June 27, 201313 yr This amp looks very interesting. Are there any plans to distribute this more widely? The old Dynalo was a starter build for many, I'm not sure if they are still available from djgardner with the transistors and all. Sorry about that, I had the thought of modifying the board so the same one could be setup for L+R instead of just balanced while writing the post. Stock it can't be done but I'll see about changing it. Might just change the board and offer a single ended one as well as I'm not really a fan of cryptic jumpers etc. It should just have all the parts on the PCB, stuff it and it works. Couldn't one just use O+ and IG for SE, and 2 boards still? Or O+ and IG and O- and IG for 2 SE outputs, one inverted? Power rails still at 16.4V (or up to 20V IIRC with the old Dynalo), or has it bumped up higher?
June 27, 201313 yr Author The board will always output balanced regardless of the input. Not really intended for SE but you could just leave the - leg not connected for SE. We are not concerned about the distribution as that is up to the people who want to build these. I have enough boards for my own use but the Gerber's will be available to all. The parts are all in stock at Mouser so that side is covered. PSU is +/-20V.
June 27, 201313 yr The board will always output balanced regardless of the input. Not really intended for SE but you could just leave the - leg not connected for SE. We are not concerned about the distribution as that is up to the people who want to build these. I have enough boards for my own use but the Gerber's will be available to all. The parts are all in stock at Mouser so that side is covered. PSU is +/-20V. Thanks. Is anyone doing a board run? I'd like to piggyback on for two pairs.
July 3, 201313 yr I would be interested in a couple boards as well if someone more versed in managing the process ends up doing one.
September 2, 201312 yr Hi Birgir - Any progress? I was inspired and took the original version of the board and modified it so the servo is the same as yours. I used a 2uF cap instead of the 10uF. Also lowed the resistor coming from the opamp to 20k. works well. now looking at an SMD version. Thinking about the sot23 version. At 15 mA per should support it. Could use the sot223 version instead. Edited September 3, 201312 yr by Kerry
September 2, 201312 yr Author Nope, nothing yet. Everything was pushed aside for KGSSHV work... SMD version would be very cool given how bloddy small we could make it. Hell let's make a portable one which would last for about 5 minutes on a set of batteries. But what glorious 5 minutes it would be...
March 8, 201412 yr Hi spritzer. Any chance you've had the time and inclination to pick this project back up? I'm still very interested in attempting a build once green lit.
March 8, 201412 yr Author Sadly it's all the electrostatic amps eating up my time. This will be finished at some point though...
March 9, 201412 yr Thanks. Is anyone doing a board run? I'd like to piggyback on for two pairs. I'd like to piggypiggyback for two pairs.
March 9, 201412 yr Thanks for the quick reply and update! I'll look forward to whenever you are able to put this back on the front burner.
March 9, 201412 yr I thought spritzer was selling some prototype boards Edited March 9, 201412 yr by nopants
August 9, 201412 yr sorry but why this board cannot run L+R ? I see ckt on both sides are identical from my untrained eyes. thanks !
August 9, 201412 yr AH I got it ,didn't notice only one set of input stage Thanks Dr.Gilmore only one set of input devices. this is unbalanced/balanced in, balanced out
August 10, 201412 yr this is the production version http://gilmore.chem.northwestern.edu/ssdynalobal.jpg
August 10, 201412 yr Fine, I will squeeze the expensive 4.7uf film caps in... done Edited August 10, 201412 yr by kevin gilmore
August 18, 201412 yr on +-15V power supplies it will do about 30vpp balanced on +/-20v power supplies it will do about 40vpp balanced on +/-15v power supplies its 200ma per channel. would need to adjust the bias resistors to reduce the current for 20v. works out to at least 2.5 watts rms pure class A into 50 ohms
