July 21, 200917 yr comment_257681 As many of you know, I have (and love) the Manley SkipJack. It's really a neat little device with many cool uses. I've been using it primarily to compare DACs, as it allows for very quick and quiet switching. One thing that occurred to me was that the SkipJack could really use a headphone jack so that one could do the same thing with headphone amps. Is that something that already exists? Put another way, is there a passive device into which you can plug a pair of phones and then switch back of forth quickly between two amps? Report
July 21, 200917 yr comment_257683 This idea has always made me nervous what with the twitchy nature of switches and the devastating affect that shorting the output of an amp can have. Report
July 21, 200917 yr comment_257687 Kramer RCA Switcher: VS-81A - Single Output Switchers - Kramer Electronics Male TRS to male RCA connectors (1 for each amp) Female TRS to male RCA connector (1 to go to headphones) Yay! Report
July 21, 200917 yr comment_257690 If I understand you correctly you might wish to consider this--- PreSonus Central Station | Sweetwater.com I use mine as a passive preamp, it only accepts two dac sources though. Report
July 21, 200917 yr comment_257694 If I were to recommend anything I'd make sure it was rated as a speaker switch to make sure it could handle the potential voltage/current. Report
July 21, 200917 yr comment_257695 Hope it's reliably break before make Very much so (thought if you press 2 buttons at the same time you might be able to force it) also all things are switched (at least in my balanced one) so no chance for shorting that I can see. Though you might end up with one amp apply voltage to the outputs of the other. Report
July 21, 200917 yr comment_257700 If I were to recommend anything I'd make sure it was rated as a speaker switch to make sure it could handle the potential voltage/current. Good point. I have my doubts that headphones require a speaker switch but I'm not sure of the power handling capability of those switches. So instead of the Kramer use a speaker switch box. Report
July 21, 200917 yr comment_257707 Wait a minute, doesn't Ray have a switchbox? Dinny, I'm sure he would let you borrow it. The best part about it is that everything always sounds the same. Report
July 21, 200917 yr Author comment_257711 Good point. I have my doubts that headphones require a speaker switch but I'm not sure of the power handling capability of those switches. So instead of the Kramer use a speaker switch box. But how many of those have HP outs? Report
July 21, 200917 yr comment_257713 But how many of those have HP outs? Dinny, Use switch box with the connectors I mentioned above minus the the rca connectors. Report
July 23, 200917 yr Author comment_258308 Dinny, Use switch box with the connectors I mentioned above minus the the rca connectors. Then I should be able to do it with the skipjack under the same principle, right? Report
July 23, 200917 yr comment_258312 Then I should be able to do it with the skipjack under the same principle, right? Yes. I would think so. Report
July 23, 200917 yr Author comment_258315 This is where Nate jumps in and says that it's also the same principle under which I am going to blow up all of my amps and sources. Report
July 23, 200917 yr comment_258326 You know, Dinny,I used to use my left hand for switching, but lately, find the right to be it's equal. ymmv may vary, but in this test, I am a right brain troglodyte: The Right Brain vs Left Brain test | PerthNow Help! Al, Vicki, John, Mike, Matt ... anyone .. that's not me, is it? Muhahaha ... of course it's me. I have and love the Manley Skipjack, so no arguments on that device allowed (per secret canjam oath with eam). Report
July 23, 200917 yr comment_258329 CAPS LOCK MAN SAYS WHAT THE HELL IS WRONG WITH YOU? JESUS. ETC. Report
July 23, 200917 yr Author comment_258366 I was able to make that lady dance whichever way I wanted with my mind. Report
July 23, 200917 yr comment_258442 This is where Nate jumps in and says that it's also the same principle under which I am going to blow up all of my amps and sources. Nah, it's where he jumps in and says he's not fixing anything you blow up. Report
July 23, 200917 yr comment_258473 Here's a DIY relay based switcher from Rod Elliott (ESP) that works well. A-B Box For Amplifier Comparisons Report
