KGSSHV, Balanced Dynahi Rev A and DynaFET board run
I'm starting to feel sorry for Lil Knight. This board run has become huge, and mailing out this many boards is going to become quite a bit of work...
  • Replies 448
  • Views 123k
  • Cool Package to Deepak seems to be affected by the hurricane... Got stuck in NY for the last 5 or 6 days already Hopefully he won't receive a soaking wet box.
  • Just got my boards. It's a bit startling just how much smaller the Exstata V2 amp boards are compared to the KGSSHV given that they were once identical...
I'm sure we'll come up with a nice way to thank him :D
We definitely should, as this board run is a great service to us DIY'ers.
Thanks Lil Knight! :)
I can't believe we are reaching 100 sets of KGSSHV... What a number!
Since we have different kinds of boards, I'll try to call the PCB factory to talk about this. I'm hoping for a 'stable' price for each kind. Wouldn't be nice if the KGSSHV boards' price is low, but the Dynafet's is extremely high.
If everything goes as my expectation, the boards should be in everybody's hands within 5 weeks from now. That's quite optimistic though. Shipping time may vary a lot.
Somebody has to start begging Dr Gilmore to do a run for the teflon Stax jacks.... *run away*
Edited by Lil Knight
Please make a prototype and have someone test it. 100 boards is too big of a risk in my opinion.
Agreed. A extra wait to ensure that the boards are perfect is well worth it.
No way i have enough time to make that many more stax jacks.
Here is the design
http://gilmore.chem.northwestern.edu/staxout3.pdf
Should be about $7 when made in quantity in china.
original kgsshv amp board with on board heatsinks known
to work perfectly with single fets, and upside down dual fet,
new version should be checked for errors.
someone needs to check the side mount kgsshv amp board for
errors just in case i messed something up when i pushed stuff
around.
someone needs to check the power supply board against the
schematic to make sure i did not make any mistakes there either.
prototype run for kgsshv power supply not a bad idea.
prototype run for dynahi/dynafet power supply also not a bad idea.
Guess it's time to start that DIY Time Dilator thread you've been dreaming about.
Libya's in shambles... probably wouldn't be too hard to get some plutonium now.
Edited by DouglasQuaid
known
there should also be a definition and agreement of 'working perfectly'.
Does that mean plays music, or is there some sort of technical meaning to the phrase?
how are we going to source enough 2sa1968 and lsk386 for that number of boards?
Somehow in the many versions of the boards, the dual fet ended up upside down.
Absolutely no idea how that happened. The board works fine and i've been listening
to it for months now. When i pushed components around to shrink the side mount
board, i may have made a mistake, or re-routed something to the wrong place
so its a better idea for someone to check against the schematic. After working
on all the boards for so long, i can easily miss a mistake that would be obvious
to anyone that just looked at it for 15 minutes.
I must have spent 100 hours on the attenuator board. I'm glad that one came out
perfect because with 6 layers, a mistake in the middle is not repairable.
When i go to bed at night and close my eyes, if i still see the board layout, its
time to give it a break for a week or two. The blue polution really is a problem.
i would be willing to place an order to have the teflon stax jacks machined, if someone can locate the pins at the right price
you mean you didnt do the whole thing in 12 hours like the guy who does the other guys "Gerber files"?
that's not at all my point. I'm clearly in the minority here, so I'll just stay out of it.
Try to contact CMC audio directly for a quote, they might be able to give you a better price than wonderco_buy.
I'm sure the first version only took about 4 hours.
But there were 19 different versions. 2 layer, 4 layer, 6 layer
all parts on one side, parts on both sides...
(REALLY, 19 different versions i have them all)
I did not keep track of the time, but i may have more hours
in the attenuator board than the T2 board set.
Wait a minute... Isn't this the same guy that says his gerber files cost tens of thousands of dollars
to produce? Or did things suddenly get cheaper.
the files cost tens of thousands, but the labor is cheap
im not familiar with either of these names, or the part #
CMC is the company that make those teflon tube sockets: http://www.cmc-audio...-sockets-c.html
I just sent them an email asking about the pricing for those pins. Hopefully it'd be cheaper than buying from the guy on fleabay.
Also, according to their FAQ, they can do OEM connectors. Not sure if they could make the Stax jacks though.
I'm in for 2 sets of KGSSHV, 1 onboard, 1 offboards.
Regarding the transformer, I assume people are going with SumR? If we agree with on a configuration with dual primaries for 110/220V we might get a good price as to people buying seperately.
