- Today
That looks rather old and not fun at all to work on. When was this made, the 90's?
I currently have an Odyssey Stratos Plus power amp which I have used for I guess going on 20 years and have been pretty satisfied with. I was thinking about upgrading it as these have gone from the Plus model to Extreme models. Klauss of Odyssey is now offering a Kismet amp. I can get my Stratos upgraded to the Kismet pcbs with a larger power supply for a fairly reasonable price. However, I ran across an opportunity to get a Mark Levinson No. 23 for around the same price as upgrading the Stratos. Reliability is a large factor in my decision. I've read a number of threads on diyaudio related to repairing Mark Levinson gear, and most of them seem to be a massive PITA to work on. This amp is no exception. The amp I am being offered would be coming from a Chicago dealer. It was repaired by Stereo Rehab in Chicago with some thermal issues (one bad channel). The explanation given doesn't really make a lot of sense to me, and I can post that if anyone wants to see it. Stereo Rehab is not an authorized ML repair facility; they do warranty the work done on this for 1 year. My only interest in this amp relates to the superlative reviews it got, and thoughts from some that these still hold their own with pretty much anything on the market. They apparently were very well built (and designed), using high quality parts, but the parts and architecture of these is jam packed together. Cosmetically, the amp looks virtually new, at least outside. Any thoughts on this appreciated. Right now, I'm leery and leaning against going for this.
- Yesterday
That sounds delightful. I've only made the traditional spaniard ones with the toasted almonds in the center. HS
Are you OK? That tirade would have to be the least intelligible one I've ever read. Maybe a giant and calm edit would improve it so I (and probably many others) could understand what your point is.
Long post, ADHD warning, am old school. With respect to the usual suspects and in danger of disrupting the circle-jerking? Which, by all means, keep at; The 007 variants were as non STAX as they could possibly get. - Certain people that would have found nirvana(tm) decades ago if only they'd bought a certain Sony, or specific Fostex/Audeze/Rosson headphones? They elected not to. Went the hard way (read: "i ride the different rain", read: i just must spend more, read: i feel so refined), when all they'd have had to do was find the chain that would be best for said type of headphone; and between interface/transport, DAC, pre-amp, amp and cabling, it does exist and in infinite variations. Only of course, they do not "believe" in chains, or do not "believe" in the need of a pre-amp, or do not "believe" in cabling, or, reasons. And instead, we're.. here. For nigh two decades now, congratulations One headphone gave them something they'd not heard before; but only because they were clueless, blame's on them for sheer ignorance. Put differently if it helps, not sure when people needing anything (insert adjective) low end pronounced or focused went for STAX? I mean, since when exactly? That's right, since never, not until that accursed thing came out. And sadly it sold well rather than flopping; sadly, because it showed, even to STAX, where the curve is. And i do blame each and every one for re-inforcing said conclusion (be it due to ignorance or monetary gain mind, yeah?). Find a few people with big pockets, there you go with the trend shifting, just like that. There were, are and shall remain many, many headphones for those folks, but.. they're not niche now are they. Where's the class, the individuality if you will.... if only you knew how many times i've seen this. Four+ decades and three continents over by now. - Contrary to elitist, individualistic, circle-jerking-focused belief? The world does not revolve around you. Sorry to break it to you. Head phones requiring significant power, ergo headphones that require significant investment in amplification, are headphones most folk cannot buy, not if they know what they're doing (and folks usually don't, not even here; i do read). The money involved to do it right is just prohibitive. You can have a halo product or two, as it drives sales all the way down, but you need a realistic approach. What you're wishing for would close STAX down, not help it grow back up; may not seem so in this glass bubble of a virtual corner, but out there, that's where it'd lead. Competition in what you're after is beyond fierce and they're too old to play the social media hype game. Entering the rest of the issues STAX faces, because those exist, yes.. nothing to do with 007 however, nothing at all. Kindly keep it real and differentiate your bloated self-want from the expansive reality governing one entire ecosystem. Kindly. Just because someone needed to say it. I mean we read your posts, if once in a while you get to read ours, yeah?
Sorry for the double post, everyone. I was curious how one sources AEO-7. Here in the US it seems very hard to get since most chemical manufacturers will only ship to industrial buildings and labs. It's not like I'm trying to buy a 1 ton drum of the stuff but alas.....
Bacon wrapped, Goats Cheese stuffed (pitted medjool) dates.
I'm really thinking that they "gimped" the 007s design on purpose.... They moved away from the gold plated fiberglass electrodes to what appears as aluminum electrodes just like 009 and Lambdas. The outer area that was solid on the previous iterations of the 007 have also been reduced probably to reduce capacitance, but this decreases the damping on the membrane. I'm sure that the new 007 probably presents with a degree more of that midrange "rising response" that we see on nearly all the other STAX using similar design philosophy and brighter treble. The pads now resemble the dimensions of the 009 especially with the uniform opening. I think that a big part of the 007 sound was the D shaped pads which would distribute front volume modes better than a uniform circle.... The 007 was a distinct tuning in the line-up and they for reasons only known to god put it in line with the rest... Some sorta 009 lite design. I can't say I really like STAX sacrificing the engineering of their older models for "easier to drive" alternatives that don't sound as good....
Beautiful fare! What did you stuff the dates with, Grahame? HS
I guess he gave up the ghost when he heard Dr. Demento announce his retirement and the end of his show.
RIP Tom. Listened to him a lot growing up. The Pigeons are safe now...
- Last week
I'm a bit late but Happy Birthday, Antonio!
Happy belated birthday Antonio!
Muchas gracias, chicos A nice day. One year less to retirement. So tired…
No idea as I've never had a broken set here to experiment on. Based on this set the coating is definitely helping and I'm about 85% balanced now. The plan is to rewire them and see how much that changes. I'm not a fan headphones being out of phase in general, I always reverse it on HE60's when I work on them as they are also wired out of phase from the factory.
Tom Lehrer, song satirist and mathematician, dies at 97. Also, Tom Lehrer was still alive.
The Quiet Melodrama of Todd Hido https://aperture.org/editorial/the-quiet-melodrama-of-todd-hidos-photographs/ -
I should have more than enough left over Baltic Birch plywood for a splining jig accessorie and even more. T tracks, hold downs (another set of hold downs packaged with the long T track), knobs and a stop. All of this will make more sense once the jig is completed. Plenty of leftover Black laminate (I assume from the chop saw station), and some Ipe to build the bridge part of the jig, that will overlay the existing SawStop fence.
Brother came up this morning on his way to his place in NH. Dropped off 2 bottles of Ardbeg 25, plus additional surprises! The Ardbeg 25's come in a lovely Russian Doll type box set, the inner box has a nice metal design on it. The top of that inner box looks to click open and close on a hinged cover. The Smokiverse is another limited edition, this was an open bottle from a sampling day that one of his clients had. Looking forward to trying it, there's only a tiny bit left.
