KGSSHV, Balanced Dynahi Rev A and DynaFET board run
Hi all,
I'm going to do a board run for Dr Gilmore's latest projects (KGSSHV, Dynahi Rev A and DynaFET) so if anyone is interested, please sign up here.
The KGSSHV will be the latest revision. Board set would be 2x amp boards and 1x PSU board. The amp boards are now mounted on side heatsinks.
http://gilmore.chem..../kgsshvps8e.jpg
http://gilmore.chem....gsshvampv7s.jpg
The Balanced Dyhahi Rev A and DynaFET will share the same PSU. One PSU is enough but due to the symmetry, 2 would surely look better biggrin.gif Board set would be 2x amp boards and 1/2x PSU board(s).
http://gilmore.chem....u/dynahibal.jpg
http://gilmore.chem....ynahifetbal.jpg
http://gilmore.chem..../dynapower2.jpg
The boards will be made with the same specs with the T2 boards I did a couple months ago.
Not sure about the price yet but I don't think it would be awfully expensive. Of course, the more the cheaper.
Whenever I have the boards, I'll try to post the BOMs for them.
So if you are interested, please let me know here what you want. I'll send out the order tomorrow for price quote.
Spreadsheet: https://spreadsheets...npReEE&hl=en_US
KGSSHV offboard $29.38
KGSSHV onboard $33.63
Extra KGSSGV PSU board $14.79
Dynahi $39.84
Dynafet $39.84
Schematics:
http://gilmore.chem.northwestern.edu/dynafetschembal.pdf
http://gilmore.chem.northwestern.edu/dynahipowerschem.pdf
http://gilmore.chem.northwestern.edu/dynahiver2a.pdf
Thanks.
Edited by Lil Knight
  • Replies 448
  • Views 124.6k
  • Cool Package to Deepak seems to be affected by the hurricane... Got stuck in NY for the last 5 or 6 days already Hopefully he won't receive a soaking wet box.
  • Just got my boards. It's a bit startling just how much smaller the Exstata V2 amp boards are compared to the KGSSHV given that they were once identical...
I'm definitely in for a set a set of KGSSHV boards as well as a Dynahi board set.
Should you have an option for 1 or 2 PS boards for the Dynas?
Just added a column for the PSU. Mark 1 or 2 and I'll calculate the total basing on how many Dyna sets you need.
Wooot....been waiting for this. Thanks Lil Knight, and of course Dr. Gilmore! :)
Count me in for:
-4 KGSSHV sets
-2 Dynahi sets (4x PSU's)
-1 DynaFET set (2x PSU's)
Kevin, I assume the hole spacing for the various output devices is that of the T2, not the previous spacing of the Dynahi boards (weren't these different?)?
Wow, this is what I call efficiency. :D The boards have been checked over the schematics already, right?
Just to make it crystal clear, the quantities are for number of board "sets" and not individual boards correct?
So if you want to make a KGSSHV amp, you would need to mark yourself down for just (1) KGSSHV. It seems like some people may have accidentally marked themselves down for number of boards needed, and not board sets.
Edited by Horio
The number is for set. 1 for KGSSHV is all the boards needed. The only option is whether you need 1 or 2 PSUs for the Dynas.
Hi Lil Knight,
I would like to have one set of KGSSHV, please. I've updated the spreadsheet.
Wachara C.
I am in for 2 KGSSHV sets
updated spreadsheet
Have these all been checked over by others to make sure there are no errors in the boards?
Edited by deepak
removed myself from Dynahi list
I would guess that these are KG's layouts?
That said, on the previous DynaFET GB, I don't think anyone has gotten theirs working yet, with the exception of KG?
luvdunhill ?
naamanf ?
vvs_75 no
Digipete no
j4cbo ???
Kevin Gilmore think so
looser no?
Pars kinda (no)
Smeggy ?
digger ?
Team Spain no?
Icarium no?
Edited by Pars
Team Spain got one half working (just 1 pair of output FETs afaik) but there's a random high frequency oscillation which is being evaluated :blink:
I need to see if I can find a decent chassis with heat sinks attached.
No T2 board sets up for grabs?
I want a set to squirrel away like a nut. :P
Absolutely brilliant, I was hoping this would happen. Count me in for a KGSSHV set.
I'm in for 2 sets KGSSHV
Thanks for doing this and to all who were involved
Edited by HDen
In for four sets of KGSSHV off board. :D
Edited by wink
In for 2 sets of the KGSSHV, spreadsheet updated :)
Thanks!
