of the US is a bit of a pain.
Edited by spritzer
So what is the price?
I also asked wonderco_buy what his best whole sale price just in case.
No idea, I was just commenting on that they could probably be bought. Then I saw your post and made the edit.
There are some pretty cheap 3D printing houses out there; it looks like they're limited to Nylon, ABS, and ceramic. Would those materials be suitable for a Stax socket? I ask because most of 3D printing shops make parts on-demand, and would make for one less group-buy to coordinate. Something like this? That was a few minutes spent with Google SketchUp, a ruler, and one of luvdunhill's Stax sockets, so it might not be accurate.
I can't imagine that 3D printing is going to be very cheap, but would like to see prices.
White nylon probably works ok. ABS, probably can't handle the voltage.
I would love a couple of macor ceramic sockets. Those would probably end up $150 to $200 each.
Ok, it's a DIY part, sorry. I will build a kgsshv MYSELF :)
I have not many knowledge of electronic, but I lisened a kgss (not the high voltage version), and it was incredible. Thank you kevin create an amp to have as good and not very expensive.
I will take 1 or 2 set, depending of the price.
The Shapeways prices for the Stax socket I linked vary from $6 to $13 depending on the material. Ceramic is $6.18, black nylon (called "black strong & flexible") is $12.72. Their Materials page describes the exact pricing--for each material, price is either per volume or surface area, there are design rules that need to be met, and there's a minimum price per part. Minimum order is $25, and shipping is free/included. It seems like they're really targeting the low-volume/prototyping markets.
Stay away from anything black, as that is going to conduct high voltage.
I would like to see the price in ceramic of my exact stax jack, this
might be a great way to do this.
Thanks Kevin; good to know. Your exact Stax jack is $9.17 in ceramic at Shapeways. I've never bought anything in ceramic from Shapeways, so I don't know how strong it would be. It might be worth increasing the diameter of the hole from .708" to .75" (or more?)--I'm worried about the ~0.05" of material between the pin and the outer diameter of the plug.
If you pinch every penny, spend wisely paying the lowest possible price for parts,
and not have to pay taxes or shipping costs, you could probably do it for that much.
Originally, my KGSSHV was $800. I went the total econo-route.
This was before buying replacement parts and upgrading the trafo and attenuator,
and installing a soft start circuit. Currently, I have $1100 in it.
@livewire
Your kgsshv is fixed now ?
There seem to be a number of problems with the 3D printing of the
stax jacks. Shrinkage when fired, roundness of the holes, sizes
accuracys... It might take a few tries to get this right.
Not that machining teflon is that easy either, but at least
the holes are the right size and in the right place.
@livewire
This prolly isnt the right thread for this discussion, but yes it is working again.
I highly recommend adding a soft-start circuit to avoid current inrush damage to
the power supply components when powering up the KGSSHV.
Now back to 100 KGSSHV board sets and counting...
Precisely.
I was referring to the inrush hit the trafo, rectifier and filter caps are taking repeatedly.
Something like this should take care of the inrush current.
http://www.mouser.com/ProductDetail/EPCOS/B57153S100M/?qs=sGAEpiMZZMv9eKVyXEc%252bhAZUpToxTU3SjSna2OgFPkw%3d
This is a 2 amp device, probably the 1 amp device works to,
put in series with the primary of the transformer. (110vac)
all transistor mounting holes are the same as the T2, which is .5 inch between holes.
That's exactly what I was going to recommend. Pass recommends the CL60 unit for the Firstwatt amps.
I have a number of 2sa1968LS - these usable?
Hi Lil Knight,
My friends in Thailand ask me to buy some PCB for them. So the new total for me is now 18 sets of KGSSHV, 7 on and 11 off. I would like to have 2 extra psu boards. I've updated the spreadsheet.
Thanks for arranging this GB.
Wachara C.
Yup, that's just the full name.
It would be VERY NICE if everyone calls up Linear Systems and bugs the crap
out of them for lsj109's, or even the singles versions. If enough people
do it, they might actually sell them.
I've put some pressure on them, dont know if they'll budge due to the lowish quantities involved...
What kind of quantities do they consider worth it to bother? 1000? 10,000?
