Considering that you're only .067% off, I'd say you're close enough:D
  • Replies 813
  • Views 301k
  • jamesmking
    jamesmking
If you can find a Fluke 187 or 189 or equivalent.
They range from $200 up to $400.  (yikes)
If you want a 6.5 digit benchtop model, an Agilent 34401A is about the best you can get for the princely sum of about $400 up.. (tee hee).
Don't look for the Agilent 3458A 8.5 digit multimeter.
  • 3 months later...
I am trying to make a power supply for my Auralic Aries mini. .
The original one is labelled "switching PS  16v 1A"
 Any idea if the goldenreference can be used for such high current?
Edited by samsie
I had mentioned using Schottky rectifiers for this. I think I am going to have a few of these made:
These are setup to take either a D201 axial diode (31DQ10 or equivalent), or also accept a TO220 package like an MUR820. I know the TO220s should probably be oriented 90 degrees from how I have them for airflow, but my intent was the axial Schottky diodes on these.
I home-etched a pair of these and used them in my original Dynalo (headamp board). I used some Mill-Max right angle pins on those (3301-2-14-21-00-00-08-0), and plugged them right into the RS402 bridge holes on the PCB. If anyone with appropriate facilities wanted to compare these noise-wise to the packaged rectifiers, I could send them a pair to test.
EDIT: Added John Swenson snubber across AC primary
Edited by Pars
I think I might plagiarise that idea...
Just a thought, how big is the footprint for R1 and would it make sense to choose a bigger one? (I could be wrong, but it looks like 10mm to me and it also looks like there's space for 12.5mm :D )
//UFN
I really like the idea of including the 330R + .022uf snubber on the board.
Edited by mwl168
I don't think you really need a high power resistor for this.
http://www.diyhifi.org/forums/viewtopic.php?f=15&t=1957#p41696
Quote
I used Jim's paper as a guide and tested every transformer I had, I came up with the values of 330ohms and .022uf, they worked well for everyone of them. So now I just use those values for everything. I use a carbon comp for the resistor and a polypropylene for the cap. Put them in series and put that network across each secondary. It can make a big difference.
I have a bunch of MKP1837 caps laying around. I'll have to measure them but used a 7.5 x 5.5 mm Wima outline, 5.08mm LS for it.
I usually just solder these on the bottom of the board, but figured since I was laying the board out anyway...
Edited by Pars
On 2016/1/18 at 7:57 PM, kevin gilmore said:
It does about 1.5 amps
there will be a higher voltage one soon that does 6 amps
Does  the goldenreference  low voltage provide enough juice for Dynahi? Use two for the Dynahi?  I plan to make the Dynahi for the use of HiFiman HE-6.
41 minutes ago, FallenAngel said:
Somebody have boards? I'm building the Dynalo MK2 and wanted one :)
There's a group buy going on now:
Cool, signed up, thanks. :)
Folks, if we need a high power golden reference, like, a 350w golden reference (AC tranny), what should we do?
I'll be impressed when I hear your finished Carbons.....    :D
My profile..?
Bald head, stub nose and receding chin......   impressive..?   :o
Is possible add smd type soldering pad at GR LV's backside? smd tantalum capacitor looks are cheaper and easy to source.
maybe just my stupid idea. :(
Love this board!
Edited by palchiu
Of course it is possible. I won't be doing it because I already ordered some, and couldn't get this version run because I had already submitted the version quoted. I could put it in and send you either the eagle files or the gerbers if you want.
Ooops, Seeeds gerber viewer doesn't appear to be working tonight so can't post a pic. Vertical mounted version, like the ones I home-etched for my Dynalo.
Love this board!
Did you have a particular SMD cap package in mind? Let me know and I will add it.
