For a Dynahi powered by a pair of GRLVs set for 30V output, what transformer specs should I go for? I was thinking 70VCT or 2x35VAC — is that too much?
  • Replies 813
  • Views 302.4k
  • jamesmking
    jamesmking
i'm thinking of 2 x 30V  but you also might get away with 2 x 28V which I have used in the past, depends on the transformer manufacturer
Stupid question time (don't slap me!).
For a dual secondary transformer, could you wire the secondaries together in phase (1 end of one secondary to the opposite phase end of the other secondary), and use that as the "center tap"?
Va
0a
Vb
0b
Tying 0a to Vb for the CT...
My turn to ask a stupid question; I'm still learning about transformers. :)
How does the math for calculating rectified DC voltage work? I assumed that for a 2x22VAC transformer outputting +/-20VDC, the voltage drop is (2*22-2*20)=4V (is that right?). Some of that goes into the bridge. In that case, how can a 2x20VAC transformer end up with a +/-20VDC output? The voltage drop then comes out to 0V, with nothing left over for the bridge.
general rule of thumb is that peak unregulated capacitor value is 1.4 x rms output of transformer for a full wave bridge.
so 22*1.4== about 30 volts unreg input the regulator needs 4 volts, so you still have 6 volts of overhead to compensate for low line etc.
issues with how stiff the transformer are (how much it sags under load) lower the voltage a bit.
is 3oz copper required on the PCB or will 2oz be sufficient?
Noob style question - how is the latest board transformer wired? I'm using a dual secondary transformer, so I'm assuming I wire the two AC lines and leave the center GND open. Also, what's the 6th input to the side with resistor to ground for used for?
yes that's right, and use two diode bridges.
the 6th is if you want to ground the board to case through the 10R resistor next to it.
Damn, I already populated all 3 bridges. Should I remove the middle one or just leave it there?
Remove it I would think... would have to check the schematic
I agree remove it...............
just cut the legs if you don't want to desolder
google
Dim-bulb Tester
a great thing to have.... and very cheap to make
or variac ...  I use both
the boards I have are goldenreference6 (file name) and says version .44 on board
Edited by congo5
Thanks Pars and congo5.
I checked the bottom of the board and it looks like one part of each secondary gets rectified and fed into the positive and negative rails.
I'll just desolder it. Worst case scenario of lifting the PCB trace still has no effect.
Glad I double checked, thanks guys.
Is there any easy table for output voltage resistor selection? Maybe I'm too used to the other forum. :P
what voltage do you want?
I do not understand Kevin's method
so came up with this:
desired voltage x 150 -1500 = R8, R9
40v is 40 x150=6000 -1500=4500
30v is 3kR
25v is 2250R
30v is 3kR
25v is 2250R
Post it again for reminder:)
for V+: (R8 + R7) / R7 x 10 (reference voltage of D5 - LT1021-10)
for V-: (R9 + R10) / R10 x 10 (reference voltage of D7 - LT1021-10)
congo5's way is also right assuming that you have fixed R7,R10 's value.
Edited by ang728
Kevin's formula is more accurately shown as ((R8 + R7) / R7) x 10
30v is 3kR
25v is 2250R
Thanks for your posts guys. My question was a leading one in an attempt to have simple and direct parts list for builders that may be very skilled in building equipment but may not have a high level of understanding of schematics or circuits.
I was hoping someone would come up with a little table like the following. :)
((1.5 + 1.5) / 1.5) * 10 = 20v
((2.21 + 1.5) / 1.5) * 10 = 24.7v
((3 + 1.5) / 1.5) * 10 = 30v
R7 = 1K5
R8 = 1K5 for 20V
R8 = 2k21 for 24.7V
R8 = 3K for 30v
R9 = R7
R10 = R8
Just an fyi, but the Excel BOM that I have has 25V tantalum caps, while Kevin stated 35V in this post:
Note the part number provided above is actually a 20V part. Correct part numbers would be something like 581-TAP476K035CCS and 581-TAP106M035CCS for the 47/10uf parts respectively.
Sorry, just getting an order together for the remaining parts to finish one of mine (v.42 or goldenreference4) boards. I haven't done a spice model or analysis to see what you really might need here, and I assume a number of these have been built with no problem according to the spreadsheet I had (which I can't find here on HC anymore).
C7, C8, C9, C13 for the 47uf
C3, C16 for the 10uf
Assume a supply setup for +/-20V output, 2x23VAC input
I used 581-TAP476M020CCS on six or so units
and 35v for the 10uf 581-TAP106K035SCS
from the semantic it looks like they only see 10v
C8 & 9 are fed by the lt1021-10
C7 & C13 are in parallel with a 9.1v zener
and C16 & C3 go rail to the voltage divider/ inverting input, which is also 10v
I remember wondering about that 20v part too.
so far no problems with them, using 20v to 40v output
Yes, looking at the schematic, I would agree that even 20V would probably be OK. I'm using 35V for the 47uf parts in mine, and 25V for the 10uf currently, but that is just what I either had or sourced.
The 10uF has a startup transient up to around Vout. Probably okay in reality but settles down to Vout-10. The 47uF behave well, and zener and reference voltages should be fine there.
I am using 16V on both 47uF and output rail on the rest. You can use much smaller than the 10uF called for and be fine, so don't be too concerned about that value.
