- Past hour
I carefully cross-checked the circlotron schematic against the PCB layout and noticed a few discrepancies between the two. I’m posting them here so others can help double-check the circuit. All the locations where the schematic and PCB differ are marked with red lines in the file. CirclotronV.11.pdf
- Today
Dusty Chalk replied to Knuckledragger's topic in Off Topic
- Yesterday
Happy belated birthday! (party favour noise)
RIP, Brigitte Bardot...
Happy Birthday!
No, it's supposed to be an Amplifier for electrostatic headphones, such as Stax.
We got an unexpected 3” overnight (that’s what she said) on top of the 4” earlier this week. First white Xmas in a good long time.
- Last week
Happy belated Birthday!
Thank you everyone. Had a nice one with my wife in our summer(winter)cottage. Now I’m preparing for Boxing Day +6. Birthday of both our children and one grandchild. Happy New Year everyone!
Maybe more like a power up-Carbon ; same design but with higher PSU voltage and new current sources, using current production sicfets.
I think there's no resistor to limit the current so it blows up.
Low precision writing on my part. No LEDs directly in CS circuit itself, but on the boards I have, two LEDs sit across the incoming CS power rail, so they see 15V.
its a new carbon? "kgsshv-carbon board with the 3rd generation sicfets as both current source and gain stages. +/-400 to +/-600 - probably limit to +/-550" (c)
new board in the stax mafia google drive has the orientation of the ttc004b fixed. edit: current limiting on CS LED???
Test build of Super-Carbon up and running to see what is what: PSU angle brackets are recycled from a previous, very tight, build, where those cutouts made perfect sense . Two small issues worth mentioning on amp boards. First, TTC004b and PZTA42 have opposite pinouts (ECB vs BCE) so if using TTC004b, transistor front needs to face heat sink. Second, you need to add some current limiting on the CS LEDs if you intend to use them. Running at +/-550V. No listening yet; need to build a more permanent CS supply solution first and also tidy up in general.
