dreamwhisper Posted November 7, 2009 Report Posted November 7, 2009 ...assuming that cables are important, (I don't want to get arguments started) Is the quality of digital cables as important as the quality of analog cables? EDITed for clarification hahaa
grawk Posted November 7, 2009 Report Posted November 7, 2009 Every bit as important. No cable no signal
Dusty Chalk Posted November 8, 2009 Report Posted November 8, 2009 (edited) LOL @ 'bit'. They (digital cables) need to meet the minimum criteria, but after that, MHO is that further improvement is nonexistent, whereas with audio cables, I think there is still an asymptotic curve (I.E. the usual lip service to diminishing returns, but no 'threshold' proper). Edited November 8, 2009 by Dusty Chalk
spritzer Posted November 8, 2009 Report Posted November 8, 2009 75ohm coax cable and 75ohm BNC's are you are set.
feckn_eejit Posted November 8, 2009 Report Posted November 8, 2009 75ohm coax cable and 75ohm BNC's are you are set.This no shen and the only way to do S/PDIF properly... it makes a difference. Doesn't need to be expensive, just to spec.
Currawong Posted November 11, 2009 Report Posted November 11, 2009 I'm with "SPDIF to spec" but analogue cables get the law of diminishing returns applied strongly (probably most due to the increasing amounts of marketing given to them as they get more expensive).
dreamwhisper Posted November 11, 2009 Author Report Posted November 11, 2009 so is BNC is the only way to have spdif to spec? it's much less rare to find BNC than coaxial right? so what about other digital inputs and outputs... toslink, aes/ebu, are these way off in terms of speC?
grawk Posted November 11, 2009 Report Posted November 11, 2009 aes/ebu is dead simple to get to spec.
luvdunhill Posted November 11, 2009 Report Posted November 11, 2009 aes/ebu is dead simple to get to spec. really? if that was the case, then wouldn't it be just as easy to get coaxial to spec? I mean, okay, there's a difference in transmission impedance, a different connector, higher signal level... isn't that it?
Pars Posted November 11, 2009 Report Posted November 11, 2009 other than an xlr will never achieve 110ohm spec. Also to the OP, BNC and coaxial aren't mutually exclusive. BNC connectors are designed to be used on coaxial cable, most of them on specific coaxial cables. Try to make your spdif cable at least 1.5m... longer won't hurt you here.
dreamwhisper Posted November 11, 2009 Author Report Posted November 11, 2009 I can't find any PCI cards that have coaxial output with a BNC female connector, and off the top of my head I can't think of any transports I've seen that have that either. I'm using a random Philips coax cable from Walmart from my EMU 0404 into my Parasound and I'm having doubts that it's up to spec, I might have to switch to AES/EBU, and see if I notice a difference
Dusty Chalk Posted November 11, 2009 Report Posted November 11, 2009 I believe older Parasound and CEC transports have BNC outputs, but I honestly can't think of any soundcards that have BNC anything.
spritzer Posted November 11, 2009 Report Posted November 11, 2009 The Trends UD10.1 has a BNC output and so do other USB based transports.
cetoole Posted November 11, 2009 Report Posted November 11, 2009 other than an xlr will never achieve 110ohm spec. Also to the OP, BNC and coaxial aren't mutually exclusive. BNC connectors are designed to be used on coaxial cable, most of them on specific coaxial cables. Try to make your spdif cable at least 1.5m... longer won't hurt you here. I believe XLR actually does come pretty close to hitting the 110ohm spec, the real problem is that an XLR connector is not in any way an RF connector. Something like a twinax connector would be much more suitable for balanced spdif.
The Monkey Posted November 11, 2009 Report Posted November 11, 2009 I guess I have similar questions: 1) What about Toslink? I generally see negative comments about it but I don't really understand why. 2) On a given DAC, is the SQ from the various inputs (setting aside the cable quality for the moment). For example, does coax in generally have some advantageous implentation over toslink that will make it a preferred method of connecting?
cetoole Posted November 11, 2009 Report Posted November 11, 2009 1. Slow rise/fall time, which can influence the decision point (jitter) 2. Yes, different connection types can have different jitter, which may matter to the sound. Depends really how the DAC gets it's clocks. Of course, toslink does have the advantage of complete galvanic isolation. Coax may, depending on the use of pulse transformers.
Pars Posted November 11, 2009 Report Posted November 11, 2009 Also, Toslink has a transmitter/receiver which introduces noise/jitter as well, so an additional conversion from electrical spdif to optical and backGood coax implementations should use a good pulse transformer (Newava?) and be terminated correctly. Many (most?) aren't. Many pulse transformers in existing equipment may be there more to pass FCC Part15 testing than their performance as a pulse transformer. Looking at my Rotel 855 for example (yeah, old ), it uses a pulse transformer and then a 2 conductor ribbon cable to the spdif RCA. Nice. Even well done, the clock is embedded in the data bitstream (bad design). Most DACs anymore don't rely on extracting the clock, but people still hear differences in cables when they shouldn't.
cetoole Posted November 11, 2009 Report Posted November 11, 2009 You figure most DACs use ASRC these days? No idea really. Also, many sources will use a series ferrite bead to suppress EMI for FCC compliance reasons, even though that EMI is really just upper harmonics making the sharp edge of the wave.
dreamwhisper Posted November 13, 2009 Author Report Posted November 13, 2009 I believe older Parasound and CEC transports have BNC outputs, but I honestly can't think of any soundcards that have BNC anything. The Transporter has BNC output, but to send signal to it you've got to be losing some quality because your'e converting music to a wireless frequencies and then back ...also it's 2K
morphsci Posted November 13, 2009 Report Posted November 13, 2009 ... but to send signal to it you've got to be losing some quality because your'e converting music to a wireless frequencies and then back ... Whiskey Tango Foxtrot!
Fitz Posted November 13, 2009 Report Posted November 13, 2009 C'mon Jim don't be daft. It's just like how when you connect to the internet via a wireless router, websites and such appear in worse quality than when you use a hardwired connection.
morphsci Posted November 13, 2009 Report Posted November 13, 2009 ^^^What? Your words are all blurry and shit. I hate this wireless bullshit.
Fitz Posted November 13, 2009 Report Posted November 13, 2009 Yeah see you would have better character separation if you weren't converting all your internet to a wireless frequencies.
cetoole Posted November 13, 2009 Report Posted November 13, 2009 but to send signal to it you've got to be losing some quality because your'e converting music to a wireless frequencies and then back Warning, does not compute!
dreamwhisper Posted November 13, 2009 Author Report Posted November 13, 2009 Yeah I think I'm prbly a little too obsessed with this spec stuff, call it bit perfectionsim . But if data is transferred to the the device without any errors I'd be interested in finding out how it works.
