My mini3 left channel is dead
Looks Like I'm gonna have to have a dig around in there to see if I can tell what's wrong and try to fix it. I hope it's simple like the jack connection. I'll pop it open and post some gratuitous pics in a bit...
Hmm, I never thought to check the tubes....
I tried it with a few phones and a different mini-mini just to make sure, it's definitely something inside. :(
Anyway, I have to go get some stuff before I start so wish me luck... the asshat is about to prep for surgery :palm:
Marshall is sending a new opamp and some magical stuff to remove the old one. Let's hope I don't fry its ass during the operation... :D
removing SMD opamps isn't my idea of a fun night ... I'd recommend clipping all the legs off, basically destroying the old opamp, then use flux on the area and finally solder wick to pull the old legs off.
It's going to be interesting to say the least, especially with all the other components in place. I guess this is where I find out whether I have what it takes in the soldering department.
MisterX didn't build it, he was kind enough to offer help though. :cool:
Ahh, ok. That was really nice of him :)
send it to nate
Gary,
I'm not sure I'd even try to remove the opamp intact. Just cut the little bugger off and then take your time removing the remnants of the legs.
Marshall is sending some special stuff that's supposed to melt the solder and keep it hot long enough to remove the chip in one piece so I'll see how well that goes before getting the clippers out.
The Mini3 uses one of two very specific OPAMPs. I don't think you can just drop anything in there and get good results :(
I'm going to wait until I can test and have parts before I take it apart so I haven't looked inside, don't suppose it'll be much different than any other mini.
Can I piggyback on this thread to ask a general mini3 question, please?
I just ordered a gamma lite/mini3 combo from Marshall for a friend. He'll be using it in a static computer rig with The Monkey's old HD-25-1s to start with and who knows what else down the road once the bug bites. ;)
What gain setting should I specify?
Never heard those, mine is set to 5 i think which is default.
My Mini3 built by Marshall has a gain of 3, plenty of volume at 9:30 o'clock position when using HD600, painful at 10:00.
When Marshall checks for a fault in the left channel, he like to eliminate all other possibilities. I think he's narrowed it down by this stage and is close to an answer :P
What the bloody hell?!? :o
I could have hacked the traces going to output jack together but I thought a replacement board was the best solution. ;)
Win! Here I thought you were just showing off your desoldering equipment :cool:
