i'm on a roll... the kgsshv
442K:  71-RN60D4423F
Not the Carbon? ???
Kevin understood me, major brain fart time...   :)  I should try to sleep some more but there really is no time.
I did mean the Carbon.
  • Replies 5.4k
  • Views 1.3m
That's looking impressively small. A depth of 4.35 inches implies a horizontal mounting unless on goes for at least a 3U case. But horizonal is probably the easier and better way anyway.
I like it very  much.
Does it make sence to use mpsa06 and pzta06 on the same board?
May I also suggest to add descriptions for the trim pots on the silk screen? Makes it easier..
Edited by insanity
updated the picture, please check against schematic for accuracy.
the board is now 5.65 x 4.35 inches
the idea is to stuff this into the pesante 2U box.
just fits.  With the new power supply 6 x 6.5 inches, 2 amp channels
on one heatsink, and the power supply on the other.
leaves more than 5 inches x 6 inches for the transformer.
now to find some r-core transformers.
single box, all standard parts
Is the via above the left hand current source too close to the bracket, considering its on the top of the board?
one board may have to advantage of less cables, if possible to modify accordingly.
but i think for shipping and practicality reasons 2 boards are probably better
Edited by insanity
it would be the same number of cables.
both boards would fit on one angle bracket with .5 spacing
final board size 5.45 x 4.2 inches so the boards fit side by side.
here is what it would look like in the Dissipante 02/300N 2U 4mm BLACK
(360mm wide x 300mm deep internal)
http://gilmore.chem.northwestern.edu/kgsshvcarbonchassis.jpg
for the amp boards, you can lift off the bottom of the chassis by .8 inches
then put the power input block on the bottom of the board. would make
for a very pretty wiring job.
Looks good. I guess I'm not the only one wanting to build this.
Just out of curiosity. What is the reason why we use 4 separate rectifier diodes instead of one bridge as in the kgst supply?
So you'd want a larger cap?  Why?
Because those diodes are SiC and there aren't any SiC bridge rectifiers.
I just noticed that the two .47uf/50V disc caps don't seem to have the same lead spacing.
fixed everything I know of, same names have a look
also the stax mafia are starting to use these
http://www.digikey.com/product-detail/en/THINC22-TO220-16-11.4-5.8-0.3/1168-1953-ND/3878142
on the dn2540 and the power diodes
would like to find that part at mouser, but can't yet
(works well on the kgst cascode board)
oh good should work on the exposed tab lm7*15 parts too
also today is the time to find out what all the TKD pot fuss is about
I was just thinking about the orientation of the boards in the case. How much heat is generated by the PSU board? Is it similar to 1 amp board or significantly more/less?. From eyeballing it would just fit to put the psu and one amp board on one side and the other amp board on the other side. This would give us more space in the middle/front part of the case. But I don't if this is  a good idea if it results in significantly different temperature of both heatsinks/amp boards. I am dreaming about an rk50 in the middle behind the front panel...
Furthermore I have a question about the shoulder washers used with the bigger ceramic pad for the to247. Which ones do you use? The holes of the bigger ceramic pads are also a bit bigger.
Edited by insanity
This looks really nice! The main reason to use this over the Carbon servo board from earlier is size, right?
A few small requests for the silkscreen to make it completely self-explanatory:
1. Add voltage ratings for all caps that don't have them (1uF by the servo, 5pF, .47uF at the bottom).
2. Add an OR next to the LSK389/K170 spot, like on the KGST.
3. Labels for the the 100ohm trimpots. Not sure what they do.
added labels to the silkscreen and updated the zip file
the original board is 6.28 x 3.37 inches  and won't fit in a standard chassis with the power supply
the new board is 5.45 x 4.2 inches
the new layout is much tighter, shorter lengths and the two output sections are absolutely identical.
I have an alternate version of the power supply split into two pieces each 3 x 6.5 inches
so you could mount the power supplies vertically, one per heatsink, and one amp channel
per heatsink
The amp boards look great and I really like the idea of the split power supply. Certainly makes case selection more flexible. It seems like it might even be possible to partially overlap the amp and PSU and go for a shorter but taller case.
For the SiC PSU, what's the voltage value for the 47uf caps near the top? Since the old zener string is gone, how exactly is the output voltage (400V vs 450V) determined?
change the value of the 2 resistors in series  on the other side of the reference.
the 47uf are tantalum capacitors, and 35v is fine. just in case the zener has to go up to 24v
Thanks kevin. Would 500V caps work for 450V operation or should 550V ones go in anyway?
I would definitely go with the 550v caps.
depends on the voltage range of your power.
if you go with standard voltage +/-5% you might squeeze in to the 500v
but if its standard voltage +/-10%, that's pushing it.
might be a stupid question, but don't you need the 20k resistor to maintain a drop of 10V?  something like (Vcc-10V)/0,5mA = total value of two resistors in series ?
so in case one cannot get the resistor values needed, the 20k can be changed a bit up/down as long as there are 10V across ...right?
