May 24, 201115 yr comment_448682 So this thread is like the "post the last thing you bought" thread except the rules are that you had to dumpster dive for it. Here is my latest find http://gilmore.chem.northwestern.edu/mp4-1.jpg http://gilmore.chem.northwestern.edu/mp4-2.jpg absolutely over exposes the camera even on iso 150 and f32. 4 x 150 watt flood. Less lightbulb soon. Report
May 24, 201115 yr comment_448689 absolutely over exposes the camera even on iso 150 and f32. Yes, because in the days when copystands were in common use, film with an ISO in the single digits with reciprocity failure issues setting in after just a few seconds was common. That datasheet recommends 4x 200W bulbs, 1 sec exposure, and ~f/8. Report
May 24, 201115 yr comment_448692 Less lightbulb (anything) soon (ever). Where is Kevin, and what have you done with him? Edited May 24, 201115 yr by nikongod Report
May 24, 201115 yr comment_448704 Does replacing the motor in my 20, check that, 25 year old beard trimmer count? Report
May 25, 201115 yr comment_448772 I like this thread idea. My community dump has a separate pile for electronics right next to where you drop off the rest of your trash. Pickings are slim, mainly broken computers, VHS players, and CRT TVs and monitors. Sometimes good stuff appears though. My most recent acquisitions were a Panasonic ghetto blaster from the 80s (my 3 year-old son's introduction to cassette tapes is nigh) and a Yamaha Natural Sound receiver, which needs its pots cleaned but otherwise sounds promising. I used to dumpster dive a fair bit, mostly at Future Shop. Functional cordless mice and keyboards seem to make their way into their garbage frequently, for whatever reason. Edited May 25, 201115 yr by acidbasement Report
May 25, 201115 yr comment_448804 Manufacturer: Canadian General Electric Co. Limited, Toronto, Canada. Model: C100 Approximate Date Of Manufacture: 1946-47 Type: 5 tube AC/DC BC band radio Tube lineup: 35Z5, 50L6GT, 12SQ7, 12SG7, 50C5 (octal) Report
May 25, 201115 yr comment_448838 Where is Kevin, and what have you done with him? I did not think Kevin had that word in his vocabulary! Someone must be holding him hostage and usurping his posts! Good thread idea, though I don't dumpster dive, but might if there was anything around here worth doing so for. Edited May 25, 201115 yr by Pars Report
May 25, 201115 yr comment_448859 I suspect Kevin will do something like install LED floods of a specific color temperature (and eye-watering price tag) and then fabricate some electronic ballast dimmer pack for the whole thing ...maybe a 4 channel one for independent adjustment. Report
May 26, 201115 yr Author comment_448879 Well dimming those flood bulbs results in the typical shift in color temp. Tried 75 watt halogens, don't really like them. I have some 50 watt ones i have not tried yet. Tried 15 watt cfl bulbs, ok but... color temperature shifts and warmup which really annoys me. LED bulbs it is. Probably i will spend about $160 on the bulbs plus i have suitable dimmers laying around. 2 dimmers, front and back just like the switches at the bottom of the thing. At least no shift in color temp. And no gobs of heat suitable for melting stuff either. I really like the antique radio. Do realize that the entire chassis is electrially hot, and all the filaments are in series on the 110 vac line. Which is why among other reasons the entire case and knobs are plastic. I did also want to point out that my mantra that "if some is good, more MUST be better" is not always true. Case in point, my corvette is 1300 lbs lighter than my previous jaguar S type R. So 25% less car gives me 25% more mileage and 50% more fun. Similarly too much light for a modern digital slr is also a bad thing. Most of the lenses have their sharpest focus and minimum aberations at two stops down from fully open. So if you have to put stop the lens down to f32 you are not going to get as good a picture. Once you crank down the fake iso number as much as it will go, and have the shutter as fast as it will go the only thing left is to reduce the amount of light. I measured the work surface at over 2500 foot-candles (meter maxed out) with 4 x 150 watt bulbs light. Edited May 26, 201115 yr by kevin gilmore Report
May 26, 201115 yr comment_449025 Here is my latest find http://gilmore.chem....n.edu/mp4-1.jpg http://gilmore.chem....n.edu/mp4-2.jpg I noticed the cuddly soft toys in the bottom left corner. Must be for consolation purposes when the builds don't co-operate - or presents for Grawk..... Report
May 27, 201115 yr comment_449102 ^ bad links Kevin http://gilmore.chem.northwestern.edu/mp4-1.jpg http://gilmore.chem.northwestern.edu/mp4-2.jpg Report
May 27, 201115 yr comment_449106 ^ bad links Kevin http://gilmore.chem.northwestern.edu/mp4-1.jpg http://gilmore.chem.northwestern.edu/mp4-2.jpg Need one of those to take pictures of my bottles.. Report
May 30, 201115 yr comment_449637 My wife works for a university engineering department. About a year ago they cleaned out the labs, tossing out a huge accumulation of "obsolete" parts. By the time I found out about it, almost everything was gone. I did manage to salvage 25 or 30 new testing RCA red base 5991 and 5992 out of a dumpster filled primarily with coffee grounds, week old lunch remnants, and half filled old milk cartons. Really needed a shower after that one. I kept a dozen or so of the red base RCA's and sold the rest on Ebay. Netted about $250. Not bad for 15 minutes of work. Still pisses me off about what I might have missed. I'm always on the look out for interesting stuff in garbage cans, garage sales, thrift stores, etc.. Used to find things on a regular basis ( Fisher 500C, Harmon Kardon Citation, Klipsch Lascala). Not much anymore. Report
June 6, 201115 yr comment_451017 I don't need these and would give them away if anyone wants them, not sure what could be done, maybe Frank could make s case Pretty nice aluminum. There are around 30 I think. Report
June 8, 201115 yr comment_451266 Those are cool. I'll ask Bonnie if she's into making aluminum jewelery. Report
July 22, 201115 yr Author comment_459724 Found this brand new in the box, never used. Batteries in a seperate bag, and immediately dumped in the used chemicals pile. http://gilmore.chem.northwestern.edu/simpson260.jpg I have no idea how old it is, i figure late 1960's Report
August 30, 201214 yr comment_532697 Necrobump! My friend was going to throw this out. I said "mine!". It's a Mitsubishi LT-90 linear tracking turntable with the accompanying DA-L90 seven-cassette deck receiver combo. Seems to work perfectly. It's very '80s, with the seven-cassette drawer sliding automagically out from the receiver when you push the button. Not that I needed it, but it's pretty neat. Playing Black Sabbath through my old psb alphas, it's a pretty thumpin' mid-fi throwback. Edited August 30, 201214 yr by acidbasement Report
August 30, 201214 yr comment_532705 Found this brand new in the box, never used. Batteries in a seperate bag, and immediately dumped in the used chemicals pile. http://gilmore.chem..../simpson260.jpg I have no idea how old it is, i figure late 1960's Just now noticed this. Dat font on the meter. That D3 is nearly as sharp as a D800. Which lens did you use? 50mm F/1.4? Report
