July 22, 20188 yr comment_793092 Thank you again everyone, going to get those ordered, strangely enough i'm on vacation in Hawaii but keep thinking about the amp i want to build :) Report
July 22, 20188 yr comment_793120 19 hours ago, swampsong said: Thank you again everyone, going to get those ordered, strangely enough i'm on vacation in Hawaii but keep thinking about the amp i want to build It will get worse, trust me ! Perfect project to ignore everything else in life LOL! Report
August 11, 20188 yr comment_793853 No... not me. This looks like the original layout with a custom chassis or maybe just painted. Report
August 11, 20188 yr comment_793854 It looks like the back plates are missing - maybe because they did not fit given the length of the amp board. Unless they used the shrunk amp board, I can't see an off the shelf heat sink working. Report
August 12, 20188 yr comment_793866 13 hours ago, Kerry said: No... not me. This looks like the original layout with a custom chassis or maybe just painted. My mistake. Figured it was an earlier case design iteration. Report
August 12, 20188 yr Author comment_793869 The first ever amp was the silver one Kevin has and it looks just like the other ones. Report
August 16, 20188 yr comment_794028 Okay SumR is shipping the transformers... so that is good... back from Hawaii became slammed with work, but now i have some time... Going to start stuffing the boards this weekend... Honestly i'm getting a little scared now :):) its all fun and games ordering stuff online but now is the real deal I've soldered for years so i'm not worried about that... need to order the volume control that is the last part, and a screws a few other items... should be fun Report
August 17, 20188 yr comment_794049 A lot of fun indeed. Just go slow and double check everything. Report
August 20, 20188 yr comment_794216 On 8/10/2018 at 10:42 PM, nopants said: Whose build is this? pretty slick Hey, would you look at that. It looks like the over $10,000 that lil' Knight ran off with has actually been put to good use producing T2 chassis and boardsets. Didn't recognize it at first: And it would appear that you can buy these over on Head-Fi, available in different colours. Glad to hear that Tran isn't dead.... Report
August 20, 20188 yr comment_794219 wait so the guy i got my set from is the one who ripped everyone off? if so he said he's doing another board run too... that makes me feel a little strange... https://www.head-fi.org/threads/fs-stax-diy-t2-boards-rare-transistors-set.876713/#post-14333731 Brazilnut has been telling me i overpaid a lot, and that sucks... but that's life i guess... i'm probably getting something wrong... Report
August 20, 20188 yr comment_794220 Who knows. All that seems clear is that for the past 3-4 years this fellow has been selling all of Lil knight's parts and builds, including the stacks of T2 PCBs from the failed group buy. Now he is selling the very T2 chassis set from the failed group buy. Also based in Viet Nam, as was lil knight. But then again, could be totally unrelated. Report
August 20, 20188 yr comment_794221 I bought some stuff from that guy, pretty shoddy waresSent from my Pixel 2 XL using Tapatalk Report
August 20, 20188 yr comment_794223 I don't know who that is, but the angle brackets are nowhere in any of those pictures. Almost impossible to build without the angle brackets. and brazilnut is aka hennyo aka dude5OO aka becky aka rebecca aka... so I would not put much value in what he says. Edited August 20, 20188 yr by kevin gilmore Report
August 20, 20188 yr comment_794224 that's the guy that's been harassing me about buying my stax omega's, thanks for the heads up Report
August 20, 20188 yr comment_794225 interesting are the angle brackets the parts the boards mount to on the inside? mine has those... I'll take some pics and show in just a bit... Okay thanks for the tip Kevin, i thought he was trying to make me feel unusually guilty about the money i spent but just wanted to be polite when i'm online having fun with my hobby :):) Report
August 20, 20188 yr comment_794226 1 minute ago, swampsong said: interesting are the angle brackets the parts the boards mount to on the inside? mine has those... I'll take some pics and show in just a bit... Okay thanks for the tip Kevin, i thought he was trying to make me feel unusually guilty about the money i spent but just wanted to be polite when i'm online having fun with my hobby :):) What board version do you have? That chassis would have been made for the shorter amp board with different transistor spacing and the quads of tubes are slightly closer together. Full size amp board does not fit. PSU board is pretty much the same so no issue there. 29 minutes ago, nopants said: that's the guy that's been harassing me about buying my stax omega's, thanks for the heads up Now I will be harassing you... Report
August 20, 20188 yr comment_794227 doesn't the shorter board also have errors on it?Sent from my Pixel 2 XL using Tapatalk Report
August 20, 20188 yr comment_794228 It is correctable. And i love how the seller on head-fi has soldered the output wiring block backwards on the amp boards - that is some cramped space between the wiring block and the front plate... Report
August 20, 20188 yr comment_794229 Here are my board and chassis set, the board says this on it incase the pics don't come through good: Production revision 1.08 Silkscreen version 1.04 Shrunk Version Report
August 20, 20188 yr Author comment_794230 Some slight short to ground just adds to flavor of the amp... Report
August 20, 20188 yr comment_794232 5 minutes ago, swampsong said: Here are my board and chassis set, the board says this on it incase the pics don't come through good: Production revision 1.08 Silkscreen version 1.04 Shrunk Version You will need to move your PSU board forward to make space for the transformers. And have you tried fitting the amp board with the brackets? Might want to double check that it will fit (and whether there is space for you to use board mounted XLRs), looks like it from here, though (as long as the brackets line up). Report
August 20, 20188 yr comment_794233 Okay thank you, i'll test that the amp board fits tonight Yea the PSU board was just in there not mounted so i can slide it forward i'm sure no problem Still though if this guy ripped some users off and is now selling those on head-fi maybe i should ask him about it? he has been very forthcoming... i liked to see what his response is... its weird and i think other users at headfi should know... he sold a few more sets after me and is asking for others to do a board run with too... Report
