Posts
8,436 -
Joined
Last visited
Days Won
7
Content Type
Profiles
Forums
Events
Everything posted by Pars
I don't doubt that they all get all the data there. SPDIF is not just data however; there is an RF frequency clock riding on that data which is really more of an analog signal as it is not the levels that are of interest but the edges (timing). At 2.8MHz, reflections, etc. become an issue. Really poor interface design, and the whole reason for reclocking schemes, ASRCs, etc., which do jitter reduction and make the DAC less dependent upon the transport timing. And I should have said "One probable reason why I've heard digital cables sound different." since I don't use an external DAC and haven't personally gone thru myriads of digital cables as some I've read seem to do.
Yeah, between that thread and the Valab DAC mod thread (Valab NOS DAC - subjective listening and modifications - Head-Fi: Covering Headphones, Earphones and Portable Audio), plenty of crud on the inside of the monitor (great analogy by the way... my monitor is glad I wasn't drinking coffee when I read it ). I keep getting the visual of jumping the shark in that one, but decided better to just stay out of these types of threads and treat them as a car crash in progress.
That's only 53C, so not that hot. I know TDA1541As habitually run hot.. many develop distortions, lots of time only in one channel, so you will see people putting DIP heatsinks, etc. on them. Never measured temp on them nor read temps anywhere though.
AES/EBU is supposed to be 110 ohm (like SPDIF is supposed to be 75 ohms). An XLR connector is not. The majority of implementations of either are also not properly terminated at the char. impedance. And probably don't use coax or controlled impedance cabling/PCB traces either. It still works, but not optimally. One probable reason why digital cables sound different.
I assume the panel is metal? Aluminum? Steel? You could probably get most if not all of it with something like an xacto knife or the like. Possibly have to carefully drill it out. Or use a ream, again carefully. That jack doesn't look familiar. Was it completely broken apart like that when you opened the amp? That would explain the no resistance. But yeah, the entire jack needs to be replaced.
Oh gawd... Audio Asylum
Like they said. Sorry to hear that Duggeh.
I looked at that. It wasn't that stellar. Nice backpedal BTW!
I don't know what kind of jack this uses, but yes, you should definitely feel resistance as you insert the plug into the jack. On normal Neutrik switched jacks, when the plug is inserted, it lifts contacts off of the switched set of contacts used for preamp or whatever, thereby taking them out of the circuit. The fact that the pre outs still work would indicate that the plug is not disconnecting these. I would think it should be an easy fix.
Seems like they put Terminator in the Friday slot preceding Dollhouse when it was intro'd. Didn't do anything for Terminator (other than ensuring it got cancelled), and almost took out Dollhouse as well. I know Terminator was expensive, but it does suck that it got cancelled, particularly with the other really mediocre shit that is on.
I'm guessing most of the diff you are hearing between the D1 and this is due to the output stage. I wouldn't personally bother with opamps (other than maybe an OPA861 transconductance stage), but would go for a discrete stage. Zapfilter would be the easiest, though probably not the best. If you do decide to go the Burson route, I would probably do one of the Audio Gd ones, as I suspect that they actually make the Bursons, and theirs are more reasonably priced. Note that for I/V duty, a discrete opamp << a discrete zero feedback I/V stage.
Thanks for the wishes all! I had a nice day.
I was still under the impression that few do spdif termination correctly, even now. I would agree that Empirical products aren't what I would call a good value
Yep. Hang in there and things will get better every day. My thoughts are with you and your family as well.
Sorry to hear that. My condolences as well to you and your family.
Cool. Now just renew Sarah Connor, the Unit, uhh... what else? The Shield? Oh sorry, not gonna happen on that one.
Damn, you weren't fucking around when you said you were getting back into DIY! Sweet!
FTFY
Like Jude would say otherwise?
I was trying to think of things I needed from Newark after you posted the coupon. The HLMP-D150 I recognized (dyna something). Neon lamps? Those could be interesting. Didn't realize Newark carried Caddock... will have to see what they have in the TF020 series (IIRC). 25% off those could be tempting
Oh come on, that website was screaming "you know you want to trust us..."
Happy Birthday!
x2 or more. Totally self-absorbed bullshit from my perspective. And useless.
Another product line that might be of interest: THERM-A-GAP 600 Series Gap Fillers I have some tubes of this at work (T644; not sure where they came from and what we used this for, and they are expired).
Apparently the Crystal chips (discontinued) were much better sounding than the PGA23xx series, partially (or mainly) because the PGA series has a built in opamp which is essentially an OPA2132/4. I had a Coda preamp with a PCA2310 (IIRC) in it, and I thought a TKD pot was more transparent.
