Guitar-Case
I heard a really cool device tonight -- Kemper Profiling Amplifier -- basically, it reproduces any amp.  At US$2177, it's cheaper than the 20 or so pedals I'm probably going to end up getting, trying to figure out which overdrive I want.
Also heard a Gibson Advanced Jumbo, which was pretty.
  • Replies 584
  • Views 142.8k
  • Can I post this here? A little project we've been tinkering with.
  • Wanted a new guitar my Ibanez late 80s rg570 (had it 20 years) wasn't doing it for me. Picked up a PRS S2 Singlecut hollow body. Sent from my iPhone using Tapatalk
  • This is my Jim Redgate double top classical guitar, I received it on Monday after waiting over a year to be built. This replaced my Dan Kellaway lattice braced guitar which I had for 20 years. It’s an
The only thing I have in my pedal notes is "I want an Aqua-Puss and a Sweaty-Puss or whatever those things were called."
Looks like a Mahogany GS-Mini with an SKB EPS Foam case would be my best bet for a travel guitar but I am not sure it is really worth dragging a guitar around everywhere.
But there is no creepy guy there to give me big discounts.
You would have to go to Fairfax. CA.  Lots of creepy guys there...
Uh, huh.
http://www.youtube.com/watch?v=VwR19LrF1o4
Collings Baby...
The best travel size guitar I have played.  Get yourself a Calton case for it and you can check it when you travel.
Edited by tjkurita
No way I would spend 5 grand on a travel guitar setup for TSA or rapid temp/humidity changes to destroy in a year.
I ended up going with a Voyage-Air travel guitar.  Seems to be the best of both worlds as I get an OM guitar, with full scale 1-3/4" nut that in everything I have seen sounds very good.  Unfortunately the shop had to order so it will not be in until after I take off on this first leg of the NBA trip.
DV016_Jpg_Large_H64973.001_natural_in_ca
Started working on Mumford & Sons "The Cave" tonight in lessons.  Love the song and it is really much simpler than I would have thought listening to it all this time.
Stopped to pick up my new Voyage Air and my freshly Plek'd / upgraded Gibson at the store tonight.  The Voyage Air sounds really good for something that fits in a back pack.  Quite a bit better than I remember the GS Mini sounding.
Also picked up a ceramic and a brass slide to try out.
It is remarkable what a good setup & PLEK plus replacing the Tusq with real bone has done for the Gibson.  Far better playability and sound now.
Just found out that PRS made another baritone, and in purple no less:
...but no Bigsby option.  :(
I mentioned that to them on Facebook, and they said they could do it, and to contact their Tech Center, but their tech center couldn't do it.  ("Unfortunately we could not install one as the bridge will not work for one and the neck angle is to low for the bridge that will.")
Oh, well, there's still the Gretsch.
  • 4 weeks later...
Trying to choose between a couple of guitars.  Neither of which I can try out locally.
Guitar #1 - Gibson Nashville Custom Shop '59 Re-issue ES-335 in Cherry
17308_59_ES_335_Dot_Plain_FC_2013_A93085
Guitar #2 - Collings I35 Deluxe Carved Top with Lollars Humbuckers.
The Collings would actually be a bit cheaper and I really like the looks better I think.  It would also come with the lifetime warranty which would be nice.
You guys ever played either guitar, have any advice?
I've played neither so my opinion doesn't matter but I'd go for 335, because a 335 is a 335 rather than a semi hollow body if you know what I mean.
