October 28, 200817 yr comment_171463 I admit that Wes Phillips' reviews of these two flagship models have got me looking at them, but everything I read seems intriguing and alluring. These are shockingly high cost items, so I am both hesitant to go too far down the rabbit hole of this fixation and yet still very curious. I also admit that the K-XR User Manual's suggestion that a balanced tape out could be used for a headphone amplifier made my heart go pitter-pat. Recognition in the highest of the high end! Anybody else heard the these and/or have any opinions on them or their design? A local dealer reps them, so I hope to get a listen later this week. Report
October 28, 200817 yr comment_171466 I wonder if that means ayre's gonna put out a balanced headphone amp? Report
October 28, 200817 yr Author comment_171467 That would be cool. The pre has 2 balanced pre-outs and 2 balanced tape outs to go along with the 4 s/e and 4 balanced inputs, so it can do a whole lot. Any number of the ins and the tape outs can also be turned completely off and the ground lifted so it is like they ain't there. Report
October 28, 200817 yr comment_171469 It's probably just a buffered tape loop. Hell, I can do this off my KGSS and have done so. Report
October 28, 200817 yr comment_171477 My guess would be that Marc is right on the money but asking Ayre would be the best route. Since we are dealing with a real high-end company they will discuss their designs and can stand by them... Report
October 28, 200817 yr Author comment_171481 Marc and Birgir- What is it that you are talking about, or in other words what would I ask Ayre to explain? My comment about their suggestion of using the tape loop for a headphone amp was purely for grins and giggles because I don't recall seeing that in other hi-end preamplifier documentation. I was not suggesting it was anything special. As for turning off the inputs and the tape outs, my understanding is just what Wes Phillips and the Ayre manual say: turning them off "completely disconnects the auxiliary components from the K-XR (including the ground connection)." Wes goes into more detail on how it is done -- I think -- but mainly it just seemed like a good idea with so many ins and outs to be able to disconnect them and lift the ground to prevent ground loops or other interference from having all those empty jacks. That's all. Thanks, Al Report
October 28, 200817 yr comment_171485 At that price point I would look at the high end Parasound, Pass Labs and Krell too. The X .5 Pass amps are killer. Report
October 28, 200817 yr Author comment_171499 I have already had a couple of email with the guy. Report
October 28, 200817 yr comment_171500 I have already had a couple of email with the guy. Wow, get it in time for Tampa. Report
October 28, 200817 yr comment_171506 you could check it with one of the pelican cases like I bought for canjam Report
October 29, 200817 yr comment_171514 It's no problem, he has a money tree out back at the Mayberry Compound. Report
October 29, 200817 yr comment_171516 It's no problem, he has a money tree out back at the Mayberry Compound. If you attended the meet, did you get to keep what you picked? Report
October 29, 200817 yr comment_171518 If you attended the meet, did you get to keep what you picked? Yup, everyone got to shake the tree once and keep what dropped. Report
October 29, 200817 yr Author comment_171519 How do you think Mike has afforded all those Beta22s and Suckitalo cables this year? Report
October 29, 200817 yr comment_171520 How do you think Mike has afforded all those Beta22s and Suckitalo cables this year? I can't wait to get out there again, maybe I can get my wife that kitchen she wants. Report
October 29, 200817 yr comment_171522 How do you think Mike has afforded all those Beta22s and Suckitalo cables this year?Wait, was he supposed to pay me for that stuff? Report
October 29, 200817 yr comment_171524 Wait, was he supposed to pay me for that stuff? Thanks Al. Report
October 29, 200817 yr comment_171529 I was not suggesting it was anything special I suppose for some a heart-pitter-patter is special anyways, the question would be whether or not the main preamplifier circuity is responsible for handling the headphone load, or if it's an ancillary function. The latter would be my guess. Reason being that the tape loop may be powering something like a tube amp that in normal situations would cause an impedance mismatch. Report
October 29, 200817 yr Author comment_171535 The pitter-patter was due solely to Ayre mentioning headphone amplifiers in their manual. Here is the totality of the manual info on the tape outputs, and at least the third paragraph suggests there is a difference in how the signal gets from input to output as compared to the main outputs: The Ayre KX-R provides two tape outputs per channel, allowing connection of the selected source component to a recording device, headphone amplifier, or secondary sound system. These tape outputs utilize balanced XLR connectors. Should it be necessary to connect a tape output to a single-ended component, high-quality adapters are available from your Ayre dealer. Turn the tape outputs off unless they are currently being used. This will completely disconnect the auxiliary components from the KX-R (including the ground connection), eliminating the possibility of undesired ground loops. Unlike the main outputs, the tape outputs will not convert the signal from a single-ended source to a true balanced signal. Instead, the “hot” signal will be present on pin 2 of the XLR and pin1 and 3 will be grounded. This allows a connected balanced component to internally perform the single-ended to balanced conversion without the need for adapters. The tape outputs are controlled by a button on the remote control handset. Pressing the button activates the tape outputs, and pressing it a second time will turn them off. Turn the tape outputs off unless they are currently being used. This will completely disconnect the auxiliary components from the KX-R (including the ground connection), eliminating the possibility of undesired ground loops. Report
October 29, 200817 yr comment_171538 That thing costs more than a hooker, even on A'Gon. For that money, I expect more satisfaction than a hooker. Report
October 29, 200817 yr comment_171540 That thing costs more than a hooker, even on A'Gon. For that money, I expect more satisfaction than a hooker. Report
October 29, 200817 yr comment_171545 since hookers provide no satisfaction, that should be easy. Report
