  • Replies 1.6k
  • Views 321.8k
  • This could be trouble. First results were very promising, if not entirely drinkable.  I'll toy with grind just a big more to get a full extraction but tomorrow morning should be fun and int
  • ^^ enjoy I was lucky that Sonja brought a Breville to the relationship.. (larger style with grinder, etc.) After several months of Costco coffee living out of the airbnb - we unpacked the ro
  • The Niche Zero arrived last week and I've gotten to use it.  So did the Chemex.  I chose the 6 cup which worked out well for my situation.  I'm the only coffee drinker in the house, but if I have a gu
On the Niche for espresso machine shots I'm between 9 and 11 depending on the bean and the age of the coffee.
I don't clean my Niche that often.  When I do, I simply disassemble to get the burr related parts out and use the provided brush.
HS
I clean grinders the same as Dan.
The Hoffman giveaway item I received was the refractometer! It’s not the best one in the world, but I’m sure it’ll be fun.
And the corollary being that we can all calibrate the same way. I go slightly to the right of the indicator, myself.
One thing I started doing after the espresso machine acquisition is placing a couple of small pieces of masking tape between the rotating rings/parts so I could see if they were drifting (require recalibration) given I use the Niche for pour over in the morning and for espresso after lunch.  YMMV...
HS
Ok, now that I reduced the grind to 12, the puck crumbles upon whacking the knock box. (Behave here Steve) Prior to changing the grind the puck would pop out as a solid piece.  Is that bad or nothing?
if you have a bottomless portafilter, does the stream consolidate into a single stream or is it a shower or multiple streams?
It's probably crumbling because you're getting better extraction.   Watch the pour, and stop it a little after you get blonding, and you should have a good shot.  Experiment with that and find out where your sweet spot is for flavor.
One of my smarter purchases in support of the espresso maker is a small mirror that is magnetic and rotates.  I place it on the espresso maker next to my scale so I have a clear view of the portafileter screen so I can see the stream coming together, etc...  Money well spent IMHO.  I found it on Etsy and I'm happy to provide a link if anyone is looking for one.
HS
All of the above. I need to try a few more pulls and watch closer with my mirror to assess my progress.
HS
Yes please. I tired of crouching to watch the pour.
This is the one I purchased, but it appears they are out of stock.
https://www.etsy.com/listing/1103111404/shot-nanny-elegant-bottomless?show_sold_out_detail=1&ref=nla_listing_details
I saw this one in the feed that looks like it could be the same.
https://www.etsy.com/listing/1205499848/espresso-shot-coffee-mirror-50mm-2?click_key=3ea59f7c4e3dca25744ec94a5a9c03a6578bc067%3A1205499848&click_sum=eff1b793&ref=sold_out-6
HS
I have a Normcore mirror and a Weber looking glass. The Weber is nice, but not worth the money over the Normcore. The Normcore has a magnetic base. I keep it on the edge of the drip tray.
How often are y'all struggling with channeling? I have not invested in a new portafilter yet, so I can only judge by flow rate change, taste and puck inspection.
Not too terribly often; are you WDTing? I WDT or use a blind shaker; they both do a great job of distribution, which is the number one element for reducing channeling.
Edited by EdipisReks1
Nope - using the Oracle grinder built in setup with it's spiral press. It does a really good job most of the time. I have found that if I have an issue it is the grind setting (well it is the only setting that I have). I was just curious with most people using an open portafilter, if there were issues that people were trying to resolve.
Q - with the duel boiler - do you have a preference for your pre-infusion pressure? I have been using 65 (I assume %). I think that the duel is the same setup.
The Oracle and the Dual Boiler have the same basic mechanism, so yeah, it works the same way. I don’t think my having the OPV set much lower than factory affects the preinfusion, but my having a different solenoid very well may: I’m running at 80, which on my machine gives me a solid 1/2 bar preinfusion. My understanding is that it’s percentage of pump pressure, yeah.
I don't have channeling issues very often.  I do have to play with the grind setting as I purchase new coffee, or adjust a smidge as the beans age but these are very minor tweaks to grind setting (well less than one tick on the Niche).
I pre-infuse with the Lelit Bianca at 2 bar for roughly four seconds and then swing the paddle for higher pressure until the gauge hits 9 bar.  Seems to work pretty well.
One thing I have concluded is I can torture myself with a less roasted bean trying to hit the sweet spot for espresso or I can purchase a bean clearly roasted for espresso (plenty dark) and make my life much easier hitting my marks.  Much darker notes on the heavily roasted beans so it's a taste thing.
HS
Latte art is sure hard if you aren’t making 100 lattes a day and/or are not a robot.
After two pounds of coffee, I am starting to get the hang of the Oracle. The new portafilter helps with being about to see the flow and distribution.
I am on my third new coffee now. And I am able to get it dialed in with about three shots. I seem to work best starting with too much flow {a bit sour} and then work towards making it stronger and more extracted. My palate can detect that easier than starting on the bitter side.
I wanted a bit more coffee in my latte, So I have increased my dose up to 22 in and 45 out, right at 35 second. I will probably decrease my milk volume a bit to give me a little more coffee ratio.
Still a few things I may change, the burr set is a little worn {rough cutting edge}, and they are relatively cheap to replace. It was a used machine. But overall I am becoming more happy with it as I use it more. Surprise, good coffee makes me happy.
cheers
Nice! It feels really good when you get things dialed in. Plus, as you say: good coffee makes you happy.
