EC Black Widow
  • Replies 53
  • Views 27.4k
  • kevin gilmore
    kevin gilmore
    ss dynahi and its easy to modify the gain. what's not easy for most people is all the chassis work. The same people sell the boards and all the parts for a price that I cannot even come clos
  • kevin gilmore
    kevin gilmore
    The ksa5 is voltage limited, so for things like the he6, not enough oomph. And its single ended, although nothing prevents you from stacking 2 of them for balanced in which case its going to have seri
  • kevin gilmore
    kevin gilmore
    I read some of what you have written elsewhere, and its becoming clear you don't have any idea what you are talking about. The apex amplifier linked to above is a single ended amplifier, that is
An eddy current is wasted energy.
Eddie Current amps are just that, i.e. Eddie Current amps.
eddy current? sounds like an old brand, must be famous.
get me one for a couple of days, then everyone will know.
lately things getting high praise by many over there turn into massive pieces of poorly build crap.
Unfortunately I don't have one. I do apreciate HC letting people know about Cavalli Audio, but what's wrong with Eddie Current? I've searched around but can't really find anything.
What amplifiers would you recommend for dynamic headphones such as HD650 then? The more the better!
Thanks kevin, google told me the eddy flapship thingy is 7 grands...
singlepower made a sds xlr gold plated that was over $30k.
inside it looked like all the other ones.
craig published one picture of a obviously hand built electra that looked decent except for the el-crapo connectors. I have been told production models are the same garbage as always. companies that refuse to show whats inside are obviously not proud of their work.
buy a Chinese made ksa5 klone.
someone posted a pic of the $7k amp, spent me a few minutes to dig it up. input and output both using transformers.
capacitors floating in air
filament transformers also floating in air with chipamp drive circuits
not really a headphone amp is it.
Studio Headphone/Speaker amp.
So, what did you expect for $7k amp,  quality, perhaps..?  :blink:
Are there any specific Chinese ksa5's that you'd recommend? I remember reading some had issues or component omissions. Thanks.
Edited by dcpoor
here you go
its better than a lot of other eddie current stuff I have seen
people that think that shunt regulated power supplies are better than really good linear supplies are wrong
the input stage is very familiar
really weak output stage with virtually no heatsinking
painted really cheap steel chassis
there are a number of ksa5 clone boards on ebay, some are mine and are obvious, but no one putting my board inside a chassis at the moment.
if you have to buy one now on ebay, this one is complete, the power supply is not as strong as the original, but its cheap
http://www.ebay.com/itm/Headphone-amplifier-Imitation-KRELL-ksa5-line-CPI-full-DC-amp-machine-ClassA-amp-/112050882595?hash=item1a16c0c823:g:61kAAOSwu4BVkJvH
this one has my board but a different power supply
http://www.ebay.com/itm/Finished-Kevin-Gilmore-KG-version-KSA5-headphone-amp-preamp-amplifier-HL-230-/142031703076?hash=item2111bfcc24:g:6GMAAOSwM4xXaLnE
this one is my power supply with a different heatsink
http://www.ebay.com/itm/Assembeled-Power-supply-board-for-KG-version-KSA5-headphone-amp-PSU-/322047929078?hash=item4afb8d6af6:g:-~UAAOSwoudW8MxP
so you could buy the right board, and the right power supply, put it in your own chassis with a transformer for about $300 total...
How would you rate the KSA5 against the Susy Dynahi or Dynalo for that matter with HD800?  Which of the three would you recommend to buy KG?  Never mind...the 2nd one I guess.
Edited by purk
The ksa5 is voltage limited, so for things like the he6, not enough oomph. And its single ended, although nothing prevents you from stacking 2 of them for balanced in which case its going to have serious amounts of power.
ss dynahi is for all practical purposes way overkill for all modern in production headphones. Very nice on vintage electrovoice and jbl horn speakers. I did just pick up a pair of original "voice of the theater" set, if I bring them home i'm dead for sure.
ss dynalo is what I listen to when I listen to dynamic headphones. as I only use the he6 now for testing.
any of the audio-gd headphone amplifiers are better than that eddie current piece of crap in every single way, sound quality, build quality etc. And less than half the price.
I hope the black widow is reliable because its stuffed with obsolete parts (although the layout for the thatcorp/Motorola front end is obviously there), repairing the thing is almost as bad as trying to repair a cavalli piece of trash.
compare the picture above with this for $520
http://www.audio-gd.com/Pro/Headphoneamp/NFB1AMP/NFB1AMP9.JPG
So this board with this power supply, plus chassis/jacks/pot, and a transformer. Sounds great for the $300 price.
Is there a specific transformer that you would recommend or prefer for this particular build? Thanks again.
yep that board and that power supply.
what you want for the transformer is a real good torroid, or even better a R-core transformer although I used a Hammond transformer for my build because it was easy to source.
Btw, that $7k amp is single-end essentially, although using some input transformers to convert the signal to balanced, long live single end tube stuff (some tell me with tubes you can't go balance without breaking the bank). I remember one of kevin's designing ideals is avoiding any transformers in the signal paths.
I've been using a headamp GS-1 with the Dynalo+ upgraded boards with my HD650's for a few months now and it transformed those headphones.  I'd put them up for a good while as I found them underwhelming with a Woo WA7 I was using.  The GS-1 really perked them up for me.  I do find the GS-1 a bit too bright with my TH900's, though....getting old and the uppers are a bit to peaky for my tastes.
HS
The apex amplifier linked to above is a single ended amplifier, that is there is a single output tube driving an gapped output transformer that carries the full dc of the power supply. The rise time and fall time of the output signal is not the same.
The eddie current tube amp pictured above is a push pull amplifier with 2 output tubes per channel. The output transformer is not gapped, and there is no dc in the transformer. The rise and fall time of the output signal is the same. In fact with both input and output transformers, that amplifier can be considered as fully balanced, and fully differential.
Big difference in the kind of sounds that these amplifiers make.
Now, since a couple have sent me emails about the black widow, here is my explanation of whats wrong with the picture above. Now maybe in the 2 box version the board had to be that size, and was obviously stuffed into a box of a specific size. But designing that way is stupid. In the single box there is all sorts of room to make the board bigger and do a much higher quality layout with better and bigger heatsinks, and having the left and right channels be absolutely identical.
The worst offender of differences in left and right channel layout was the melos, but the liquid fire, liquid lightning and especially the liquid glass are in the running.
The power supply board is obviously new, full ground plane on top, suitably sized heatsinks secured to the board etc, why use an amplifier from 2007.
The stax mafia can (and probably should) do a much better layout with larger heatsinks, identical channels etc. There is absolutely nothing unique about the circuit design.
If its going to be eye candy on the outside, it really needs to be eye candy on the inside if its going to command a premium price.
Parallel SE, they say. Balanced in with an input transformer, single ended gain stage, interstage transformer, parallel single ended output stage, floating secondary for "balanced" output.
Sure looks like 4 input wires and 2 output wires to the transformer, but what do I know.
parallel dual single ended output stage sounds like push pull to me.
