Balanced to unbalanced board
Am looking at it but I don't see the input resistors (file diffinput3 right?).
  • Replies 260
  • Views 86.5k
  • Messing with this tonight. Its playing into balanced ortho's. the gain is stock at 2 and its just enough, not real loud but sounds just great! yes this is meant for Pre duty, this is on
  • mypasswordis
    mypasswordis
    So I did end up using a female header socket and air wiring the ground. The part number for the 4 pin right angle header is 68016-404hlf. The leds I used are extremely bright orange-red, glad once i c
  • Transformers
it had better look like this
the output impedance is about 1k, working on the diamond buffer output now
Now it does. Thanks! Must have been the cache of my browser acting up.
Pardon me, how to wire the boards?
why O+   one one side,   i+ on the other?
       GND                        GND
       -i                              O-
start laying out your own boards and you will know why.
there will be a all smd version at some point with these as output buffers  .8 x 1.5 inch
+1
Now we're talking...  So if I understand that would go after the output from the unbalanced\balanced to balanced board.  Is that correct?
yep, gets the output impedance down to say 5 ohms. then you can add some resistance to match the cables you intend on using, +45 or +70 ohms
It looks like the buffer is single ended. So would you need 4 diamond buffers for 2 balanced channels?
Really looking forward to that!
Edited by MLA
some people are going to have trouble assembling this, same size for comparison
see updated picture below
Possibly, but it's still fantastic!!!
Edited by MLA
24 minutes ago, luvdunhill said:
Now you just need a second on the other side of the board :)
Or a diamond buffer or two ... :) (or are they better off separated?)
Edited by MLA
I would think that incorporating the diamond buffers for balanced would be the way to go. Do you have a schematic for this board as well?
Broken record time... Any chance of including footprints for 0.1" Molex KK connectors as well?
Good time to duck now :)
Am I going to need an oven for my birthday?  Or, will there be a through hole version with the diamond buffer included?  Ducking as well:rolleyes:  If not I'll be fine with four or the through hole buffer boards and the unbal board
Edited by sbelyo
any possibility to make these two new input output boards smaller than ever before while making them still be better than all the versions which released last year? (small size saves money)
For all intents and purposes, that's exactly what just happened.
how does this compare to the 49830? (I know it's obsolete, but still)
lm49830 is a chip amp
do you mean opa1632 and its clones, all of which require huge amounts of feedback and have all sorts of common mode dc issues
