Posts
10,564 -
Joined
Last visited
Days Won
6
Content Type
Profiles
Forums
Events
Everything posted by Torpedo
Andras Schiff - Beethoven Piano Sonatas Vol.2
How the hell can they fit the Wifi Tx/Rx into the card? Unbelievable the things they invent
JJ - No 2
I've owned two Canon Ixus (in USA are the "digital Elph") and have been very pleased with them. Somthing like this would fit your needs quite well. They're very portable and resistant, take decent pics... Another great option, albeit a bit above your target budget, are the Panasonic Lumix DMC-ZS3S. They use Leica lenses and take great pics, better than Canon's IMHO. A friend of mine owns one of these and is very pleased. His other camera is a "big" Canon EOS, can't recall the model, and when he needs portability he takes the Panasonic without much regret I suppose the photo experts in here will give you much better advice
St Vincent - Actor
Volcano Choir - Unmap
My condolences Pars. Loosing a friend for so many years is a very sad thing.
SACD -- Is it worth it in a headphone rig?
Torpedo replied to The Monkey's topic in Home Source Components
I quite agree with John. I've listened -while not in my own system all of them- to a few "good enough" SACD players, and never was impressed, there was always some faked feeling which kept me away from getting into the format. I'm afraid the future, like it or not, is in PC audio, downloads, streaming and all that, so a DAC which is capable to take maximum profit from such source would be my choice. SACD is a dead horse, as much as DVD-A, Dual Disc, minidisc and probably RBCD will be soon. -
x2 while I agree with Tony that it requires some amp-matching to make it sounding a bit enticing. With many amps it's not a fun can at all. It also depends on the music you listen. I enjoy it much more with classical and jazz than with anything else.
IMHO the HD600 are the best dynamic phones under $300. Well balanced, resolving enough... not many flaws to criticize. However coming from true high end phones, one can be missing a few things. I like them better than the HD650, I find these boomy too
Just finished Joss Stone - Colour me free Now starting The Jayhawks - Sound of Lies
Still in a bluesy mood: Jimi Hendrix - Blues
Stevie Ray Vaughan - Couldn't stand the weather
Lee Morgan - Lee-Way
Rubinstein, Heifetz & Piatigorsky - Ravel/Tchaikovsky Piano Trios
Various Artists - This is 1964 A compilation of tunes by pop-rock acts like the Animals, Beach Boys, Shirley Bassey, etc. which were popular that year. Looks like it's a collection with an album for every year from the 60's to 90's ... not sure. Anyway, found it by chance on Spotify.
I've listened to Benz carts in several occasions, once even compared one -not sure it was an Ace- to a "simple" D103 on the same TT (an Audiomeca) and I didn't like them. Not as "despisable" as any Clearaudio to my ears, but prescindible. To each one his own I guess
Why? For some time I had a VdH The Frog mounted on a Project. I don't think a good cart really "needs" an expensive TT to shine. A better table will provide some benefits, but good tables don't need to be expensive IMHO. TT is the simplest part of the vinyl playing equation.
Glad you solved it Maybe my HF-2 start developing that problem too. I'll need to look at them better, probably mine aren't glued either.
No words required
Maybe you just can push the wire a bit into the cup, so there's more wire inside, then hopefully it won't touch the driver. It will work as long as the solder joint is upside, away from the wire entrance into the cup. My HF2 seem to be glued inside, so I can't push more wire inside -not that it's needed-, but on the PS1, which don't have glue holding the wire, I need to do that from time to time, otherwise I get something very similar to what you're describing.
Amos Lee - Amos Lee
Some pics will help As you can see, there's a selector to choose the source that will be amplified and "sent" to the speakers outputs (you have two, though not selectable separately, one has lower output impedance than the other, so you can find which one matches better your speakers). The other selector, labeled "record", lets you decide which source will go through the tape out. So you might be even sending one signal through the speakers and a different one to the headphone amp or recorder. In this one you can see all the inputs available -plenty of them- and the tape in and out. Just one tape loop. Also the speakers outputs, one with binding posts suitable for bananas or spades, and the other ones just for bananas. For the porn fetishists, one of the insides: Like Nate said, you can turn the volume completely down, so muting the speakers, and then listening whatever you select for the tape out, or choosing an empty input. It doesn't have a mute function as such. The tape out should work with the amp off, but it's intended to be an "always on" unit. This is one of those things which don't sound very well until they've been on for "some time" This amp errs more to the "musical" sounding side of things than to the analytical one, but I wouldn't say it's not mainly neutral. The DT is the model to look for. Forget the "normal" non-DT units or more modern ones.
I'd suggest trying the YBA Integr
Vicki, while those speakers probably aren't up to your "sound" exigences, I think the excessive bass comes from the desk acting as a resonance chamber for low freqs. I'd try taller stands, and if possible, something rigid made of metal. I'd link the speakers to the stands using Bluetack, and would decouple the stands from the desk using sorbotane cubes or half squash balls. Also moving the speakers a bit more forward probably may help. Another thing to try is filling the ports with tissue paper, so you can use light damping or more severe depending on results. If you ended up thinking that completely blocking the ports is the way to go, then I'd use thick felt or even rubber.
