digital attenuator
I may be interested since I missed on the last run.
Can you remote control them?
  • Replies 415
  • Views 133.9k
  • I've got my controller boards working pretty well now with the digital attenuators.  I like the larger one because it has a really nice feel as you turn the volume knob (...yes I see it ). I went
  • Here's the code.  Just rename the PDF to Zip and expand it into a folder under your .../Documents/Arduino directory. The code works well now, though there are a few things I'd like to keep workin
  • Just wanted to offer a quick update on this...... I couldn't get the "all in one" code from @Kerry to work perfectly with my setup; it always opened up the relays to full volume on power-up, and I cou
You'll need to build your own controller for the attenuator. (i.e., an arduino) You can add remote control functionality to it.
I have never played with an arduino; I guess I may have to sooner or later.
  • 9 months later...
I was considering about making another batch of bare boards.  Anyone else want to join in?
is there a compelling reason to run boards for this one over the amb or twisted pear offerings
I found the TP JTree to be a bit of a hassle to implement right. Heck, I'd rather take TDK instead.
What I'm anxious to try are the PGA2320 chips.
If that's the case with commercial offerings then sure I'd be down to grab a few attenuator boards.
I've built a simple circuit with a PGA2310 which is very similar to the 2320 but comes in a DIP16 package. The only things I haven't done yet are figure out the input and output impedance and how well balanced operation would work.
  • 2 months later...
Anyone have used the KG Digital Att with Pot/Vol/Bal controls for an amp. If so how did it work out.
What did you use for controls. Want to do it but was interested if there were
any snags found.
Thanks
Les
  • 2 months later...
Just finished my two boards and wanted to say thanks to Kevin/Kerry and stv1756 for their valued contributions.
Assembly was straight forward and for a guy with buggared eye sight the 1206 smd were great.
My pair are for my T2 and will be balanced arrangement. The code worked well and absolutely thrilled.
This is my 3rd KG project that's worked first time and above expectation.
Les
  • 1 year later...
Anyone had experience with the smt version attenuator in the board dump?
Is the board verified?
finally cleaning up, i have one extra set of the original attenuators, part of the buy that
kerry did, professionaly assembled, and i tested them last night, so if anyone is interested
i can sell that pair. Price is whatever kerry charged, which might take me a while to look up.
I'd like to buy
If I remember correctly they were around $97 $99 ​per board.
I'm going to review the new smt version of the board and order a couple so I can test it.
EDIT: I just checked on the price of the original assembled boards.  I have a set sitting in front of me that i'm putting into my BH build.
Edited by Kerry
I'm interested, count me in for one set please.
I was just looking at the 24.3K BOM and Mouser, and it appears that Mouser doesn't stock 6 of the resistor values anymore (in the IRC/TT PFC 1206).
If anyone has already worked through this problem, let me know.
Also, I assume that this version of the attenuator (Kerry group buy, 24.3K impedance) would work fine with the Multiamp?
Timely, I know ::)
Chris
Edited by Pars
I'm also interested in a set if you're willing to do a run, what impedance are you aiming for?
for multiamp, you really want the 10k version.
Is it still an issue if using FET input? I believe the 1st BOMs were for 10K? I presume the Rt termination resistor = 10K is what I am looking for?
