Guitar-Case
  • Replies 584
  • Views 141.4k
  • Can I post this here? A little project we've been tinkering with.
  • Wanted a new guitar my Ibanez late 80s rg570 (had it 20 years) wasn't doing it for me. Picked up a PRS S2 Singlecut hollow body. Sent from my iPhone using Tapatalk
  • This is my Jim Redgate double top classical guitar, I received it on Monday after waiting over a year to be built. This replaced my Dan Kellaway lattice braced guitar which I had for 20 years. It’s an
^ you just got one ?
or you  didn't notice
making you a bit of a ....
I saw that you posted "Crybaby Wah-wah pedal" in response to Jeff's query, but I didn't watch the video so didn't realize it was an HOUR LONG DOCUMENTARY.
So yeah, mah bad.   :)
And no, I didn't get one, I just thought it was a cool video that would appeal to guitarists.
I'm thinking of selling my stuff locally since I haven't really gotten around to playing it for a while.
I dont think I have the patience to re-learn everything at this point.
If anyone is interested.  50 cents on the dollar should do it.
Fender twin (15")
ernie ball albert lee
vintage/boutique pedals
good chords and whatnot
I just received the 4th one a week ago.  Two are SEs (the beater Santana that started it all, and the 7-stringer that just came out), the other two are cores (Mira & Starla).  Those latter two are the better ones.  They're both flat black and with dot inlays, so they were cheaper, but they're still 2 of the 3 best guitars I own.
The 3rd being a Parker.
Kind of off topic but somewhat related - any ukulele players out there? In my new position I teach 7th and 8th grade general music and guitar has been a big part of the curriculum in the past. Doing guitar with my 7th graders has been mostly successful but some of the physical obstacles have been frustrating for a lot of the kids. Their hands can be quite small at the age making stretching out to even the 3rd fret difficult. Chords like C and G look like they are impossible for some of the kids.
I asked a local shop to loan me some ukes and God these things are so easy to play and jam out on, it's a lot of fun. Just seeing if anyone else out there has played with an uke before.
Tyll's a big ukelele player.  And yes, they are probably the perfect solution to what you're saying.
Me:  I can hold a note!  Clean attack and release, no warble in the pitch...as long as I'm concentrating.  Day 7 (as in, in a row) is tonight.
The Paulownia Tele was routed improperly and they did not like the fit with my neck so I assume it either went back or was used for a build with a better neck fit.
No, my strat is Paulownia.
I use something similar for my ukes. I found the cigar world has many products that basically keep RH dead on at 50% RH. I use tubes filled with humidity beads from heartfelt industries.
There are tons of DIY options as well. I have 30 solid ukes in my classroom and over long breaks I put them in plastic bins with a container of water storing crystals I bought from Home Depot and those work well.
Interesting, thanks for the additional input.
The heartfelt beads work perfectly. It's such a stupidly simple concept that just makes total sense. Basically the beads are impregnated with a certain salt solution that emits a certain RH. The humidipak is essentially the same thing. One of the more weird options that works as well are kitty litter beads.
I would look into Boveda packs, depending on how far from your RH you are and how much you want to spend (these two are related). Beads are only one-way humidity control, Boveda isn't.
That's what I use for my cigars and it's fantastic. I use Oasis for my instruments.
Edited by luvdunhill
